Question about Quartet gbc Office Equipment & Supplies
I have a GBC 60s shredder adf it is not working. When plugged in I can hear the sound of the motor but it doesn't accept the sheet of paper and commence rotating and shredding.Can this be fixed?
SOURCE: GBC Quartet Shredder - Service manual
try this customer service number for help 800-541-0094. I believe that Acco is the parent company for GBC.
Posted on Jul 30, 2007
SOURCE: Shredder won't shred any more.
You might have broken the actual mechanism enabling it to move forward. To be honest, your easiest solution would be to buy another shredder rather than attempt repair if this is the case, they're so cheap now.
Posted on Mar 27, 2008
  • 3 Answers
SOURCE: How to fix a stuck shredder
get a pair of needle nose pliers and pull the jammed paper out. (you may need to figure out how to pop off the top cover to get better access to the blades)
Posted on May 27, 2009
FixinFax
  • 3085 Answers
SOURCE: Staples SPL-X21G shredder won't turn off
Blow canned air down into the feed slot.
Posted on Sep 22, 2009
  • 610 Answers
SOURCE: SHREDDER INDICATOR KEEPS COMING ON WHILE SHREDDING
look for two LED lights where paper falls into bin and wipe them off, but the sensors could be faulty as well. I have seen both.
Posted on Nov 11, 2009
Black and decker shredder will only go in reverse, when you try forward it makes a loud sounding noise and will not take the paper
Shredders require maintenance. They have moving parts that make lots of dust.
Check your user manual. Does it require oil or special oiled sheets? If so, you might be overdue for this maintenance. Also, check the frequency of how often you are supposed to oil/add oiled sheets to it.
If it won't accept paper in the forward position, then you might be out of luck with trying to run oiled sheets thought it. If it's still under warranty, see if they can repair it for you.
Mar 02, 2015 | Black and Decker USA Black & Decker -...
PROBLEM SENSOR PAPER DETECTION
There is a lever inside the shredder that is connected to a micro switch that detects the paper. Its usually located in the center of the opening where you insert the paper. This switch will make a very slight click if you turn the shredder off and insert a sheet of paper at the opening. If you can hear it click and it still doesn't work the motor could be defective.
Feb 19, 2015 | OfficeMax 10-Sheet Micro-Cut Shredder...
Overload light stays on
Most likely the cutters are still stuffed with paper shreds and needs to be dismantled and cleaned
Mar 29, 2014 | Honeywell Seven Sheet Micro Cut Paper...
The shredder doesn't automatically shred anymore. How do I set it so the "eye" works and it shreds automatically without me holding down the button?
Check the Power Ensure that the shredder top is firmly placed in the shredder basket if the unit will not operate. If the top is not in place the feeder will not work and accept any paper. Make sure it is firmly plugged into the wall outlet and that the outlet is active. Rest the Shredder Let the shredder cool down if the shredder has been running continuously for a long time. It may have overheated and needs to be left in the off position for at least 30 minutes to reset. Verify the basket is empty or not too full as that will cause the shredder to deactivate. Clear Paper Jam Rotate the shredder into "Auto" and reverse to loosen any paper jam that is stopping the gears. Pull out any papers that are sticking out from the shredder feeder. If there is no progress then unplug the shredder and remove the shredder top from the bin. Turn it upside down and use tweezers to free any paper that is blocking the gear. Auto Mode Not Working Select the "Auto" option and feed paper into the center of the feeder tray if the shredder is only working in reverse mode. The sensor is located in the middle of the feeder tray and could be blocked by jammed paper. Use an index card to firmly unblock any paper that could be blocking the sensor.
Sep 04, 2013 | Quartet gbc 5550X Shredder
It will not grab the paper; need to press forwared
Try running the shredder in reverse and oiling the blades. More help with paper shredder oil here: http://hubpages.com/hub/Paper-Shredder-Oil
If you can't get the paper shredder up and running, it looks like you might have to pick up a new paper shredder. Paper shredders can be pretty cheap though, great guide to cheap paper shredders here: http://hubpages.com/hub/Best-Paper-Shredders
May 24, 2010 | Quartet gbc Shredmaster 6550X...
GBC Shredmaster 3220S stopped taking paper in and makes a loud,
Myi shredder does the same thing so I removed the screws to see what was going on inside.
What happened is the fan tail that spins when the shredder is in operation and cools the motor had broken off. I got some gorilla glue, adhered the fan back on, then let it dry for 24 hours. Replaced the screws, turned on the shredder on it worked just fine. The loud grinding noise stopped and the shredder worked wonderfully. I am looking for a replacement part because I don't trust whether the glue maintains its hold when the motor heats up after excessive use . Darlene
May 21, 2010 | Quartet gbc 2230S Shredder
I have been using my shredder heavily in the last 30 minutes. I have had to stop twice for it to cool down. It was working fine, and now it won't accept paper. The cutters are turning fine. It is not...
Most shredders don't recommend use for more than 20-25 sheets in a session. Try using the reverse setting; even though you can't see paper, it's possible that there's some still in the feed channel. If after switching to reverse paper comes out, inspect the feed channel for more paper and clear any you find before trying to feed more sheets. Also in the future, constant use as you've described will burn out the motor.
Nov 16, 2009 | Tech Solution TS-4500 Shredder
ROYAL RL170MX Shredder won't shred
Did you ever put shredder oil onto the cutting blades?????
The blades can clog with paper dust and then it can't shred as many papges as it should or even jam completely...you should occasionally shred a sheet of paper with shredder oil poured onto the sheet.
Aug 11, 2009 | Royal 1280MX Shredder
Paper shredder
There is a housing arond the shredding wheels, they get jamed with paer and break the screws holding this guard around the wheels. Not sure on that model if it has those gray plastic guards, and they are available...
Jun 21, 2008 | Office Equipment & Supplies
My shredder stop shredding. has paper caught in it
Shredder drive gear is probably shredded - hard part to find or replace usually. Could mean a new shredder;-(
Aug 29, 2007 | Quartet gbc 6120S Shredder
96 people viewed this question
Top Quartet gbc Office Equipment & Supplies Experts
WTF Chuck.....
WTF Chuck.....
Pie-man
Level 1 Expert
graybeard32301
Are you a Quartet gbc Office Equipment and Supply Expert? Answer questions, earn points and help others
