Question about Vacuums
My jm3 1500w super lightweight cleaner simply just cut out last night, only had it a couple of months, changed fuse and still not working, filter was already cleaned out,pipesare not blocked either.HELP
5 Suggested Answers
SOURCE: Motor overheating
Had the same problem 2 years ago. Washing filters only a short-term solution. After contacting Dyson, they replaced the shroud and cyclone under warranty. This cured the problem from July 05 until last week, when the motor has started to overheat again and cuts out on the high temperature safety trip. Mine is out of warranty now, so am unsure how to proceed. Maybe buy the parts they sent me before, but reckon they'll be expensive.
Posted on Jun 02, 2007
reddevil6
  • 1673 Answers
SOURCE: sebo x5 vacuum cleaner
The full bag light comes on when it is getting full or a blockage in the hose or the dirt inlet by the brush roll. Other then that, there is a circuit board called the computer controller, part #5740ER and is giving you a false reading and causing a shut down.
Posted on Jun 22, 2008
  • 3 Answers
SOURCE: Power cut off after handle was dropped on floor while vacuuming
connections inside the handle came loose. happens to me all the time. take the handle apart and connect the wires back.
Posted on May 29, 2009
kevster6720
  • 171 Answers
SOURCE: My sebo cleaner keeps almost
Sounds like a bad sensor or a possible loose connection electrically. If you are very handy with tools you could try taking things apaet but a dyson is expensive nso I would leave it to the pro's and take it to the local used vacuum shop. They give the best advice in these situations.
Posted on Oct 07, 2010
Testimonial: "My husband took it all apart and put WD40 on the connections, its working fine now. Thankyou for the advice"
Which vacuum would you prefer for pet hairs ?
I've been repairing vacuums over 30 years, I prefer a bag vacuum because a good bag vacuum is a lot less maintenance, all the nasty stuff goes in a cheap paper bag (which is actually just a really good great big cheap filter) which you simply remove and gently sit in the trash. It usually takes less than 30 seconds to change bags and only needs done about once a month. You will dump a dirt cup about 40 times compared to changing one bag. Bags compact the dirt while bagless fluffs the dirt. Bagless filters and dust compartments need frequent cleaning and replaced at least once a year to work properly. Bagless vacuums leak more dust and dirt which you will notice on your vacuum. In the long run its much easier and cleaner using a bag vacuum plus they usually last much longer, usually outlasting 3 or 4 bagless vacuums. Much less expense and hassle in the long run.
Mar 05, 2018 | Vacuums
How can I get auto rewind to rewind?
give the power cord a couple sharp tugs quickly and release
Jan 16, 2016 | Royal S15 Lexon Series Lightweight...
Volta vortex 2200w vacuum cleaner
See if the company will fix it under warranty. If not, you can take it apart and look for the obstruction. It sounds like something is inside obstruction the air-suction flow path. Normally the motor or controller would not cause the motor torque to drop.
Apr 02, 2017 | Vacuums
My miele has no suction and i changed the bags
99% of the time you can fix this problem with a new filter i have put the link in for the filter for your vacuum cleaner if you have changed the filter in the last 3 months then you might have a blocked hose check the hose first then get yourself a new filter
Miele filter for s514
Jun 04, 2012 | Miele S514 Solaris Bagged Canister Vacuum
Bionaire humidifier model:bcm7309cm How to clean the air filters?
"You should change your furnace filter once a month in the winter season and your central air filter once a month during summer months.
If you run your heat or air every day and night, have pets, or your home collects a large amount of dust, you may need to change your filter more often during very hot and very cold months.
If you use disposable filters, it's really not worth vacuuming them to reuse them. They are inexpensive enough that you should replace them instead.
Disposable filters don't work as well after only being vacuumed and they are usually in a cardboard frame and therefore don't wash well.
Before you take out the filter, however, vacuum the outside and around the filter encasement. After you remove the filter, you should vacuum behind it, too, to catch any stray dust and particles.
Replace disposable filters with new ones."
(http://www.mrscleanusa.com/en/cleaning-tips/tip/cleaning-air-filters.html)
Mar 03, 2011 | Vacuums
Hoover turbo cyclonic only 12 weeks old stopped working while cleaning. I was using the hand tool and after about 3 minutes it just stopped and will not turn back on.
try changing the fuse in your plug ( uk ) if this fails to fix it , have it repaired under warranty
print-icon.gifPrint/Download
Warranty The Platinum Collection Lightweight Bagged Upright plus Portable Canister warranty covers parts and service of the cleaner for six years.
As a member of the Hoover Platinum Collection, the Platinum Collection Lightweight Bagged Upright warranty gives the owner access to the exclusive Platinum Collection member services line for the best in customer service.
TTI Floor Care North America
7005 Cochran Road
Glenwillow, OH 44139
1-877-MY-PLTNM
Nov 15, 2009 | Vacuums
May 16, 2009 | Oreck XL Ultra Bagged Upright Vacuum
Vax 2400 performance pet overheating
Unfortunately there is no permanent solution.It is a terrible vacuum cleaner and im getting rid of mine today. I have been maintaining it for 6 months cleaning filters , swapping filters, swapping carbon brushes all to no avail.Dump it. it would'nt **** the air out of a balloon.
Jan 29, 2009 | Bissell 9500 ProHeat 2X CleanShot Upright...
Vacuum cleaner filters
Sponge filters should be washable. I have found that "FLASH" lemon floor cleaner is by far the best, but washing up detergent will do (far too many bubbles to get rid of for my liking!). I find pouring the detergent onto the sponge and working it in before dunking it in very warm water works best. Despite not being very washable, most paper filters can be washed if you have no other choice and you take care. Just pour on cleaner and then dunk up and down in hot water. Then leave in the airing cupboard for a couple of days to dry. It should get you by until you can find somewhere to buy a new paper filter.
Jan 23, 2009 | Vacuums
My scunci steam cleaner has a white build up and is clogged. How can i clean it?
I had not used my scunci for a few months and now it is completely clogged. I tried vinegar over night and removed a lot of sediment, but it is still not working. My last shot was going to be to use lime-away. Any suggestions. All parts look in mint condition, but it just doesn't work.
Sep 28, 2008 | Scunci 52067 Handheld Steam Vacuum
Vacuums Logo
78 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
