Question about XO Vision GX1211 XOVision 12" Roof Mount TFT LCD Monitor
My car stops on motion
My Car Honda Accord '94 model stops while on motion, it does it stop while stationary, neither does it **** before it stops, at top speed, the engine just switches off itself, and as sson as I bring it to a stop and restart the engine it starts up again and continue running as if nothing happened.
It has gotten so frequent now that it's just embarassing on the road. I have changed the fuel pump, removed all the security and yet the problem still persist!
Please help.
  • Sharafudeen PM
    Sharafudeen PM Jun 20, 2008
    I have Ford Ikon 1.3exi petrol. The car frequently stops abruptly especially
    while downing the gear or in turning. This is dangerous since power steering. Earlier due to same problem I had changed 3 coils going to the spark plug. Please help me out immediately.
It my be your distributor had a similar problem it would die out at every complete stop or spark plugs
Posted on Apr 15, 2009
  • 1,224 Answers
Several things it could be
alternator replacement
relay is bad
computer going bad
over heat saftey feature thats killing the power so you dont crack your block
make sure your fan is running and hook power to fan direct to an power fuse this is when you turn the key to on the fan starts running you can also add a toggle switch to cooling fan so when in accessory it wont run down battery
your vehicle is equipeted with an electric cooling fan if this shuts off your vehicle over heats and shuts off
this ensures vehicle is always running cool
Posted on May 12, 2008
My 1997 Honda Accord makes a grinding noise when in motion. When I press on the brakes it stops, when I release the brakes it starts again. The grinding noise continues pretty consistantly when in motion,...
Sounds like a bad wheel hub. Or it could be just the brakes. Can you tell which corner it is coming from? Can you jack up that corner and spin the wheel? Wheel hub job about $400 brakes about $200 or less. Good luck
Oct 22, 2017 | 1997 Honda Accord
94 honda accord wont start and d4 light is flashing constant. It's cranking but it wont turn over.
my 94 honda the check engine light comes on then the d4 light flashes i can turn off the key and it stops for a minute
Apr 22, 2010 | 1994 Honda Accord
My speedometer stop working.94 Honda accord LE
you may need to replace the speed-o-cable give these websites a try and if all fails stop by your local library and get your hands on a Haynes auto repair manual for you car wish you the best of luck Michigan Man.
Nov 04, 2009 | 1994 Honda Accord
My honda accord 94 the stop light it on all time with car on/off
Brake light switch at fault, located at your brake pedal.
Aug 08, 2009 | 1994 Honda Accord
94 Honda Accord with stopped mile counter
You will need to pull the speedometer out and have the odometer (u call mileage counter) repaired, the little drive gear that comes off the speedometer to operate the odometer has failed or broken.
Apr 27, 2009 | 1994 Honda Accord
Honda stationary engine hunting 5HP
The IAC, (Intake Air Control valve) is a rotary valve that binds with carbon build up. the valve is usually on the bottom of the throttle body, has two small coolant hoses going to it.
Apr 07, 2009 | 2001 Honda Accord
Honda Accord EX 94 vss has been replaced, but still nothing work
If all the connection and power supplies to instrument cluster are ok,I suspect that the speedometer or instrument cluster is faulty but before you replace it, make sure the gear inside the transmission that drives the VSS is in good.
Mar 12, 2009 | 1994 Honda Accord
Car Audio & Video Logo
151 people viewed this question
Top XO Vision Car Audio & Video Experts
Are you a XO Vision Car Audio and Video Expert? Answer questions, earn points and help others
