Sony BRAVIA KDL-40S2010 40 in. LCD Television Logo
Posted on Sep 03, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Hdmi is pluged in and there is sound but no picture
BONES420
Level 2:
  • Expert 171 Answers
  • Posted on Sep 03, 2010
BONES420
Expert
Level 2:
Answers
171
Questions
Helped
57064
Points
537
If the TV works ok with the other inputs then the problem is the input/output board that is not sending the correct signal and you would need to replace the analog board get the part number of the physical board to find the right one
My tv will not turn on. it shows the sleeping red light and sometimes will turn blue but the picture and sound will not turn on? what's going on?
your tv has a bad power supply module. with the model and serial number look it up on ebay, they are like $60. buy a new one and replace it.
I can not see any picture or sound at all. We have the HDMI cable pluged in the PS3 and the TV, but red white ,and yellow plugs we r not sure where they should be.
There are different settings for PS3 video output, i.e. if it is set for HDMI it wont display when a scart lead is used. Try the scart connector, if it works go into settings and change to how you want it set, dont forget to save settings
Sound but not picture on all inputs.
Check to make sure the color is matched correctly from the cable box to the tv. I.E. Red to Red Yellow To Yellow White to white. If Hdmi Cable make sure cable is in the hdmi port on the cable box. If so power cyc the cable box by unplugging the box and pluging it back in.
HDMI and or Receiver problem
While Bluray pluged into the TV change the resolution from AUTO to 720P then plug Bluray back to the receiver and see if it solve your problem.
PLUGED IN HDMI CORD AND I NOW HAVE NO SOUND THROUGH THE TV
Some of these sets have to run seperate red and white RCA cables along with the HDMI. I know it sounds silly but it is the truth. Look for audio inputs on the back near the HDMI port.
Hdmi 2 wont work on mitsubishi wd-y65
It sounds similiar to a problem we've had with ours, all components would work in hdmi 1, but hdmi 2 would only work intermitently. They ended up replacing the digital board (fortunately we have the extended warrenty, I'm sure it's not cheap). Sorry hope this helps.
No picture
Look under your tv settings for the pal ntc settings if you are using the av wire, if not please tell my what yoiu are using, also mak sure that youve pluged the av wire in the yello conecter av out on dvd/vhs and @ the tv AV in
No sound from my xbox 360
You cant have HDMI and the xomponent cables pluged in at the same time.
to get audio to your monitor you will need an xbox 360 audio adapter. You can find that here. http://www.xbox.com/en-us/hardware/x/xbox360hdmiavcable/default.htm
That comes with the HDMI and audio adapter.
You can probabaly find it seperate somewhere else.
I hope this helps.
42 plasma tv no picture but have sound
Try pluging in the euro connecters in tight on the back of the set or in some cases HDMI cables
8helpful
7answers
No sound through ps3 hdmi
hi i had a problem, but had no pic, but did have sound, rang sony, and they said buy a new hd cable, went out and bought one, and it worked fine!!!
Top Sony Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
ZJ Limited
ZJ Limited
matt martin
matt martin
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
