Question about Mercury P4VM800M7 Motherboard
I load windows xp service park 2 but after loading the files, on rebooting the machines it brings hard disk error. and i have change all the hard disks
  • 26 Answers
Http://www.hiren.info/downloads/freeware-tools/1
Try the disk digger and run Hiren's Boot CD on startup to check your disk for errors. Installing SP2 isn't something that should cause a massive HDD failure.
Posted on Sep 03, 2010
I am unable to get windows xp to load onto my ASUS A2500H anymore. Everything was working fine for a long time, even with an external HDD attached until today. All of a sudden the laptop died and when...
The best you can try is to remove the external HDD and see if computer boots..
If it does, you know where the problem is..
If it doenst, reboot computer, start tapping F8, if you get advance boot options, try to boot computer with Save Mode, Perform system restore from save mode.
If the above doesnt work, you need to perform repair installtion of Windows XP.
Apr 11, 2011 | Computers & Internet
When i power on the laptop it says "please install windows in your hard disk " but when i reboot it 5-6 times it loads the windoes automaticaaly . please help
Hi, This problem usually occurs when your HDD or your Hard Disk Drive is showing signs of bad sector. I would suggest that you run this command in Command prompt to check the integrity of your file system. its not loading normally because it is sensing from problems with the files. > click start > run > cmd > hit enter.. on command line type "sfc /scannow" after hitting enter you will see a progress bar. Any corrupt, missing or incorrect files would be replaced by this process. If this option doesn't work, you could try to run a checkdisk to see if there is a bad sector in the hard drive. heres how:
  • go to my computer
  • right-click local disk c: and choose properties
  • go to tools tab
  • then click error checking
  • a box will appear and you have 2 choices
  1. Automatically Fix file system errors
  2. Scan for and attempt recovery of bad sectors check boxes
After clicking on start a window will appear telling you that you need to restart the computer to run the Check Disk before loading windows to check the windows file. click yes and then wait for the reboot and check disk to start.
It may be a long process but it will definitely inform you what is wrong with your computer.
Hope this would help you.
Cheers!!
Aug 12, 2010 | Computers & Internet
WINDOWS XP WON'T LOAD TO HARD DRIVE
1) If you are trying to install from a bootable disk and trying to make a fresh install, you will not come across this error.
2) If you are trying to repair the existing installation, you might need to use FIXBOOT command and try. Please refer the below link before you try this.
http://support.microsoft.com/kb/314058
Apr 21, 2009 | Computers & Internet
Can't install OEM Windows XP on fresh hard disk
please check the consistancy of hard drive or try to run a zero format first and then reinstall the win
Apr 15, 2009 | Computers & Internet
Installing windows
1. Windows 2000 / XP maximum hard drive size 137 gigabyte limit
This one was fun. To install a hard drive larger than 137 gigabytes on your computer you need the following:
a motherboard, such as the Gigabyte GA-7N400 Pro2 which support the 48 bit hard drive addressing. Only new motherboards can be counted on to support this.
Windows 2000 service pack 3 or later. Windows XP service pack 1 and greater have this support built in. I assume this isn't a problem with Linux at all...
Shalom
Aug 25, 2008 | Maxtor Hard Drive
Game guard dump_wmimmc.sys
Cloaked Malware. The Process is packed and/or encrypted using a software packing process. DUMP_WMIMMC.SYS has been the subject of the following behavior:
Created as a new Background Service on the machine
Loaded and Executed as a System Driver File
Deleted as a process from disk
Created as a process on disk
This file I believe it is from GameGuard, Nprotect.
Aug 20, 2008 | Computers & Internet
Blue screen error
When you connect the drive on another machine make sure the jumber setting are either connected correctly as a slave or if using cable select option make sure the jumpers are correct and its on the first slot for the slave.
i am saying so because if it is detected on your computer, thats is why it allow you to load XP up to where you get stuck.
If you cannot manage to get it connected as a slve on the other machine, try connecting it as a single drive on that machine and load XP on it, if it manage to load then transfer it back to your machine when it start rebooting so that it will reboot after copynig files on your original machine.
If it then cannot continue loading on your machine, we will then be certain that the problem is not with your hard drive but just a hardware conflict on your computer, Try that before we pick it fro there.
Mar 25, 2008 | Samsung (SP0822N) 80 GB Hard Drive
FACTORY TV CARD PROGRAM AND DRIVERS WON'T LOAD
sir try copying all the files in the installation disk to your hard drive then run the installation in where you copy your file... probably just a read disk error... if you have successfully copied all the files means disk is still working... if you get an error chances are the installation disk is damaged or your disk drive have a problem.
Jan 20, 2008 | NEC VALUESTAR T (VT900/8D) PC Desktop
Hard Drive Unknown Size Issue!
What type of system is this?
is the H.D. SATA or IDE?
What OS? XP, 2000, ect...
Have you checked the CMOS Settings... hitting delete or F2 ect...
Start here....
IF XP Right click on My Computer Click Manage, Click Disk Mamagement.. This should show you Fat and Health....
Jan 07, 2008 | Western Digital Caviar SE 120 GB Hard...
Start up problems
it fails to boot-? does it just sit there, or does it reboot continuously? Do you have the os cd for it- you might need it to do a recovery mode and run chkdsk /r that might fix the file error
Dec 02, 2007 | Compaq Presario R3000 Notebook
Mercury P4VM800M7 Motherboard Logo
49 people viewed this question
Top Mercury Computers & Internet Experts
Abhinandan  Patil
Abhinandan Patil
vsri9
Computer Links
Are you a Mercury Computer and Internet Expert? Answer questions, earn points and help others
