Question about Coleman Powermate Premium Plus 6250W Portable Generator
My generator is not producing any power how do I go by exciting the brushes
    President:
  • Coleman Master
  • 1,383 Answers
Simple way is to use a small battery charger (1 or 2 amp) and momentarily contact brushes (very quick swipe). You must watch polarity. Check your manual; generally the positive brush is the one closest to the bearing. Oftentimes problem is brushes have worn and are not contacting rings. Examine commutator rings for smooth surface. Remove diode board and check for leaking capacitor. If it is split open, burned or swollen replace as needed. Good luck
Posted on Sep 03, 2010
Why doesnt my Homelite HG3500 generator not produce power when running?
Try flashing the rotor it has lost it's resideual magnetism through sitting.
Disconnect the rotor field wires at the AVR or on the exciter/brushes. Note they are polaroty sensitive. Connect a 12V battery to F+ and F- (note polarity) and momentarilly power from the battery for a few seconds. DO NOT forget to disconnect the rotor/exciter field wires first or the voltage regulator will be damaged.
Feb 27, 2015 | Electrical Supplies
The gt5250 power back generator has stop producing
If it has sat, it may have lost it's rotor residual magnetism. Disconnect the rotor field wires at the AVR or on the exciter/brushes. Note they are polaroty sensitive. Connect a 12V battery to F+ and F- (note polarity) and momentarilly power from the battery for a few seconds. DO NOT forget to disconnect the rotor/exciter field wires first or the voltage regulator will be damaged. If it hasn't sat check voltage regulator, rotor resistance, and stator resistance, and for shorts to ground.
Oct 18, 2014 | Electrical Supplies
Brushless generator has stopped producing power ,
My 7500 watt generator doesn't produce any power
Jul 31, 2014 | Honeywell 7500 Watt Generator 15 HP Engine...
Coleman generator #PM0497000.02 generator starts well and runs smoothly, yet I have no electrical output. I have purchased replacement brush modules, but am unsure as how to re-excite the unit. The...
You have to get a cord that has a plug on on it. On the other end of the cord strip the insulation off the ends of the wire about an inch. It would be easier if you put small clamps on the stripped ends of the wire. Connect the black wire to plus on a car battery and white to negative. Start the generator and plug the cord in to a outlet on the generator just for a second and take the plug out. The generator should now be producing electrical current. If not there is something burned out internally.
Mar 11, 2011 | Coleman Powermate 7,000 Watt 13 Hp...
Hello I got a 5000w powermate generator that could run for hours without problem but when i stop it and restart it again it will not produce electrcity. I have to open the back and clean the plate where...
Did you flash the exciter since it has been sitting and after brush replacement?It has probably lost its charge and needs to be flashed with 120v, let me know and we can go from there
Jan 21, 2011 | Coleman Powermate Powermate 5000W...
Can not excite generator
most generators you can polarize the brushs this is done by using a 12v. battery and a set of jumper cables hook to the battery and touch the brushs with the other ends it doesn't matter whicht side, but before you do all that check the connections at the brushs and see if they are loose or not making a good contact, i do hope that i was able to help you, thank you.
Jan 07, 2010 | Coleman Powermate Premium Plus 6250W...
Generator starts but does not generate power
  1. Check for any blown fuse and replace. It can be traced directly from the output lines.
  2. Check field excitation. The field excitation is supplied by the battery to the excitation coil through a pair of carbon brushes. If the brushes are worn out, no excitation field is supplied and no output is generated. Replace carbon brush if found worn-out.
  3. Use an analog multitester to check the continuity of the carbon brush and the field coil.
Sep 25, 2009 | Honda Electrical Supplies
Coleman Powermate Premium Plus 6250W Portable Generator Logo
669 people viewed this question
Top Coleman Electrical Supplies Experts
John Trevino
Shawn DuRee
Phil Walker
Phil Walker
Are you a Coleman Electrical Supply Expert? Answer questions, earn points and help others
