Question about Electrolux Ovens
My friend bought an Electrolux smooth top 30''electric. She has had it two, no family at home so not much cooking but oven went out she called Electrox repairman came out he orderded a part she has been waiting since JULY SO SHE CALLED AND NOW THEY Tell her they no longer make that part. They will refund her but she had rather have her stove. Is there any other ones like this you have delt with??
    Brigadier General:
  • 3,917 Answers
Hi
Please check the bellow link to have a detailed idea regarding your query:-
http://www.repairclinic.com/Range-Stove-Oven-Troubleshooting#Itsstoppedcompletely_electric
Also check this site to contact the customer support of electrolux for further assistance:-
http://www.electroluxappliances.com/support
Please accept the solution if it’s helpful. Do get back to us for any further query.
Thanks for contacting fixya.com
Posted on Sep 03, 2010
Top part of oven not heating up
Thank you for your post, friend!
Based off what you have described your Electrolux double wall oven is not heating up inside the top portion. It could be a miscommunication within your oven and you can usually perform a reset to clear that out. In order to reset your oven you would need to flip the household circuit breaker off for roughly ten minutes. If you restore power and continue you having an issue with your oven I would suggest you could have a possible fault with the control panel, thermostat, element, or connectors. Typically, this is not a simple DIY job. You may need to look for assistance with replacing any electrical components and I would highly suggest having a professional technician help with that. Hope this is helpful. -Matt
Feb 23, 2015 | Electrolux 30" Built-In Double Electric...
Why my ew30ew55gs5 have no heat and all the light and function work.
Electrolux Customer Phone Number Shortest Wait Best Support
  • Talk to a Human Press 2 then 1. For kitchen and laundry appliances
  • Call Time
    Average Wait: 37 mins - Monday-Saturday, 8AM-9PM (EST)
Electrolux Calls You Instead Electrolux Calls You Instead
I would contact them first before you waste any money.
Jan 21, 2015 | Electrolux 30" Built-In Single Electric...
How to address F14 code? Convection oven does not start.
Hey friend, thanks for your post!
I see that your Electrolux wall oven is displaying an "F14" error code. "F14" stands for display tail missing, which means you could have an issue within your main control board or keypad. I would perform a reset on your appliance which can be done by flipping your household circuit breaker off for roughly ten minutes. If that does not correct the issue I would suggest seeking a professional to come out properly diagnose and repair your appliance. I hope this is helpful. -Matt
Aug 31, 2014 | Electrolux ICON Designer E30EW75GSS 30"...
Diagram electrolux
From my understanding you are searching for a diagram of your Electrolux range. I have located the manuals and diagrams for your appliance. I hope this helps. -Matt
Frigidaire Manual Search Results
Aug 19, 2014 | Frigidaire 30" Self-Cleaning Freestanding...
Electrolux oven racks how do they go in oven?
Hi Friend, that's a great question!
I see that your post is listed under Electrolux Wall-Oven. May I have your model number please? You can normally find the serial tag (which lists your model number) on the front of the oven, on the left side, as you open the door. With this material I can provide you the correct instructions on how to place the racks in your Electrolux wall-oven. Thank you! - Z
Jul 20, 2014 | Electrolux 30" Built-In Double Electric...
Electrolux EOU5330X Ultrafan Electric Double Oven -
Sounds to me like the lower element shorted and tripped the breaker as it burned out. If you're handy at electrical troubleshooting that's where I'd start - comparing ohmmeter readings between the bad element and the one that works.
A wire short to the chassis would have a similar set of symptoms and be easier to find and fix.
Beyond that, you need a service tech.
Sep 03, 2017 | Electrolux EOU5330X Ultrafan Electric...
Electrolux 30" electric double oven
Some oven elements are "plug-in" style, held in place with spring clips, It is possible that they have dislodged during cleaning. Good luck, Rob
Dec 31, 2010 | Ovens
BOUGHT A HOME IN UNION NJ WITH THE GE DOUBLE WALL OVEN TOP PART DOES NOT WORK BOTTOM PART BURNS THE FOOD NEED REPAIR PLS CALL ME AT 908-391-8942
The heating element in top unit may be loose or burned out. Push the element toward the back and see if it engages. If it is already engaged, you'll need to replace it. It is simple to remove it.Just give a firm tug and it should come right out. To replace with a new element, simply push it in firmly.
With the bottom unit, are controls set for bake? If they are set for "broil" you are using direct heat and it will cook foods more quickly.Also, is bottom unit a convection oven? If so, foods will cook in 1/4 to 1/2 the time for a conventional oven, so you'll have to adjust your temperature down about 25-50 degrees and shorten your cooking time.
Nov 01, 2010 | GE Built-In 24" Double Electric Wall Oven
Using both ovens at the same time
Both ovens should be able to be used at the same time. Most likely problem is the control board or user interface. The oven should have a 1yr. warranty. Call your local authorized servicer but first please rate this post.
Dec 14, 2009 | Electrolux 30" Built-In Double Electric...
Glass
glass is glass. wouldn't say its normal but not an unheard of complaint, YOu purchased an ICON, id call the manufacture, wouldnt be suprised if htey took care of that for you! thats their pride and joy!!!!!
Feb 27, 2008 | Electrolux ICON 30 in. Double Wall Oven
Ovens Logo
Top Electrolux Ovens Experts
ashburton
Mack Baxter
Are you an Electrolux Oven Expert? Answer questions, earn points and help others
