Question about Keurig Elite B40 Coffee Maker
The handle on my Keurig is stuck 1/2 closed ,1/2 open. won't release.
Keurig handle wont raise or lower it is stuck in the halfway position
Check for obstructions behind the machine, in the area behind the handle and in the area behind the kcup holder. Ensure that the kcup holder is inserted correctly, aligning the arrows at the top. Be careful of the needles!
Apr 06, 2014 | Keurig Elite B40 Coffee Maker
Drivers side sliding door won't close
check mechanism on working doors. In my car if I move the catch on the door(click it like in closed position)like it was closed,then when I open the handle it releases open;this shows me closing/opening. Spray penetrating fluid on the metal/mechanism,possibly rusty and prevents smooth actions. Hope this helps.
Jan 01, 2014 | 2004 Nissan Quest
Keurig will not open & close
Misalignment requires lifting the handle and reestablishing proper contact.
Nov 14, 2012 | Keurig Platinum B70 Coffee Maker
My Keurig is stuck. The top of the handle won't go in :( it won't close. Stuck open.
Remove the Kcup basket and clean. Rest and strat over. Pull down and reset handle.
Jan 21, 2012 | Keurig Elite B40 Coffee Maker
I just installed a Sears Craftsman 1/2 HP Garage Door opener. As I was doing the adjustment to keep the door closed, it closed too tight. I disengaged and confirmed the door arm was set wrong so I fixed...
Use the emergency release handle to release the door. Run the opener to the open position until it stops. Close the door until it stops. Now re engage the the door.
May 04, 2017 | Sears Genie Garage Door Gpwk12 Wireless...
Volvo xc90 rear hatch door closed and won't open
Hold the hatch hard closed into its frame whilst pulling on the release handle. The mechanism on most cars consists a grab/release on the door and a simple metal hop at the bottom of the frame. Over time the hoop can become loose and move slightly inwards each time the door is shut. The door seal rubbers push back on the door surround putting a lot of tension against the grab/release mechanism preventing it from releasing. By pressing on the door and compressing the rubber surround you will take the pressure off the release mechanism and allow it to open when you pull on the handle. Once the door hatch is open, loosen the mounting bolts to the metal hoop and move it out about 10mm. Tighten the mounting bolts. Shut the door gently as a trial close and check for security of fit. If very slack, ease the hoop inwards a couple of millimetres. When happy, tighten the mounting bolts securely. draw around the hoop mount with indelible ink so if it moves in future you have early visual warning and can remount it easily
Jul 13, 2010 | 2004 Volvo XC90
Hatch back will not open
With key in hand,hit power door lock switch to lock. Raise release handle & lower. Hit power door lock unlock raise & lower handle. May take a couple times is stuck in limbo between lock & unlock mode.
Jun 07, 2010 | 2001 Volvo V70
The hood release handle is stuck out and won't spring back on my 99 ford escort. The hood is closed and latched. Any help would be appreciated
you probably have to open up the hood latch assembly and replace the sring. sounds like it broke. or maybe the cable. can you push it back in?
Feb 25, 2010 | 1997 Ford Explorer AWD
Tailgate
I have a 2002 Chevy 3500 and the same thing happened to me. It turns out the latching mechanism on the left side would not release when I pulled on the latch handle. I stuck a small screwdriver in there to release the latch handle (as I pulled on the latch handle) and it popped open. I then squirted some WD-40 on that latch mechanism because it was hung up. I didn't have any problems after that.
Jun 28, 2008 | 2002 GMC Sierra
Keurig Elite B40 Coffee Maker Logo
148 people viewed this question
Top Keurig Coffee Makers & Espresso Machines Experts
Lisa
Lisa
Jason
Oloyede Monsuru
Are you a Keurig Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
