Question about Sharp AR-M350U Copier
Our machine is a Sharp AR-M55OU and it is giving us the error CE-02 when we try to scan. What does that mean?
I believe the CE-02 is a generic network error.I had the same issue, with us it was a DNS issue. We had old computer accounts in DNS confusing the scanner when using hostname. Have your network admin scrub DNS and see if it solves it.
Posted on Feb 21, 2011
I have a Sharp AR-M550N; It's giving me a code Network error CE -02? How can i solve that error?
CE 02 is rarely a machine problem, It normally is an addressing problem between the machine and the network. That code indicates a communication problem, normally relating to scanning.
Often times it is a wrong character in an address.
Feb 01, 2011 | Sharp AR-M550N Copier
What is Network error (CE 02) thank you
Network Error CE-02 - this is where the machine cannot communicate with the SMTP Gateway / Mail Server for scanning. Check that you have a connection with the network and that you have the correct SMTP I.P address.
If you are using a host name for the mail server make sure that you have configured the DNS entries correctly.
Hope this helps.
Feb 01, 2011 | Sharp AR-M455N Copier
Sharp AR-BC260 shows the network error CE-02
You need the Sharpdesk Software CD and you will have to install it in order for the scanning function to work.
Feb 03, 2010 | Sharp AR-BC260 Color Copier
Network error CE-02
You didn't tell me enough about the problem. Are you trying to scan from a PC or to a PC? The problem is that the network address changed when you moved the printer. You can fix this by correcting the network address
Nov 23, 2009 | Sharp AR-M162 All-In-One Laser Printer
Getting a CE-02 error when trying to scan.
1) Check that the Network Cable is
inserted properly.
2) Check that the connected network
supports TCP/IP protocol.
3) Check from the Web Page that the
Primary/Secondary E-mail Server
Address or the Destination FTP server/
Desktop PC address are properly set.
4) If the above address is described with
Hostname, check that the DNS server
is properly set.
5) Check that the SMTP server/FTP
server/NST causes a trouble or not.
Jun 10, 2009 | Sharp AR-275 Copier
I have an AR-M207 machine scanning error msg
Is it possible to ping top this machine? My i.t tech just whispered into my ear and said perhaps the machine can't scan perhaps because the authentication name/password (login name/paddword of your pc) has changed, so the copier doesnt have the permission to write information directly to your computer.
Jun 08, 2009 | Sharp AR-M207E Black and White Copier
Error code CE-02 when in the scan mode.
the FTP server cannot be found. This is a network error. If it is connected to a network, check with your IT person to set up the FTP server.
Apr 13, 2009 | Sharp AR-M455N Copier
Network Error code CE-02
the ce-02 code is just a communication error it general in nature so you could have a couple different issues going on
Apr 09, 2009 | Sharp AR-168D Black and White Copier
CE-02 error code when scanning on SHARP MX-M550U copier
ce error means not hooked up property to your email server
Feb 12, 2009 | Office Equipment & Supplies
Network Error on display
Have you setup your smtp address on the machine? From any workstation in the same network open your web browser. Key in the IP address of the mfp copier. Goes to network setup and key-in your smtp address.
Sep 14, 2007 | Sharp AR-M277 Black and White Copier
Sharp AR-M350U Copier Logo
521 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
CheckitRight
CheckitRight
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
