Question about Philips Philishave Cool Skin HQ6760/HQ 6761
Lock symbol Whenever I try to start my shaver I get a flashing key symbol?
You've turned the travel lock on - hold the power button down for about 3 seconds and it should turn off and on normally again.
Posted on Jul 19, 2008
Flashing key symbol
wire may have fallen off switch, or shorted
Feb 08, 2013 | Hotpoint WMA74 Front Load Washer
Won't start key symbol flashing
So do you need a manual for operating it ?
Oct 06, 2008 | Gaggenau EB290 Electric Single Oven
Cranking but not starting...
If the pass lock sign is flashing (pad lock symbol) then you have no gas to start, you have to turn the key off, wait ten minutes then see if your pass lock symbol light goes out, it will blink then go out if it is reset, then you can start your engine.
Dec 20, 2012 | 2005 Chevrolet Colorado
I have the Philishave Smart Touch-XL Sudenly a key and a lock have appeared and I can not use my razor machine Pls. help me
Just for future reference, I have a Smart Touch XL and the key and lock symbols in the display seem to be some sort of child lock - you can get them to become active by pressing and holding the power button. There is also a way to instigate a demo mode from here where the display will cycle through as though the shaver is charging and the shaver will switch itself on and off in a cycle for in store continuous demonstration purposes (it does not have to be powered). To recover from locked mode it is simply a matter of pressing and holding the power switch for a couple of seconds and the shaver will turn on and the key and lock symbols disappear.
May 03, 2011 | Philips Philishave HQ7780 Electric Shaver
How can i turn off key symbol
Hello Lucy and welcome to Fixya.
As far as the "signal" activation or de-activation goes, it should be performed before starting a load of laundry and it is as follow's... 1) Turn the program selector to any program as you would doing laundry. Add your items... 2) When you close the door the "start/pause" light flashes... 3) Press the "menu" button until the signal indicator is displayed and flashes ( a small speaker symbol ) as does the start/pause light. If no buttons are pressed within 10 seconds, the current setting will be saved. 4) Press the "select" button until the desired volume or "off" is reached/displayed. 5) Press the "start/pause" button so the program starts and the setting is saved after the cycle has completed. As for the "key" symbol, your washer has a "child lock" program and the symbol indicates it has been activated.
Here`s how to deactivate it...
1) Press the "menu" button until you see "CHILD LOCK :ON" appear in the display. ( if nothing is pressed within 10 sec.following this the menu will close and it will default to program in the display )
2) Once you see what I just mentioned in the display press the "select" button until "CHILD LOCK :OFF" appears in the display.
3) Finally by pressing the "start/pause" button the key symbol should disappear confirming you have successfully exited the child lock program.
Let me know if this was helpful to you or not, if so please take a second and rate it accordingly.
Thank you for visiting "fixya" for your washer solution inquiry.
good luck going forward.
macmarkus :)
Jun 16, 2010 | Bosch Washing Machines
Have bosch classixx6 1200 express which has frozen displays a flashing key and 36 will not budge, desperate Molly
Simply press and hold the Start button for 4 seconds and the childproof lock will turn off - the key symbol will disappear from the display.
If you want to activate the lock then press and hold the Start button until the key symbol appears on the display.
Oct 22, 2009 | Bosch Washing Machines
The digital display is showing a KEY symbol flashing, and i can't program a new load. What does this mean?
This is the childproof lock symbol and prevents you from changing a program once it has been selected The symbol flashes if the program is changed during a wash cycle. If the machine is switched off mid cycle with the lock on then it will continue the program as so as the machine is switched back on. To activate the lock press the START button and hold for 4 seconds and the key is displayed. To deactivate the lock press the START button and hold for 4 seconds until the key symbol disappears.
Sep 30, 2009 | Bosch Exxcel WFX 2467 Front Load Washer
Smarttouch xl lock
Keep the on/off button pressed for approx 30sec (or more) until the razor starts
Dec 05, 2007 | Philips SmartTouch-XL HQ9190 CC Electric...
Red L.E.D light won't stop flashing
Shaving head check indication After two years of use the red shaving unit symbol î will flash for 30 seconds during 7 shaves to indicate that you should check the condition of the shaving heads. This indication is based on an average shaving time of 3 minutes per shave. When the shaving head symbol flashes, all other symbols and lights are out. When the shaver is switched off, the shaving unit symbol disappears. When the red shaving unit symbol starts flashing, you should check the shaving heads for possible damage. If the shaving heads are damaged in any way, they must be replaced in order to obtain optimal shaving results
Nov 20, 2007 | Health & Beauty
Philips Philishave Cool Skin HQ6760/HQ 6761 Logo
356 people viewed this question
Top Philips Health & Beauty Experts
shaveroutlet.com
shaveroutlet.com
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Philips Health and Beauty Expert? Answer questions, earn points and help others
