My computer will only go to a blue screen. I cannot even get it into safe mode. It says that a problem has been detected and windows has been shut down to protect the computer
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 103 Answers
Try running the recovery OS CD. If it doesnt work you have to format Hard drive and reinstall the OS
Posted on Sep 03, 2010
4 Suggested Answers
  • 14 Answers
SOURCE: blue screen of death
well 2-4 months ago i attached new hardware and got the same responce
took it out all better
2 thing is you need to what the other guy suggested is reinstall th OS/operating system EX/win 98
or your hard drive is broke
or your harddrive needs to be erased then install everything again
please make sure that what ever new stuff you try to add is compatable to the computer
if your going to download something you don't know into the computer you lible to make it crash and make your life worse.
Posted on Mar 19, 2008
tipstir
  • 67 Answers
SOURCE: Blue Screen
Is this still under warranty? If not then you'll just need to buy another HDD (hard drive device) and connect that one where the old was. Re-install XP or Vista. Conact Gateway or go to the Gateway web site to see what was hardware was supported for your system.
HDD IDE/EIDE or SATA/SATA II
OS XP or Vista
After you find out the info just install the new HDD, and install the OS. I only recommend doing this since you can't even get into the Safe Mode. When everything is back up and running you can also re-attach the old drive to what is called Slave or CS (cable select) this is more automatic process. Then you'll be able to recover any data missing that you need that was on the older drive.
Posted on Jul 30, 2008
geemarie
  • 876 Answers
SOURCE: Blue Screen
You could try turning the computer off at the switch when this happens. Sometimes it is a very temporary problem. You would need to wait a few minutes then turn it back on and restart your computer.
Posted on Aug 01, 2008
Panasonic toughbook cf-74 blue error screen loop
Which OS do you have? Have you tried booting to safe mode?. Restart the computer. Immediately after the BIOS post ends, start tapping the F8 key repeatedly. when Windows Advanced Options menu appears, select safe mode and see whether it boots completely without blue screen(BSOD)
Apr 22, 2014 | Tablets & eReaders
COMPUTER - BLUE SCREEN
what is the error of the blue screen showed? etc Stop :0X00000FE
Jun 08, 2012 | Dell Computers & Internet
Dell inspiron mini 10 Turn it on, put in password. screen says windows did not start up sucessfully. A recent hardware or software change may have caused this. then i go to the last known good...
A blue screen with white writing appears on my computer,
just before windows is about to begin and it reads:
A problem has been detected and windows has been shut
down to prevent damage to your computer.
UNMOUNTABLE_BOOT_VOLUME
If this is the first time you've seen this stop error
screen restart you're computer.
If this screen appears again follow these steps:
Check to make sure any new hardware or software is
properly installed. If this is a new installation, ask
your hardware/software manufacturer for any windows
updates you might need.
If problems continue, disable or remove any newly
installed hardware/software. Disable BIOS memory options
such as caching or shadowing. If you need to use safe
mode to remove or disable components, restart your
computer, press F8 to select advanced startup options,
and then select safe mode.
Technical information:
STOP: 0XOOOOOOED
(OX8OED4AF8, OXCOOOOO32, OXOOOOOOOO,OXOOOOOOOO)
I cannot go into windows even in safe mode, and I don't
know how to execute any of the other things it's telling
me to do.
It may have something to do with my virtual memory as
windows had to increase it while I was playing a computer
game, or because I added some extra pictures I downloaded
to a computer game folder where the default pictures were
already stored.
if u cant do these then reinstall the operating system.
Sep 03, 2011 | Dell Inspiron Mini 10 Notebook
Netbook bios not fully acpi compliant
you are experienceing the blue screen of death, if these happened to yo have your netbook check by a qualified laptop tech to avoid any hardware damages
Nov 22, 2009 | ASUS Eee 4G Notebook
Unable to get into safe mode
hi there !
-try t drain everything out of the computer first; remove the power adapter then remove the battery; after 1 minute try again; if problem persists run diagnostics
--while the computer is off, press and hld the "Fn" key then press the power button at the same time to start the test; note down error message then consult manufacturer for the code obtained. if no errors found it is a windows problem; you need to reinstall windows on the computer
cheers!
Sep 28, 2009 | Dell Vostro 1700 Notebook
Can't log on
what i can suggest you is to reformat/do a recovery..nothing else....dont waste your time..because you cant load in windows right? its commin only with blue screen...when you select safemode or etc..nothing happen...try with my suggestion..if you have some important files you can do a backup by removing the hdd and put into usb adaptor and plug in any computer that can do a backup....i hope you appreciate it
Jan 05, 2009 | HP Pavilion ze4933US Notebook
After loading Window service pack 3 update, comes up blue screen
press f8 and go to safe mode and delete service pack 3. sp3 is known for problems
Sep 23, 2008 | Dell Dimension™ B110 PC Desktop
Blue Screen
Aug 01, 2008 | Compaq Presario SR1103WM-B (PC183B#ABA) PC...
Safe mode business
safe mode automatically comes up when you didn't shut down properly. Just select boot as normal or last known good configuration then you are good to go.
uninstall any new hardware or software you have recently installed to cause the problem in the first place. If you haven't installed anything then windows should just start normally.
good luck
smeags.
Jan 22, 2008 | Computers & Internet
Computers & Internet Logo
37 people viewed this question
David Payne
David Payne
