Question about Refrigerators
What weight of freon i need for recharge hot point refrigerator compressor
  • Refrigerators Master
  • 43,501 Answers
Here is a tip that I wrote about recharging refrigeration or air conditioning...
How to add Freon to a Air Conditioner or Refrigeration System
heatman101
Posted on Sep 03, 2010
Isn't blowing cold air, clened coils, removed, dirt, leaves, but still no cold air. Seems to be low on Freon. How do I get the unit charged?
The compressor needs to run, does it run? If it runs and the outdoor radiator is not producing heat, then it may be low on refrigerant. The compressor refrigerant lines, the skinny gets hot and the thick line gets cold under normal operation.
To recharge the unit, it needs to be leak checked and repair any leaks found, then recharged. The refrigerant type used needs to be known, a manifold gage set is used to diagnose and recharge.
If you have a window unit, you should have it serviced or replaced.
Jul 14, 2015 | Kenmore 25,000 BTU Room Air Conditioner
Why dose air blowing out dash hot when in cold a/c position
Hello, There are a number of reasons that may cause your A/C to blow hot air. The compressor belt could be loose or broken, the A/C system could be low on freon, the A/C compressor clutch could be defective or the fuse could be blown, or the A/C mixing door could be stuck open just to name a few.
Jul 30, 2014 | 2004 Ford Excursion
My hotpoint refrigerator leaked out all the freon. Can I repair it myself?
this hot point or ge had freon leak at evaporator coils. I replaced that piece and here is video.
Nov 27, 2011 | Hotpoint HSM25GFRSA
My lg 15000 er air conditioner is blowing hot air i could hear compressor starting for five minutez of cooling the n shuts off and hot air again i have cleen filtered and cleaned coils inside part
The unit is probably low on freon and so it is running too cold....this trips the freeze stat and shuts down the compressor till it warms up and you reset it by turning it off and then on again...
The unit will need to be recharge or replaced...
Here isa tip that I wrote about how to add refrigerant to a air conditioner or coolingsystem
heatman101
Sep 27, 2010 | LG BG8000ER Air Conditioner
Ac will not take a charge ac is blowing hot 2002 kia sedona
could be a problem with the heater controls ,or you do not have the right machine to recharge the vehicle properly with R134 ,the vehicle needs to have the system reclaimed then oil recovery and then a vacumn before the oil is added and the gas by weight.For this you need a special machine
Jun 06, 2010 | 2002 Kia Sedona
Recharge freon. How do you add freon to the air conditioning?
when the ac doesnt blow cold and the compressor pump doesnt click on ,this can only be done with the proper machine to remove the gas and weigh how much was taken out ,then oil recovery and a vacumn then recharge with the corerect weight of gas .
May 27, 2010 | 2001 Chrysler Town & Country
Freezer not freezing and burning smell
it may be the compressor overheating it could be the relay but if the compressor is hot then you are low on freon and need to have it recharged
Jan 26, 2009 | Amana ARS2464B Side by Side Refrigerator
Fridge compressor hot. inside of fridge/freezer is not. compressor humming(assumed to be running).Whats an indicator of low freon and can it be refilled? Thanks!
low refrigerant may be indicated by outside tubing at room temp (or at least most of tubing) when compressor running. can be confirmed by pressure checks on system. Refrigerant can only be checked or recharged by qualified (card carrying) appliance tech or refrigeration tech. be sure to clean condensor (outside) tubing and make sure fan next to compressor is running if there is one.
Jun 20, 2008 | Refrigerators
Refrigerators Logo
116 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
