Question about Broadcom (BCM94318MPG) 802.11g/b Wireless Adapter
When i started my laptop the adapter is not showing in device list, when i deleted all network devices from the list and restart the laptop and searches thru system bios setup then this will work for one time. After i shutdown and re strart the laptop same WIFI is not showing in device list
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 103 Answers
Donot use an extension cable or a USB hub. Connect the wireless adapter directly to the computer. Try with different USB ports on the computer. Try updating the latest driver. Check it with a different computer so that we can isolate if it is the issue with the computer.
Posted on Sep 03, 2010
LAPTOP SCREEN JUMPING EACH TIME I TURN IT ON
Check Video Drivers, Start - Computer (Right Click) - Properties - Device manager - Display adapters (Right click on Driver Listing - Disable
Restart the computer. Should work fine with basic drivers
If not, Follow the steps to go to the Display adapters and uninstall the driver software with delete existing files.
Restart the computer, Update the display adapter drivers online.
Regards,
Nov 05, 2013 | Dell LATITUDE Computers & Internet
My friend has an acer an she is trying to put the network adapter that were originaly on the computer becaus her boyfriend deleted it
If I am understanding you. Then all that was done. Was to remove the drivers for them. So they won't show up. However they will appear with exclamation point in device manager.
(start/run/devmgmt.msc) then we just need to reinstall the drivers. to help you identify the needed driver check here http://support.acer.com/us/en/default.aspx. they can be stored on a flash drive and select update driver and point to the flash drive for the needed files.
GL
hope this helps
Don't forget to vote for me
Thank You
Jammer
Aug 17, 2011 | Acer Computers & Internet
Wireless adapter not found
uninstall the drivers
click on start then right click on my computer, then click on manage, the a page will come up, on the left side of the page you will get the option of device manager on the left, once you will get the device manager, click on device manager, you will get the list of devices, in the list of devices, click on network adapters
once you click on network adapters there would be an option of wireless adapter, right click on wireless adapter and click on uninstall, once it is uninstalled, restart the computer, it will detect the drivers automatically
Aug 14, 2011 | NetGear Push2TV TV Adapter for Intel...
Wife accidentally disabled wireless on hp mini. How do I restore wireless?
Hi Sathomas,
I have found that a similar question was asked and the solution was provided on fixya ,
http://www.fixya.com/support/t3006204-cannot_get_netbook_connect_wireless
Hope this works for you, your feedback would be appreciated.
May 13, 2011 | HP Mini 1000 Netbook
I got a wrt54gh router just less than a year now. it is connected to our desktop being used by my son & grandson in our living room, while i'm using my laptop in my room. it just happened that i...
If you have Windows XP then try this, for Windows 7 and Vista also the procedure is similar. If you have Vista or 7 then tell me I'll post the tutorial for that also.
  1. In Windows XP, click the Start button and select Control Panel.
  2. Click the Network and Internet Connections category.
  3. Note: If you are using Classic View, you will see the control panel icons instead of categories. Double-click the Network Connections icon.
  4. Click the Network Connections control panel icon.
  5. Double-click Local Area Connection, listed under LAN or High-Speed Internet.
  6. When the Local Area Connection Status window is displayed, click the Properties button.
  7. In the Local Area Connection Properties window, do the following:
    • Verify that the Internet Protocol (TCP/IP) box is checked.
    • Note: If your Ethernet adapter is not listed in the Connect using box, you need to install your adapter.
    • Click Internet Protocol (TCP/IP) once to highlight it and then click the Properties button.
  8. In the Internet Protocol (TCP/IP) Properties window, do the following:
    • Click Obtain an IP address automatically.
    • Click Obtain DNS server address automatically.
Apr 11, 2011 | Linksys Wireless-G WRT54G Router
Wireless adapter cannot find enough free resources
please try to see if this steps will work. change the startup type of your wifi card into automatic by:
• click START, click RUN
• type services.msc
• look for WLAN Autoconfig and double click it
• change start up type into automatic and stat the process
• hit Apply and the OK
• restart the computer and also restart your wireless router
Hope these helps.
Jun 02, 2010 | MSI (CB54G2) 802.11g/b Wireless Adapter
I have a hp dv9205us laptop. The wireless network adapter is not listed in the device manager. I try to turn the device on but the indicator light would not turn blue- which is the on position.
hi
As soon as power on the notebook keep tap on F10 - in Bios setup screen press f9 - accept to load the bios default settings press F10 to save and exit
Boot the os in to the safe mode by restarting the notebook and keep tap on F8 to access the safe mode with networking
Check for device in device manager it is not listed under the network adapter
If does not list update the latest version of the BIOS and wlan software
Regards
Jun 10, 2009 | HP Pavilion dv9205us Notebook
Laptop unable to connect to Internet
Assuming you are using Windows XP, try the following: Conntact the maker of your Laptop and find out how to remove their brand of wireless software so your computer defaults to the Windows built in wireless software.
Then:
1. Winsock Reset:
- Click the Start button and then click on Run.
- In the Run window command line type in CMD and press enter, or click OK.
- A black command prompt window will come up.
- At the command prompt type NETSH and press Enter.
- A NETSH command prompt will appear
- Type WINSOCK RESET then press Enter. It will display the following message:
Successfully reset the Winsock Catalog.
You must restart the machine in order to complete the reset.
2. Remove and reinstall the wireless adapter:
- Click on Start, the right click on My Computer and choose Manage.
- In the computer management window that opens, on the left side, choose Device Manager.
- Look for the network adapter heading in the list on the right. Click on the + next to network adapters.
- Right click on the wireless adapter listed under network adapters, choose uninstall. It may ask if you are sure you want to remove it, say yes.
- Close that window and restart the computer. As it reboots, it will reinstall the driver we just deleted. When it is completely start up, try your wireless connection.
May 14, 2009 | Computers & Internet
NETWORK ADAPTER PROBLEMS FOR HP LAPTOP
go into device manager click on wireless device and update drivers or in device manager delete wireless device and restart.
on restart sysstem will detect and install found device(wireless)
you may have to reconfigure so check ip address,dns and gateway details first (find them by clicking on your wireless icon and select properties,scroll to internet protocol.select it get details.
Jan 10, 2009 | HP Pavilion dv6000z Notebook
In device manager Network Adaptor has yellow exclamation mark. "Windows cannot load the driver required for this device." My HP Pavillion laptop is under guarantee - was purchased Feb.2008.
Completely remove the LAN adapter and disable "Plug 'n Play OS" in the BIOS, as follows:
1) Remove the card from Device Manager, under Network Adapter
2) Delete C:\WINDOWS\INF\DRVDATA.BIN
3) Delete C:\WINDOWS\INF\DRVIDX.BIN
4) Delete the following files. Not all of them may exist.
  • C:\WINDOWS\INF\NET82557.INF
  • C:\WINDPWS\INF\NET559A9X.INF
  • C:\WINDOWS\INF\NET5579X.INF
5) Shutdown and restart the PC, and enter BIOS setup.
6) Find the option for Plug and Play BIOS, and disable it.**
7) Restart Microsoft Windows* 95 and use the Intel® installation diskette to reinstall the adapter.
Dec 14, 2008 | Computers & Internet
Broadcom (BCM94318MPG) 802.11g/b Wireless Adapter Logo
74 people viewed this question
Top Broadcom Computers & Internet Experts
Prashant M
Prashant M
Laxman Bisht
Laxman Bisht
Computer Links
Are you a Broadcom Computer and Internet Expert? Answer questions, earn points and help others
