Question about Virtual Reality Black Vr3 Wrless Backup Camera W Color Monit
MY VR3 GPS CRASHED GOT ERROR CODE 0X6 - Virtual Reality Black Vr3 Wrless Backup Camera W Color Monit
  • rreyes34 Sep 04, 2010
    The answer does not fix my problem
  • 666 Answers
What you will want to do is go into the users guide and find the reset factory defaults option usually it involves holding a button or two while starting the device however are sometimes very different
hope this helps
Robb
Posted on Sep 05, 2010
  • 19,396 Answers
Hi. The 0x6 is not an error code, if this is reported as quirk, it may indicate a faulty timer board, otherwise it is probably a firmware problem.
There is no or scarce documentation on this problem, did you try contacting the support number listed on the documentation to find out if a firmware update is available?
Posted on Sep 04, 2010
Vr3 bluetooth password
  • Turn on the Bluetooth device that you would like to sync to by pressing and holding the multifunction button on the device until the blue light turns on.
  • 2
    Navigate on your Vr3 phone through the main menu to "Settings," "Bluetooth," "Handsfree" and "New Device."
  • 3
    Click on the name of your Bluetooth device and enter the default passcode for the device, which is "0000" for Motorola devices.
  • 4
    Click "Connect" and your Vr3 will be synced with the passkey to the Bluetooth device.
  • Good Luck
    Oct 28, 2010 | GPS
    I got the VR3 gps with back-up camera less than a month ago, the first day it worked perfectly fine, then when I installed the route 66 stuff it started showing me some really long message saying to...
    Ok so this happened to my gps after an improper shut down. Here is how I fixed it. Follow each step carefully and make sure your gps is fully charged before beginning.
    1st open up the route 66 disk to see files not actually accessing the program. Right click on the disk and tell it to open from my computer. you will see many files one folder will say memoryimage.
    2 Then on the gps click on settings and go to backlight setting backlight to the dimmest stetting. Now go into power and tell your gps to never standby.
    3 Plug your gps into your computer then turn it on. Windows mobile will come up click on connect without setting up your device. Under file management click on browse contents of your device. You will now see what is actually on your gps. Open NANDFlash.
    4 Now select all items except the route66 folder in the memoryimage folder of the disk and move them into the NANDFlash folder of your gps. When it asks how to transfer tell it to replace current folders with the same name. It will then take several hours to transfer.
    5 On mine the route 66 exe file would not transfer back into the actual route 66 folder so I created a new folder then transferred the route 66 exe file from the route 66 folder in memoryimage of the disk into my new folder in NANDFlash. Once it is transferred you should be able to click navigation on the gps and have your gps load route 66. Your maps will be locked.
    6. I kind of forgot how I did the next step because I cannot get back to where I was because I have already activated my gps. Go into the main menu from inside route 66 and either enter the extras folder or route 66 settings. Somewhere in one of these you will find a place to activate your route 66. It will then give you a website and an id for your gps. Go to the website and enter your gps id and the code from the voucher code card which came with your gps. Once entered on the website you will receive an activation code which you will have to enter into your gps. I recommend you turn off your gps then turn it back on and give it time to find you. You can go into gps status to watch for a signal and once you have a good signal it may take several minutes to locate you. After it has found you it should be working fine.
    Aug 06, 2010 | GPS
    I crashed my truck dont have the password or
    There is no master code, you have to send it in to Garmin to have it removed. This is to keep it from being used if it is stolen.
    Feb 19, 2010 | Garmin nuvi 780 GPS
    I need the codes for a GE univeral remote for a memorex tv
    You can download a list of codes from these links:
    Try all of the codes that you download and at least one of them will work.
    Thank you for using FixYa! Have a nice day and please remember to rate this solution.
    Kind regards,
    BearWeb
    Feb 07, 2010 | GE Televison & Video
    How to change region code on Toshiba D-VR3 player?
    1) In DVD mode,press System Menu.
    2) Go down to the Lock icon.
    3) While lock is highlighed, press 0 for seven times (o,o,o,o,o,o,o).
    4) There will be a pop-up window that asks you to confirm.
    5) Press ok.
    Jay
    May 21, 2009 | Toshiba D-VR3 DVD Recorder/VCR
    VR3 VRVD630 dvd bypass instructions/codes
    I also just bought a VR3 DVD -CD PLAYER MODEL# VRVD630 ALL I DID WAS CONNECT THE BROWN PARKING BREAK WIRE TO THE GROUND WIRE THAT LETS YOU WATCH DVD WHILE DRIVING HOPE THIS HELPS
    GOOD LUCK STROUP
    Nov 27, 2008 | Jensen VM9510 Car DVD Player
    Pass code for VR3 (Roadmaster VRTB100 Bluetooth)
    the passcode for most BT are 0000
    Jun 20, 2008 | Cell Phones
    Virtual Reality Black Vr3 Wrless Backup Camera W Color Monit Logo
    156 people viewed this question
    Top Virtual Reality Home Security Experts
    Lawrence Oravetz
    Are you a Virtual Reality Home Security Expert? Answer questions, earn points and help others
