Question about Acer Aspire 5315 Notebook
My laptop just switches itself off now and then?
    Problem Solver:
  • 6 Answers
Si ce apaga con la pantalla asul que hace un conteo hasta 100 es que tu memoria ran o targeta ce suturo si no ce apaga de esta forma puede ser la pila =)
Posted on Sep 03, 2010
How to replace power button
If you are meaning to ask how to replace the power switch on a Dell Latitude laptop, then that is not something as simple as, say, replacing a light switch on the wall of one's home. This requires disassembly of the laptop and generally the switch itself is part of one of many circuit boards inside the laptop. If the actual switch itself is defective, then the board will need to be replaced. On the other hand, if it is the button that you depress to activate the physical switch, that is most often part of the keyboard cover and would require replacement of the keyboard cover itself. In either case, this is not something for the end-user to accomplish. Take the machine to a certified and experienced local computer repair professional as there are many parts that can easily be damaged by a novice, thus making your problems much worse and that can potentially be so costly to resolve that it would be cheaper for you to replace the laptop with a new one.
Sep 29, 2014 | Dell Latitude - E5510 Laptop Computer...
Why does my Disco 2 R990 radio switches itself on and off at random
Is there a laptop near by? Some (most older) laptops, can send out infra red codes. Used for infra red communication with hardware. I once was shocked when my lights went on and of without any cause. Till I found my very old laptop did so, when I used certain buttons.
Perhaps even another remote control is sometimes giving the right code, just to switch on?
Aug 18, 2014 | Audio Players & Recorders
I ve an acer aspire 5742...as soon as i connect my internet the laptop gets switch off within 30 mins.....it continous to switch on and off...pls suggest me wat to do
Hi
is it the laptop itself switching off or is it the hard drive turning itself off after
30 mins because by default many laptops are set to turn off the hard drive after 30 mins
also by default the display turns off as well after a short time
these setting can be adjusted in control panel power options
Apr 14, 2011 | Computers & Internet
Hi I have an acer laptop travel mate , before it was operating well but now it switches of by its self even if the battery is fully charged and when its on power what could be the problem?
switching off by itself could be a sign that it is overheating or over heated and urned itself out. Are the fans clear? were the vents blocked by a thigh, blanket or loose papers underneath?
Feb 26, 2011 | Computers & Internet
I just bought an HP mini 210 - 2080 and its keeps on turning off by itself.Sometimes it goes on but then it switches off again and again!
Try logging in safe-mode and see if it switches its self off.
To log on in safe mode, power the laptop on and keep pressing F8, choose safe mode using the arrow buttons, continue to log on. when you successfully log on, leave the laptop for some time to see if it will switch itself off, if it does switch itself off, then definitely, that will be a hardware related problem.
if it does not, then that's a virus causing it, email on xrojer2005@yahoo.com to solve the software related problem.
Jan 07, 2011 | Computers & Internet
My Gateway P-7805U Laptop will not stay turned off. Every time I do a shutdown the computer turns itself back on within 10-15 minutes.
All laptop has a small push switch near the hinges between the LCD to the base.
Make sure this switch is operating smoothly.
A malfunction or loose switch will not trigger the correct condition to the laptop.
Jul 08, 2010 | Gateway Computers & Internet
Fujitsu siemens notebook s6120 laptop switching itself off
the processor fan might not be working due to which the laptop gets heated up and switches off. if u dont replace it u might end up burning the processor.
May 17, 2009 | Fujitsu Siemens LIFEBOOK S-6120 PC...
Laptop switches off and doesn't switch on again.
your battery has become weak. you need to change the battery. If the issue persist, you need to service your laptop.
Dec 27, 2008 | Dell Latitude D630 Notebook
Acer Aspire 5315 Notebook Logo
57 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
