Question about Panasonic C1153 1100 Watts Convection / Microwave Oven
My panasonic ne 1856 microwave is faulty. It cut out two days ago, i imeadiately changed the fuse but this was not the problem. After being turned off at the plug for some time it stated to work again but only for a short time. Do you know what the problem could be
fridgetech
  • 473 Answers
SOURCE: 1250w panasonic inverter microwave
Yes these are torx safety bits could be a t-10,t-15, or t-20.  Replace the fuse and see what you get.
Posted on Oct 15, 2007
MicrowaveSvc
  • 9047 Answers
SOURCE: Panasonic Dimension 4 microwave model
A microwave can be dead for many reasons.
It may be the fuse, which is usually located on the floor of the oven behind the control panel or between the door switches.
If the fuse is good, it may be an open thermostat or thermal cutout (TCO) / thermal fuse on or near the magnetron or on top of the cavity / body of the oven.
If it goes dead for a while during or after cooking then comes back on, the magnetron is probably overheating and causing the magnetron thermostat to open.
Then when it cools, it closes the circuit and allows power through again.
When checking thermostats, if it has a hood fan thermostat, that should read open, as opposed to the others, which should read closed.
If it went dead almost immediately after pressing the Start pad, that's usually a shorted high-voltage capacitor.
If it went dead a few seconds after pressing the Start pad, that's usually a failing high-voltage transformer.
If it goes dead or blows the breaker (or GFI) when you plug it in or open or close the door, then there's a problem with a door switch or door switch mount.
If it's intermittent or random, it may be a bad connection, usually on the control board or a loose fuse holder, or even an intermittent fuse.
You should do a continuity test on the fuse while it's in the holder (with the microwave unplugged, of course) then turn the fuse by hand or take it out and put it back in, then test it again.
If you remove the fuse, then press the meter leads against the ends, it can allow internal contact to be made and make a bad fuse appear to be good.
Posted on Aug 03, 2008
jyackle5
  • 8197 Answers
SOURCE: Hi I have lost my
ou can buy one here
http://www.user-manuals.com/advanced_search_result.php?keywords=panasonic++NE+1856&forward=plist
or you can call panasonic at
(888) 536-3201
Posted on Dec 18, 2008
cactus bob
  • 267 Answers
SOURCE: microwave cut off
the main control board is "seeingf" a high amprage draw from the inverter board . you have a problem with the inverter or the magntron . parts are more than a new unit . try to stay away from the inverter type , there just not ready for prime time . google "panasonic inverter reviews " and you will see just common your problem is good luck
Posted on Jan 17, 2009
MicrowaveSvc
  • 9047 Answers
SOURCE: my panasonic nna770s combi microwave cuts out
See if this describes what's happening:
  • Put in time, push start and unit runs for 2 seconds, relay clicks, unit goes off. Cook time on display goes off and clock time comes back. Bad upper interlock switch and charred connector
If so, see http://www.microwavedisplay.com/safety.txt , http://www.microwavedisplay.com/disassembly.txt and http://www.microwavedisplay.com/doorsw.txt
Otherwise, if the digital programmer circuit / controller does not get a feedback signal from the inverter for a period of 3 seconds, the controller will stop the cook cycle.
It may be a loose connection in the wiring between the inverter, magnetron, and/or control board, or maybe one of those components has failed.
Due to the lethal voltages used and produced in inverters, I do not recommend that an inexperienced person work on these.
You can find an authorized Panasonic servicer here.
In Canada, you can find an authorized Panasonic servicer here.
If you;'re not in the US or Canada, see the support or service links at www.panasonic.net.
Posted on Sep 11, 2009
Replace fuse panasonic ne-8860 microwave
The outer cabinet has to be removed to gain access. Be aware that you will be exposed to potentially lethal voltages, even with power disconnected.
Feb 12, 2017 | Panasonic Microwave Ovens
The problem of my microwave panasonic, i flug the socuit then ok,i put one minits then i start but the fuse inside the microwave cut off then i change the new fuse but still cut off what is the sulution...
I would call an approved Panasonic repair shop, as there is a possiblity that the invertor is faulty and that requires specialist equipment to repair it.
Jan 12, 2011 | Panasonic NN-S960WA Microwave Oven
Which fuse to connect with the main supply for ne
You will need at least a 20AMP BREAKER.
2100 Watts. at 115V = 18.2 Amps.. therefore your breaker MUST be more than that, to allow for inrush current in the event the oven is left on high when connected.
Feb 05, 2010 | Panasonic Pro II NE2180 2100 Watts...
Fault code FO9
F09 means that it's running on the wrong power frequency.
Is this a model designed for a different country than the one you're using it in?
Does your owner's manual show a way to select a different power frequency?
If for some reason you don't have your owner's manual, see Panasonic.net for support.
Oct 10, 2009 | Panasonic Microwave Ovens
Where is the fuse and reset button for the Panasonic NE1064TC located. Can anyone help with this. Thanks,
On our Panasonic microwave there are two fuses, a regular cylindrical current fuse and a one-time "thermal fuse." If you remove the case which in our unit is held on by a handful of screws on the back of the unit, both fuses are visible if you stand at the rear of the unit and look on the left hand side. The thermal fuse is the gadget attached to the top of the magnetron heat sink. It is typically in the white wire. The current fuse is located in the black wire. I hope this helps!
Mar 27, 2009 | Panasonic NE-1054 1000 Watts Microwave...
Replacement part for microwave
That would have been # ANE06012L0APbut it is listed as no longer available from normal distributors.
It looks like you can still order it here.
Dec 04, 2008 | Microwave Ovens
Microwave runs for a few seconds then F 12 displays on screen and it stops
The following is a solution for the Panasonic brand microwave. I do not know your brand so this is the best I can do.
PANASONIC
Model: NE-1057, NE-1057C, NE-1257, NE-1077, NE-1277, NE-1457, NE-1457C, NE-1757, NE-1477, NE-1777 Symptom: Code "F11" or "F12" appears on the display intermittently Problem: Moisture is accumulating on control panel from steam rising out of the door. Solution: Install foam sealer (cushion rubber) along lower edge of control panel escutcheon. Part # A8251-3180
Apr 03, 2008 | Microwave Ovens
Panasonic C1153 1100 Watts Convection / Microwave Oven Logo
117 people viewed this question
Top Panasonic Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Jerry Greenberg
Jerry Greenberg
Are you a Panasonic Microwave Oven Expert? Answer questions, earn points and help others
