Installation manual for a bryant plus 80 furnace
4 Suggested Answers
panilling9
  • 284 Answers
SOURCE: Filter for Bryant plus 90i
Bryant Furnace Filters www.iaqsource.com Every Bryant filter in stock For every Bryant furnace and AC
may want to check on the filter itself and the housing for numbers that could assist its type and size
this site may help you
Posted on Jul 04, 2009
heavyt15
  • 91 Answers
SOURCE: I have a Bryant Plus 90i furnace and a Bryant2.5 A/C
go mid.range....cfm dont go to hi spd or no cooling pick up
Posted on Aug 18, 2009
flatech
  • 111 Answers
SOURCE: bryant programmable thermostat will switch on furnace
Turn the power off to the Air handler unit.
Remove the thermostat from the wall, (Just the face part).
Look on the back side of the thermostat and verify that the jumpers are set to electric and not gas, otherwise the fan will not run during heat mode, they come from the factory usually set for gas.
If this is a electric heater this will solve your problem, If it is gas then it will be more detailed. Once you put it back on keep in mind that most thermostats have a 3-5 minute delay so just give it a little time and the fan should then work once you have the jumpers in the correct position.
FlaTech
Thank you for using FixYa!
Posted on Nov 17, 2009
Bryant plus 80 furnace no fan/ operation , yellow constant flashing light code , power to furnace was rerouted during remodel and since then furnace stopped working. Any suggestions ?
You need to have/ know the "fault code" chart for that specific furnace. Count the number of flashes and refer to chart. Look on the inside of the furnace blower door or other panel. Also look up on internet and print it off. If the furnace was allowed to run during the remodel it voids the warranty automatically. Read the installation manual.
Try resetting the electronic board by turning the power off then back on.
Mar 29, 2017 | Bryant Heating & Cooling
Furnace Bryant plus 80 keeps failing intermittently to restart. Light indicator flashing code 3 which states pressure switch stuck open. Where is that so I can replace it.
You could also clean the flame sensor .Look for a black sort of box or it may be round should be near the combustion fan.
Dec 14, 2016 | Heating & Cooling
Bryant Plus 90 furnace
possible your supply duct leak or break
Feb 11, 2014 | Heating & Cooling
Why is my furnace filter dirty after 3 days
depends on what you are calling dirty which is relative to each person
Are they so dirty they are clogged or do they just have dust on them
IF they are just dusty then that is normal and it is being pulled from inside the house
If you have a pet door that will cause a lot of dust
The only other way is if there is a hole in the attic or your return air somewhere
Feb 26, 2013 | Bryant Gas Furnace Legacy-310AAV Plus 80...
Bryant plus 80 heat exchager is cracked, i'm looking for a replacement heat exchanger
Hate to tell you but heat exchangers are hard to match up. Unless it is relatively new then in most cases they have a warranty of 10 years. So you will have to replace furnace. You might be able to find a used furnace or go to web site and enter model number of your Bryant to get replacement.
Oct 23, 2010 | Heating & Cooling
Bryant Plus 90i furnace vibration
You have not mentioned if the vent pipe has any anti-vibration mounts or not. If not, use rubber mounts to suspend the vent. It may be transmitting your noise.
Mar 11, 2010 | Heating & Cooling
Aug 18, 2009 | Bryant Heating & Cooling
Jul 04, 2009 | Goodman CLJ30AR32 Air Conditioner
Heating & Cooling Logo
506 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
