Help me about compaq d330 st
Hello gud people here i plugged my pc into 220v outlet and i donot noticed that my pc is set to 110v as.booooom! sound i heard. about me i have a small knowledge in trouble shoooting.i replaced 3 metal oxide varistor on its power supply because i see that it has burned then i test the power supply itself and it is now ok.then i put it again in my pc put the connector in their proper place.then i turned on it again the two indicator lights light up then the one remains light up and blinking.but it doesnt turn on my pc.the one indicator i mean has a bulb drawing on it.do yout think there are some components of my power supply should be replaced?and when i plug the psu it self the fan is not working.and it there is a possibility that my hdd and motherboard have been damage also?pls help me pls.
  • 35 Answers
Heloo yaoming.the best thing now is not doing a Rnt on your pc.get a spare powersupply and test on your pc if its working properly and about your current powersupply its still not in a working state as the fan is not working.if you are not a expert in powersupply leave it to a gud tecnical personell in your area.if it would have been a detail report about the powersupply i would have helped from my side.hope you get me.
Posted on May 11, 2008
What is required to use it as far as electrical outlet.
Dryers come in both 110V and 220V.
If you plug a 220V dryer into a 110V socket, it will run very slow.
If you plug a 110V dryer into a 220V socket, it will burn up.
If you can find a 220V extension cord, then you should be able to use it.
Mar 08, 2015 | Dryers
I accidentally plugged in my pulmoneb in a 220v outlet
plugging a 110v device into a 220v outlet is not likely, as the plugs are a different configuration. In the event that you somehow managed to do that, your device is probably fried, as that would be to much voltage. Hate to say it; but you are probably gonna need a new one
Nov 27, 2012 | DeVilbiss PulmoNeb Compressor Nebulizer...
How to use it if we have 220V outlet?
If the AC unit is 110V then you must plug it into a regular 110V outlet. You cannot plug it into the 220V outlet. Either get a bigger 220V unit or use a 12 gauge extension cord to get it to a 110V outlet.
Sep 06, 2011 | Haier Mechanical Air Conditioner HWF05XC7
I want to put machine in my house but need 110 motor instead of 220. nothing wrong with motor or control box
I'm assuming that you brought a vacuum cleaner from a country that uses 220V to a country that uses 110V.
You either have to change the motor to a 110V motor, or find a way of plugging the cleaner into a 220V supply.
You could contact the manufacturer and ask them if they have a 110V replacement motor for your model. (Safety warning... it will take double the electrical current, which will cause four times the heating in the cable; this could be dangerous.)
A better solution would be to have an electrician fit a 220V outlet in your house. The pin arrangement will be different to prevent 110V deviced being plugged in to it. You'll have to cut the existing plug and replace it with the correct one for that voltage for your country. (I have used a British 'Dyson' in this way, plugged in to a tumble-dryer outlet; I use a GFI for extra safety.)
Jan 19, 2011 | Vacuums
Plugged my US made PC into a 220v outlet!
Hi
You need to change power supply unit. You can find a guide with screenshots here
May 03, 2009 | E-Machines eMachines Desktop PC
DVD
what operating system did you replace XP 32bit, XP 64bit? Was the version of Vista you used the 32bit or the 64bit. You may need to go to HP.Com and look for replacement drivers for the DVD. You can also use the windows update to obtain correct drivers for the DVD if they have tested them already. Another option is to go to the manufacturer of the DVD device and see what they list for the driver. Just remember there is a big differance between the 32bit and 64bit drivers. Read on the Vista system you installed and see what level was installed in your system. Regards, rcampsr
Feb 21, 2009 | HP Compaq Business Desktop d330
Power conversion
Ram,
Good day mate, no problem you can plug your dvd direct to your outlet since it indicates 100 - 240V it only means your player is capable of having either 110V 0r 220V.
note: also try to check 1st if you will see a voltage selector at the back of your dvd player. it's either a slide switch indicating 110 or 220V. if no sign of this selector no problem you can plug your player straight to your socket.
cheers
mark
Jan 29, 2009 | Durabrand DVD-1002 DVD Player
Power outlet
Here is the specification sheet for that machine. Look at the power section.
http://www.patriotgroup.com/colorcopiers/af6513specs.html
Oct 22, 2007 | Ricoh 6513 Copier
Power supply 220v
Most laptops dont have that switch. You need a power adapter, to do the work for you. Or just get a generic adapter, to plug your power brick into.
Oct 10, 2007 | HP Compaq Evo Notebook N600c
Computers & Internet Logo
219 people viewed this question
David Payne
David Payne
