Question about Samsung Televison & Video
Switch on TV Picture perfect change channel and the screen is snowing with "weak or no signal" sign. This is an intermitent fault and shows no discernable pattern. I have had the arial checked and found to be in working order. I have returned the T V to the dealer who says nofault has appeared. The T V was delivered in November 2009. Model is Samsung LE26B350F1WX according to receipt.
  • 10,594 Answers
Problem seems with tuner in tv that can not process a little weaker signal hence tv shows *weak or no signal* message on screen.
Ask your dealer to increase AGC level of tuner as dealer would have contact tv repair shop/ tv technician to do so.
Hope this adjustment will solve your tv issue or replace tuner board in tv to fix the issue.
Thanks.
Posted on Sep 03, 2010
Model LNT4061FX/XAA Intermittent snow then picture. Is there a cure?
Intermitant snow means your tv is not getting signal continuously. Please check the input signal connection and source to your tv.
Dec 26, 2013 | Samsung LN-S4041D 40 in. LCD HDTV
LG flatron plasma rz42px10 snow screen with sound
Check and replace its tuner. If you wish to get some details; visit the site linked here. Pull up older posts.
http://electro-medical.blogspot.com/
Apr 11, 2017 | Televison & Video
My sony tinitron kv-t25sf11 turns on but no picture or sound, just snow, cant find any channels on autotune. when i turn to av channel, then back to tv i get audio from a channel for half a second before...
There can be few suspects for this fault but ONLY a signal test will confirm the exact part.
1. It is possible that the TUNER is faulty , if so the AV must work with good clarity.
2. Also the IF section can be faulty, it can be the IF processing section or the data switching from the processor.
3. It can be a digital logic gate switch failure as the processor is unable to switch from AV to the TV RF section.
4. Tracing using a signal or tracing with a scope can confirm the section. You can check at the AV switching section for a possible fault.
Thank You
Sep 24, 2011 | Televison & Video
What can I do to fix the flipping of the screen from snow to prog
the tuner is getting a weak signal and that is why the vertical sync signal is weak and the picture is rolling .check the cable on the back
May 23, 2009 | Samsung Televison & Video
The screen shows ''Weak Signal'' and no picture, even though audio is coming through from both the Cable DVR box and Blue-Ray player. The cable box connects to the TV with an HMI cable - all five TV inputs...
Mine did the same thing once. I think all I did was hit the setup on the remote, and let it run back through all the channels and then it worked just fine.
I hope this works for you.
Dec 29, 2008 | JVC LT42P789 42 in. LCD TV
Sanyo DS20930
The problem with saying my TV is acting up, is you did not mention the model #, type of TV, tube type, projection, plasma, LCD. They all have different faults that can cause this. The first thing you do is to hook up signal to your video inputs if you have any and see if the signal works that way, if so then you probly have a bad tuner, or you cable box is bad.
Oct 26, 2008 | Sanyo DS20930 20" TV
Picture shows snow and fuzz on channels JVC AV-32980
Sounds like U have an antenna or feeder problem. Get it checked out/ check it out. If in a strong signal area, try a simple indoor antenna for comparison. If in a marginal reception area, it could be your antenna is inadequate.
Mar 27, 2008 | JVC AV-32980 32" TV
No more picture and sound
Tv was showing perfect picture now it's snow solution 1 please check antena wire & its socket. 2 check for dust where wire is connected. 3 loose contact or print break near tuner. 4 tuner defective.
Sep 15, 2007 | Sanyo DS27930 27" TV
Rear projection snow
Bad primary tuner==can be replaced,or==by-pass by using video inputs.
Aug 26, 2007 | RCA D52W20 52" Rear Projection HDTV-Ready...
No Picture, sound is all static
Make sure the ant. input switch didnt change and check the ant. connections If that dosent work sounds like a defective tuner.
Mar 30, 2006 | Philips Magnavox 27MS343S 27" TV
Televison & Video Logo
46 people viewed this question
Jerry Greenberg
Jerry Greenberg
