Question about Turbo Air 23 cu. ft. / 651 liter Commercial Freezer MSF-23NM
Evap coil eventually freezes. But it will maintain 10. The boar
    Sergeant:
    Novelist:
  • 193 Answers
It sounds like you may be low on refrigerant (freon). One way for a novice to check this is to look at your compressor. There are two line coming out of the compressor. The comressor is the black thing about the size of a bowling ball under your freezer behind the grill. The small line coming from the compressor to the "radiator" behind that lower grill should be very hot coming from the compressor. The big line going into the compressor should be very cold to the touch. If that is not the case you are low on refrigerant. Without gauges and a supply of refrigerant you can't fix it yourself. Second thing to check is the thermostat is it set all the way to cold? If not turn it clock wise 1/5 turn and watch to see if the temperature goes down.
Posted on Sep 08, 2010
KFFS20EYMS00
KitchenAid Refrigerator Not Defrosting - Model ...
www.repairclinic.com/...-/KitchenAid-Refrigerator-not-defrosting-KFFS...
Show all parts for model KFFS20EYMS00 ... If the defrost heater assembly has burned out, the frost will build up on the coils and eventually no air will be able to ...
Jul 28, 2015 | Freezers
The fan on my GT345 chest freezer runs constantly. Is this correct ?
Depends are you referring to the condenser fan or the evaporation fan? If it's the condenser fan you may have an issue with debris in the condenser coil not letting enough air flow to cool down so it will stay on to keep from burning up compressor.If it's inside the evaporator coil then it may be low on refrigerant possibly freezing up the evap coil making it run then kick into defrost run kick into defrost etc... hope this helps
Aug 12, 2014 | Freezers
COILS FREEZING UP
On Hoshizaki freezers, it has several items that can cause this. Check to see if the heater in the evap are heating up when in defrost. Older machine can force a defrost by just unplug and then plug back in to outlet to do this. There is a "Klixon" type thermostat that disconnects the heaters in case of an overheating condition. These go bad fairly often. Make sure the door closes and seals. Be sure not to do anything that hampers air flow over the evap.
Jun 25, 2014 | Hoshizaki Freezer Commercial Ice Machines...
Is it okay to freeze Boar's Head turkey and ham after they've been sliced?
Yes, as long as it hasn't been sitting out in the warmth too long, bacteria can grow under those conditions. If it's fine you can freeze it, but take care to wrap it so that it is air tight, otherwise it will freezer burn. After freezing it might not be *quite* as tasty as when brought home from the deli, but it will still be good.
Dec 23, 2013 | Freezers
Coldspot model: 106 725540 freezes sometimes
You can by pass it but I wouldn't. You may need to replace the t'stat on this. This controls pretty much everything. Depending on your model, the defrost cycle can be adjusted to shorter cycles. Bypassing it would eventually lead to ice build up and a real mess to follow .
Feb 04, 2013 | Freezers
Hoshizaki M# DCM-270BAH-OS runs for days then freezes up evap coil and stops water inlet to evap.
There is a thermostat probe sat on the front of the evaporator to tell the control board when to harvest. Check it is tight in it's holder. Check the condenser is absolutely clean and filters clear. You can adjust the thickness of the cube. set it on the thinnest setting and see if it harvests before freezing solid.
Jun 15, 2012 | Hoshizaki Freezer Commercial Ice Machines...
Frigidaire Freezer, model # FFU20FC6AW3. Unit is not cooling and the fan motor inside behind the access panel is not running. My Temperature Alarm sounds and will not shut off, unless I switch it to the...
if the evap fan is not turning try to turn it by hand a few times then start you freezer if it does not turn it needs to be replaced.make sure there is no ice build up on the evap coils.alos check the continuity of the defrost heater below the evap coils.once you het teh fan replace your unit should cool down to the proper temps.
Nov 16, 2010 | Frigidaire Freezer Refrigeration White...
My walk-in's ceiling panel is dripping
The coil in the conditioned space is called the evaporator.
If the water droplets are forming on the ceiling around the evap, it is due, most likely, to the defrost cycle being too long.
Defrost cycle: compressor stops, evap fans stop, electric heaters in the evap come on to clear any ice/ frost on evap fins/ coil.
The ice/ frost melts and some of it turns into vapor. As it hits the cold ceiling surface, it condensates into water droplets. Defrost cycle could be too long. Usually 4 time aday and no longer than 30 minutes should be enough unless there is high humidity.
There could be another cause.
Normally, after a defrost cycle terminates, the evap fans do not come on, due to a delay control. This prevents circulating warm are due to the heaters. The compressor comes on and cools the evap down to, usually 20 degrees or so, and then the fans come on. What could be happening is, the fans are coming on too early and blowing the water driplet off the evap and onto the back wall of the unit.
A third item, is to be sure that the condensate drain is "P" trapped. The prevents warm, outside air from being drawn in and causing exess frost build up, thus excess water and vapor.
Good luck and hope this helps
Jul 24, 2009 | Nor-Lake Freezer Norlake Refrigeration 8'...
Turbo Air 23 cu. ft. / 651 liter Commercial Freezer MSF-23NM Logo
103 people viewed this question
Top Turbo Air Freezers Experts
Dennis Boxerman
Dan Webster
Dan Webster
Charles T Nevin
Charles T Nevin
Are you a Turbo Air Freezer Expert? Answer questions, earn points and help others
