Question about Samsung SyncMaster 540N 15" LCD Monitor
How to open samsung syncmaster 540n monitor - Samsung SyncMaster 540N 15" LCD Monitor
  • 11,361 Answers
Here are the service manuals: http://elektrotanya.com/?q=showresult&megnev=samsung&megnev2=540T&kategoria=&kat2=all
You will need thin flat blade screw driver to crack open the case, hard to explain by words but you can try YOUTUBE. Juat be real careful wit the front bazel where the switch assembly is, it has very delicate ribbon cable attached to it.
If you are going to DIY and have proper tools and know safety precaution then please read on:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply (they should be replaced in a set), blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Posted on Sep 03, 2010
When i turn on my lcd samsung syncmaster 540n it displayed a lot of colored vertical and horizontal lines.no video when i attached my cpu but it turns on when i powered my cpu
boot up in safe mode (press f8 while booting) If your monitor works now, you need to go the the samsung site and download the driver for you monitor. I assume windows 7, since that is where most of the monitor problem occur.
Mar 08, 2011 | Samsung SyncMaster 540N 15" LCD Monitor
My monitor (Samsung, SyncMaster 540n) is not getting "ON" normal. it takes almost 15 mints and some times more.
meu monitor quando desligo ele passa +ou- 20 a 30 minutos piscando pra poder ligar op q tenho que fazer será que é um defeito ou pode ser alguma configuração por favor manda resposta pra meu e-mail eu232011@hotmail.com
fico muito grato por colaborar abraço atodos uma otima semana,
agradeço a direção...
Jan 09, 2011 | Samsung SyncMaster 540N 15" LCD Monitor
Samsung SyncMaster 540N Monitor takes long time for the first time. Once it is up, if I turn it off, and on again, it comes up as usual.
sounds live you video drivers are not right. verify this is being used. download and run the application setup. it will only install if you have the right monitor
http://www.samsung.com/us/support/detail/supportPrdDetail.do?menu=SP01&prd_mdl_name=540N
above is drivers for the Samsung SyncMaster 540N
Aug 12, 2010 | Computers & Internet
I have a syncmaster 540N monitor for 3 yrs. Until a week ago it was working superbly..Bt now the display appears after 5 - 6 mins..plz help..
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed SAMSUNG monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
http://www.badcaps.net
Service manuals: http://elektrotanya.com/?q=showresult&megnev=SAMSUNG%20&megnev2=540N&kategoria=&kat2=all
May 12, 2010 | Samsung SyncMaster 540N 15" LCD Monitor
I have samsung syncmaster 540n lcd monitor . i want install the driver file
For this samsung monitor driver search in driversguide.com before downloading the driver register your name.
or
Click this Direct Link from download.cnet.com
Happy Downloading
Thanks & regards
Nandu :)
Apr 28, 2009 | Samsung SyncMaster 540N 15" LCD Monitor
Is there any display driver for synmaster 540n
http://www.samsung.com/it/function/search/resultList.do?searchWord=540n
Mar 05, 2009 | Samsung SyncMaster 540N 15" LCD Monitor
Problem with samsung syncmaster 540N 15"
To replace all Electrolatic capacitors in Power supply& drie Currected
check all connectors are properly connected r not
Sep 13, 2008 | Samsung SyncMaster 540N 15" LCD Monitor
Samsung SyncMaster 540N 15" LCD Monitor Logo
719 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
