Question about ViewSonic VG150 15" LCD Monitor
MY MONITOR HAS A RED LINE IN THE MIDDLE OF THE SCREEN FROM TOP TO BOTTOM WHAT CAN I DO?
  • 11,361 Answers
You can try resting the connector between the T-CON board on the LCD panel to see it will fix the problem, but more likely to have bad LCD panel due to bad TFT driving circuits.
Failed TV and Monitors: http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Posted on Sep 03, 2010
My lg m2762d lcd tv has a half millimeter white line across the screen can you tell me whats wrong?
makes a difference where this line is... very top, top, middle, bottom, very bottom? also, is this set new to you, or has it been fine for a while, and just started doing this? does the line stay there when you switch to other inputs? (like a dvd player or a gaming console)? this kinda stuff will help you get an answer that makes sense - good luck
Dec 11, 2010 | LG W2753V PF Flat Panel 27" LCD monitor
Thin red lines have appeared on my samsung 42" plasma tv screen, I've taken it to a reapir guy who said the bottom board had gone and the top board was on its way out he wanted to charge £290.00 to...
There is no term called top/bottom borad in monitor. Lines might have caused becoz of capacitor problem in ur monitor. replacing capacitors will not cost much. try taking ur monitor to someother person
Oct 26, 2010 | Computers & Internet
A red line in the middle of screen
I have seen this many times . most people would said video card but for a fact i use a monitor with 3 red lines down the screen for a test monitor . the monitor has failed .
May 17, 2010 | Computers & Internet
I have green and red running top to bottom on screen
Red and Green Lines on the screen could be graphic card or the screen itself. Try and external monitor and see if you see line there. Yes graphic card No Screen
Nov 26, 2009 | Toshiba Satellite M35X-S111 Notebook
The screen is blurry on the top, bottom and sides, but the middle is somewhat clear. how can i fix it? thank you for your time!
open the monitor a black EHT will found see the preset set it by screw driver on line see result on the screen the name on preset is FOCUS
Nov 13, 2009 | IBM E74 Monitor
Thin red line in middle of screen on nec 42 inch plasma monitor
I had the same problem -red, vertical bars along the right side of my Samsung 42" Plasma- and this is what fixed it: Removed unterminated cable.
I had hooked up an HD video camera to the set about two weeks ago. While I disconnected the camera I left the other end of the connector cable plugged into the T.V.. As I've since learned from friends who work in television, this is what's called an "unterminated cable" -meaning one end is unconnected. It can lead to problems with electrical interference and appears to have been the problem in this case; When I disconnected this cable from the T.V. the red bars went away.
So, check your cables. Make sure everything is properly connected and get rid of anything that might be picking up interference.
Dec 27, 2008 | NEC PlasmaSync 42PD3 42" Monitor
Red line
The display cable in your LCD monitor must be replaced.
If you are feeling adventourous then you can look on ebay for a display cable to install but I do not suggest anyone open up a monitor (LCD or CRT) who is not "technically inclined."
If you can get the part then I would take it to a local Tech to replace it.
Mar 14, 2008 | Acer AL1916W 19" LCD Monitor
Black Line in middle of screen
Are you able to test this monitor on another pc? This will allow us to eliminate or identify as problem with the graphics card. With the monitor itself, these lines could indicate screen damage - has the screen been dropped or accidentally hit with a pen etc.. ?
Aug 21, 2007 | Dell E171FP 17" Flat Panel LCD Monitor
ViewSonic VG150 15" LCD Monitor Logo
182 people viewed this question
Top ViewSonic Computers & Internet Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you a ViewSonic Computer and Internet Expert? Answer questions, earn points and help others
