Looking for owners manual on a Jensen TV-611 Powered Antenna RCA 36" TV F36674ET RCA ANT200B Powered Antenna
  • 1030 Answers
SOURCE: OWNERS MANUAL FOR RCA
owners manuals or user guides are availble online at rca.com
Posted on Jan 18, 2008
SOURCE: locateowners manual/program codes for tv remote
Codes for Zenith T.V are 1000,1001,1004,1083,1101,1100,1099,1097,1089,1078,1022,1020,1011,1009
Posted on Jan 14, 2009
  • 360 Answers
SOURCE: Lost Owner's Manual
click this link to download your owners manual -->click here<--
Please take the time to give this solution a "Fix Ya" rating.
Thanks for using Fix Ya
Posted on Jan 31, 2009
  • 3 Answers
SOURCE: Need a smart antenna to go with the Digital TV converter box
First, you don't need a Smart Antenna, the manual is simply stating that your converter will use one if you have it. Any standard antenna will work, so there is no need for a coupon to pay for a new one, whether indoor or outdoor depending on your location and distance from each channel transmission tower. Since you don't give details of what antenna you are using, I will assume you have rabbit ears for each converter. Rabbit ears are notorious for poor reception and any metal or persons nearby will change the reception quality. I would recommend a roof mounted external antenna with splitters for the 3 converters if you have the option. If not, use an amplified internal antenna and mount it closest to the channel towers you will watch most and as high as possible. If you can find a smart antenna, which is an amplified indoor/outdoor antenna with a control cable for changing the direction of reception, for a decent price, you can use that but keep in mind that to use the control feature you will need one for each converter. Also, check antennaweb.org for information on digital channels in your area and their direction and distance. Antennaweb.org will also tell you if any digital channel in your area uses VHF frequencies. If they don't then a UHF only antenna will work fine.
Posted on Feb 18, 2009
  • 718 Answers
SOURCE: Toshiba 36
I understand you have;
Toshiba 36" analog tv,
Tivax converter box,
RCA Digital Flat amplified antenna.
You want to get signal over the air;
Connect the antenna to the Tivax converter box.
Connect the Tivax Converter box to the input for the TV.
Turn on the antenna, Converter box and TV. You should get a menu on the tv screen. Follow the instructions and SCAN in the channels in your area by using the converter box remote.
You can see your channels by going to www.tvfool.com and entering your information.
Posted on Mar 05, 2009
My Tv has sound but no picture. It is 12 years
may your picture tube in bad condition or no filament voltage
Feb 25, 2010 | RCA F36674ET 36" TV
Toshiba 36" analog TV Tivax converter box RCA Digital Flat Amplified Antenna How do I get signals without cable?
Mar 01, 2009 | Vizio L32 32 in. LCD HDTV
Rca f36676et manual
servicemanuals.net on web.
Dec 09, 2008 | RCA F36676ET 36" TV
RCA 36 inch ---channels keep changing
Mine did this and I took the back off of it to remove the button panel on top of the tv. It un- snaps from the inside and pulls straight out. My channel down button was messed up but it lookd fine. It has three prongs on one side of it and two on the other. I clipped the two prong side of the switch and put it back together. Works fine now with remote. Be careful as the set picture tube holds high voltage for a long time when unpluged. Unplug overnight and then work on it.
Jul 21, 2008 | RCA F36674ET 36" TV
Rca 36" tv
are you on outside antenna or cable? does vcr or dvd do the same?
sounds like tunner in dvd or vcr works.
Dec 03, 2007 | RCA F36650 36" TV
RCA F36674ET - Only beeps when turned on
Clearly shows problem in deflection area both horizontal and vertical section. Horizontal lines is due to vertical section problem and making bbzzzz is due to horizontal output transistor short and sometimes LOT SHORT.
Aug 23, 2007 | RCA F36668 36" TV
Locateowners manual/program codes for tv remote
Jun 07, 2007 | Jensen JER-822 Remote Control
My Television makes a weird noise.
hi....maybe theres a problem with your high voltage(flyback)section.or maybe there are still moist inside your tv...try to open it(if you can) and use your hair dryer to dry it....if noise still present after you done it....call the serviceman
Apr 24, 2007 | RCA F36668 36" TV
Televison & Video Logo
240 people viewed this question
Top Televison & Video Experts
