Question about JVC GR-AXM230 VHS-C Analog Camcorder
I have a samsung scl906 8mm camcorder and it keeps eating tapes. help
techman
  • 3130 Answers
SOURCE: Camcorder eating tape
There is a small nylon gear assembly on the bottom of the chassis that needs to be replaced and is not an easy repair for the skilled tech as the entire camcorder has to be disassembled. Good Luck
Posted on Mar 30, 2007
SOURCE: samsung VP - U10
the Capstan servo has corroded and needs to be replaced
Posted on Jun 02, 2008
Bubbabear64
  • 2794 Answers
SOURCE: 8mm analogue camcorder tape playback at double speed
If you ran it through that many 8mm players, I'm going to say that the tape has something wrong with it.
You can see visually if there is anything wrong with the tape by releasing the cover by moving the tape and visually inspect the tape for anything that could be frayed. Usually you can see it on the bottom of the tape.
Sometimes the takeup can be messed up in the tape too. Once you release the tape cover, you can turn the white wheels to see if there is any slack in them.
Good luck on that.
Posted on Jun 11, 2008
SOURCE: tape eating
my camcorder eats the tape and i have alot of tapes that i recorded on it and i can't see them any where else.and no body fix camcorders in my area what can i do?
Posted on Jul 11, 2008
  • 30 Answers
SOURCE: Broken camcorder 8mm tape
Hi There, You can fix your tape yourself. 1- wind out tape from both sides of cassette. 2- cut both sides to form straight edges. 3- cut a small thin piece of clear scotch tape. 4- from cassette tape, put both sides together with recorded side facing down-- in other words you will be putting the scotch tape on the inside of the recorded tape. 4- line up the two ends and splice them together. - cut the excess scotch tape from the edges. Make sure there is no sticky stuff left there because if there is, it could rip out your video heads. The tape should only be played once and at that time, should be rerecorded to dvd or another media.
Hope this helps, mr cicmo
Posted on Jan 13, 2009
Camcorder is eating tapes (or tapes are getting stuck)
Hi ; this problem is a miss alignement off your tapthern and you may replace the pinch roler assy
and a good head cleen up
and that should solved the problem garanty
hope thats will help have a nice day
Mar 04, 2010 | Canon ZR10 Mini DV Digital Camcorder
Samsung Camcorder eating tapes
the roller inside your camcorder might have dust dirt. try to use camcorder's tape cleaner to clean it.
Jun 28, 2009 | Samsung SC-L906 Camcorder
Canon NTSC ZR25 MC Digital video camcorder eating tape how can I fix it
Canon NTSC ZR25 MC Digital video camcorder is eating the tape. I've loaded a new tape and get an "eject tape" message each time. Does anyone know how to fix this issue?
Jun 24, 2009 | Canon ES75 Camcorder
Samsung VP-D103i Mini DV eating tape apon inserting
Have you cleaned the tape deck using a DV tape cleaner?
Jul 06, 2008 | Samsung VP-D103i Mini DV Digital Camcorder
Tape eating
unit need to be cleaned or have parts replaced if they got bad enough.
only, only, only use the more expensive JVC tapes. They keep their tension far better than cheaper brands. Also, they won't rub off their oxide coatings on the heads as easily, avoiding the 'clogging' of the heads (which thereby requires constant cleaning-further damaging the heads).
Feb 04, 2008 | JVC COMPACT VHS-C CAMCORDER
Advise
Will the tape fast forward or rewind? If so, I don't know the the problem. If it either won't FF or REW the tape, there is a problem that can't be fixed without taking it somewhere to be fixed.
Please rate my help. Thanks!
Feb 03, 2008 | Samsung SC-L770 Camcorder
Samsung Mini DV camcorder (Protection-Problem)
SOUNDS LIKE THE TAPE TRANSPORT IS BAD. IT WILL EAT YOUR TAPE SOON. YOU WILL NEED A NEW TRANSPORT OR A NEW CAMCORDER ...SORRY
Dec 14, 2007 | Samsung SC-D103 Mini DV Digital Camcorder
Samsung sc-d353 Eats Tapes
THIS NEEDS A NEW CASSETTE COMPARTMENT. SAMSUNG IS REALLY EXPENSIVE. YOU MIGHT TRY TO PURCHASE A USED ONE OR I MIGHT BE ABLE TO HELP YOU WITH PARTS
Nov 18, 2007 | Samsung SC-D353 Mini DV Digital Camcorder
Samsung camcorder
Defective mechanism, a stucked mechanism is present. camcorder are smart it can detects error and shuts down itself for safety. earlier models dominoes the defect if the user is not quick enough to react when something goes wrong with the camera. You need professional service to fix it.
Aug 21, 2007 | Samsung SC-D353 Mini DV Digital Camcorder
Wont Take Tape
BAD TAPE TRANSPORT. NEED TO SEND IN FOR REPAIR
Apr 25, 2007 | Samsung SC-D353 Mini DV Digital Camcorder
JVC GR-AXM230 VHS-C Analog Camcorder Logo
102 people viewed this question
Top JVC Video Cameras Experts
Larry Stiles
Larry Stiles
Steven Wander
Steven Wander
Are you a JVC Video Camera Expert? Answer questions, earn points and help others
