Question about Siemens Washing Machines
WXL142GB/08 Washing machine Spin cycle not working, cycle get down to 11mins and then skips to 1min I have cleaned all external drainage pipes and check that the filter isnt blocked.
  • 5 Answers
SOURCE: cloged inlet filter
You can also buy new filters to replace the old inlet filters from Home Depot. They are not LG brand they are "generic" filters but they do work. LG does not supply these filters the only way to get them from LG is to purchase the entire inlet valve (keep in mind you have 2 hot and cold) to obtain these filters. You can call the parts dept 888-393-6484 and get the part numbers for these valves and a distributors phone number so you can purchase the valves from them. Hope this helps.
Posted on Jun 06, 2008
57 varieties
  • 1653 Answers
SOURCE: Bosch Nexxt 700 won't drain water
Do the following.
  1. Switch off the machine and disconnect the mains power.
  2. Remove the access panel on the lower right front of the machine.
3. Remove the filter and make sure that the filter is not blocked and is clean and clear of all debris. Clean as required. Note that depending on the machine type you may get a lot of water coming out of the filter when you remove it if the machine has not drained successfully. Note that if the machine has stopped and not fully drained then you may be able to drain out the excess water by removing or disconnecting the waste hose and laying it on the ground in a tray. It may take a few minutes to empty but it will save a small flood.
4. Proceed by checking the drain hose for proper connection and kinks and make sure that it is not blocked.
5. Also check that the main waste drain pipe, if you use one, is not blocked and clean if required.
6. Reconnect the power and switch the machine on.
If the problem persists then do the following.
7. Switch off the machine and disconnect the mains power.
8. Check the electrical connections at the pump and make sure it is operational.
9. Remove the connecting hoses, and expect water to drain out and make sure the pipes are not blocked with debris or any object blockage.
10. Makes sure the pump appears clear and that the impeller looks in good condition.
11. Reconnect the hoses and then reconnect power and switch the machine on.
12. If problem has not been corrected, then remove the pump and check that the drive coupling to the motor is OK and that the motor turns OK. If all is well then replace the pump.
Posted on Oct 23, 2009
  • 5 Answers
SOURCE: AEG 74630 washing Machine stopped working, will
I have same problem right now. The machine works fine up to the stage where it needs to pump out. the pump was dead. Have replaced the pump, but still not working and it's probably the PCB that needs replacing - expensive but will buy reconditioned for about £50.
Pump available for the machine on Ebay and easy to replace. Take of machine back panel - make sure machine off and unplugged. Pump has 3 screws holding it in - then just replace. Easy. Good luck
Posted on Jan 21, 2010
  • 82 Answers
SOURCE: water back up from washing machine drainage pipe.
Do you own a snake? If not, you can get one at any hardware store in your area. Tell the guy at the store your problem; you can buy a cheap one for about 10-15 bucks. Simply fix, pull the washing machine drain hose out of the drain and put the snake down. Much cheaper than calling a plumber to do it (would cost around 100 bucks) Good luck
Posted on Feb 20, 2010
  • 713 Answers
SOURCE: MACHINE MAKES DOES NOT WASH,WATER OUT FROM DRAINAGE PIPE
is it a top or front loader?is your drain hose same level as top of machine?if not ,raise hose to level and start cycle.machine will not wash if it does not fill.please reply if u need more help
Posted on Apr 10, 2010
Another AEG e20 Plea, tried everything please help!
E20 on your machine means some sort of drain problem. If it actually goes through the spin cycle fine; some water will still not drain out at the time of the tumble dry. Check the wall drain to make sure it isn't clogged..
Check the drain of your wall, not the washer, this shd be cleaned out thoroughly; and the exit pipe of your washer should not fit too tight into it, there shd be some space for air.
This is a further tip, if helped click helped.
Apr 10, 2013 | Washing Machines
Spin light is flashing 1min left in cycle door
Take the bottom panel off. The tech sheet is right there. While at it clean out the pump filter.
Interesting home videos
Apr 08, 2011 | Whirlpool Duet GHW9150P Front Load Washer
My washing machine isn't spinning clothes out all the way anymore... I have to run spin cycle twice to get water all out.
Hiya,
often when the machine needs to be put on spin twice to remove the water you will find the is an issue with the drainige, if the waist pip is pushed to far down the drainage or if you have lint build up it will greatly reduce the amount of water that can be released when spinning leaving it in your machine so i would surgest checking you drainage & pipes first to make sure they are clear enough for the water to escape
Hope this helps
Apr 23, 2010 | Maytag PAV2300 Top Load Washer
Simpson Aquarius washing machine 7kg: water
SOUNDS LIKE A PLUMBING PROBLEM WITH DRAIN PIPE .YOU COULD FIT NONRETURN VALVE TO DRAIN FROM WASHER BUT THAT WOULD NOT STOP SINK FROM OVER FLOWING
Jan 08, 2010 | Washing Machines
Our Fisher & Paykel Washing Machine is not spinning. It gets to the spin cycle and sits there counting down. The fault code eventually said Service fault 37. What does that mean?
Emptied washer, tipped it on its side, detached drainage pipes underneath, and pulled out old fabric/lint/blockage with tweezers. Plugged in, switched on, all good.
Sep 29, 2009 | Fisher and Paykel Fisher Paykel Intuitive...
THE WASH REACCHES DRAIN AND SPIN STOPS THEN ENDS CYCLE
pump is blocked check your filter at the front some have a small drainage tube there to remove the water. failing that tilt back machine slighty open door and remove with a jug, remove filter uscrew and pull and check for foriegn objects i.e coins screws,whilst tilted back squeeze the two rubber tubes to the pump to make sure they are clear or unclip if need be MAKE SURE POWERS OFF lay some towels down sit machine back down slowly there will be excess water and with filter out run machine SPIN ONLY if it does you've solved your problem also check your waste and outlet pipe your waste could be pushed too far down the outlet pipe 6" is adequate enough.good luck
May 18, 2009 | Zanussi FJS1225W Front Load Washer
Programme gets stuck on wash cycle
Most likely a defective door switch.
Mar 02, 2009 | Washing Machines
Help
i dont know if this is right but your washer might be old or it might need a flu pipe. the other reason is that one of the other pipes like the drainage pipe is blocked or old or rusty and cant let water past it, since your drainage pipe is different from the washing pipe the water stays their and you need to turn the spin cycle on to let it pass through the washing pipe instead of the drainage pipe.
Dec 27, 2008 | Kenmore 46462 Front Load Washer
AWM8121 Drain/Spin cycle stops
it seems to point to blockage in drainage pipe from drum likely to be a lost sock remove pipe and check
Jul 05, 2008 | Whirlpool AWM6120 Front Load Washer
Washing still wet - door won't open.
not a fault with washer. i guess you are plumbed into trap under sink. the spigot you fastened drain hose to is blanked off - there are various methods of doing this including have to saw off the end of the spigot with the bread knife. possible also a fault with pump or filter
Nov 16, 2006 | Hotpoint WMA46 Front Load Washer
Washing Machines Logo
26 people viewed this question
Top Siemens Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Siemens Washing Machine Expert? Answer questions, earn points and help others
