Question about ASUS Computers & Internet
Hello. When I plug my headphone with mic into the front panel jacks, it does not work. Now if I disconnect my speakers and plug it in the back jacks, it will work. However, the front joacks are there for this same purpose. Can you please help me.
  • 26 Answers
Open up your case.
You should see cables running from the front panel to the motherboard. On the motherboard you will see a multi-pin connector. What is your exact ASUS motherboard model? Here's a generic ASUS one. You will see this on the motherboard where the front panel connects to the board. A bunch of pins will terminate here.
Notice the pin labelled MIC. You will see GND etched on the motherboard. Use this to orient yourself. The Mic one is just below the GND pin. Connect it here. Notice the entire top row is devoted to FP_Audio or Front panel Audio. There are other places to connect it (e.g., if you just want stereo sound, there's a left and right FP_R and FP_L).
Move the mic connector over to the Mic pin if there is one. If not, you can get a cable at your local computer supply shop. As you can tell from the others, they are very basic wires with simple terminals.
Posted on Sep 03, 2010
Not receiving
Hello
I understand this ICON 802 marine radio will not receive.
There are two things to check for. First check the speaker jack on the back side of the receiver also check the speaker plug and the connections. Make sure that the wires are soldered properly. If you have access to an ohm meter connect it to the plug leading to the speaker, it should measure 4-8 ohms. If the speaker checks ok then check the headphone jack on the front panel. The jack has a contact switch internality to disconnect the external speaker whenever a headset is plugged in. You can clean it by using a electronic contact cleaner spray a little into the jack and plug in a headset and turn the plug back and fourth. If this doesn't work, it would be inside the unit itself.
Hope this helps
Bruce
Dec 21, 2013 | Icom Radio Communications
I want to attatch my mic to my motherboard
desktop or laptop computer ?
3 Ports on the side- Pink,Green,Black
Pink Port is LineIn for an external device player jack
Green Port is LineIn for the Microphone jack
Black Port is LineOut for Headset or External Speakers jack
Plug the Green jack on Headphone - into the Black Port on the laptop.
b) Go to Control Panel and open - RealTek HD Audio manager
On the top of Page are 3 Icons -
One Icon is labelled Speakers One is for Digital optics, one is for Mic,
The Speakers Icon is misleading as it is also for Headphones (LineOut)
Select Speaker Icon and make it Default. Also tick Full Range - Front LR
Ignore the 4 vertical Analog Icons on the right side.
You should now have Headphone sound if your volume is not Muted.
click start control panel on the left select hardware and sound then select manage audio devices then recording you should see a microphone right click select enable windows 7
click start control panel on the left select hardware and sound then select manage audio devices then recording you should see a microphone right click select configure speech recognition then
you will see earphones with a speaker among a list set up a microphone headset with microphone then next and next again you should see your earphones with microphone being configured
click start control panel sounds and audio devices select advanced there might be a tick in the mute box untick it or select audio from the microphone drop down list
make sure you have the right one selected and in the volume box make sure the microphone box has a tick in it or
select the voice tab
make sure that you have the right media selected also
select volume make sure the box for microphone has a tick in it
or you might have to depending on your operating system
Click start Control Pannel
click on Hardware and Sound
click on Sound
then you devices should come up ; speakers, Digital Audio, and headphones
plug your headphones in
then select headphones
at the bottom it will say set as default
select that!!
then when you disconnect your headphones it automatically switches to the speakers and when you plug them back in it automatically will switch to headphones
hope this helps
Sep 19, 2012 | Biostar P4M900M7FE Motherboard - VIA...
Using headphones
You can get a set of speakers that has a headphone jack on front (it will shut off the speakers when headphones are in) or you can unplug the speakers and plug in the head phones. Some PCs have a red and green jack in front - plug in headphones to the green, you should have the speakers shut off till you unplug. All else fails they make a headphone/mic extender that sits like a hockey puck on the desk, has cables to the mic and speaker jacks on back of the PC and on the puck part has a jack for speakers, mic and headphone - some switched manually by you, some switch when the headphones plug in. If you had posted the model I could see if your machine has front red and green jacks.
Jun 19, 2010 | E-Machines eMachines Desktop PC
I just installed a Logitech Quickcam. It came with a headset that has 2 plugs, one for mic, one for earpiece but my speakers only have one outlet for headphones. How do I get the mic to work??
On the back of the computer or front there is a GREEN Jack for the earphones and a PINK Jack for the Mike. If you have the speakers plugged into the GREEN jack you will have to pull it out and incert the headphone jack into the GREEN color jack and it should work.
Hope this is of some help. Bud
Jan 12, 2010 | Logitech QuickCam Chat Personal Web Camera
Speakers work with ipod not with laptop
ok you need to plug the speakers into the green jack it is the speaker output jack
Apr 13, 2009 | Creative Labs Inspire T3030 Computer...
Headphone problem
Did you installed all drivers ?
Are there FRONT audio jacks you are trying to connect your headphones/mic ?
Dit it work before ?
First install all (incl. audio) drivers and try to get audio from BACK connectors (Green is speakers/headphones, Pink is Mic.)
If it workson on REAR, but not on FRONT connectors, check if you have another icon for AUDIO settings in Control panel and try to set FRONT audio settings.
Check if FRONT audio connectors are connected to your motherboard.
Regards.
Check
Mar 28, 2009 | Intel Motherboard, G31 Express, Core 2...
First thing, you have plugged in to the wrong point, plug in the speaker to the headphone slot(mostly light green in color).
MIC point is specifically for MIC not speakers.
The point which works for your headphones would work perfectly for speakers.
Mar 15, 2009 | Logitech X-240 Computer Speakers
Headphones with mic / external speakers
Does your computer have front audio ports? If so, you can just plug it in there. Otherwise you need a single male 2 dual female converter to plug into the speaker port.
Jun 21, 2008 | Computers & Internet
Soundcard problem on D530 SFF
Sounds like the audio return wires aren't connected. On the motherboard, there is a sound jack on the back left side of the mobo. The jacks from the front audio panel connects to it. Both the Left and Right channel have an out and an in connector. These send the signal to the headphone jack on the front panel and return the signal to the rear output jack if a headphone is not connected. Look for looe or broken wires. The other spot to check is the front headphone jack. If a headphone plug was pulled out or pulled sideways, it could break the solder joint on the PCB panel or break the shunt feeding the singal to the rear jacks. Hope this helps.
Ron
Apr 13, 2008 | HP Compaq Business d530 PC Desktop
Microphone is not working
1-adjust the overall volume by pressing fn+f 5 hotkeys
2-adjust sliding mixer controls by doubleclicking the speaker icon
3-disconnect the headphone jack to enable check of internel speaker.4-confirm that microphone plug is proper connected to mono mic jack.5-confirm that microphone is selected as recording source in control panel----multimedia and recording level is adjusted.
confirm that sound source is selected in control panel----multimedia
confirm that headphone connector connected in right postion
Jan 24, 2008 | Compaq PC Microphone (Black or Beige)...
Computers & Internet Logo
205 people viewed this question
Top ASUS Computers & Internet Experts
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
