Question about Mk Diamond MK - 660 Electric Tile Saws
I HAVE A MK 660 TILE SAW ,GOT MOTOR REBUILT BUT WIRE WERE BURNT AND I DONT KNOW WHAT WIRES CONNECT TO ,THERE IS A SWITCH,RESISTER , THERMAL RESET SWITCH AND RECTIFIER.ANY ONE HAS HAD THIS PROBLEM OR COULD I GET A WIRE HARNESS WIHT DIAGRAM...............NICK
  • nick primerano Sep 04, 2010
    thanks j,
    but on that web site it does not show me any of the parts that i need to re wire this machine(mk 660)
  • 3,740 Answers
Diamon has the wiring diagrams for their motors on their website here: http://www.mkdiamond.com/tile/tec_wiring.html
They do not list them by model number. The are listed by motor part number. FYI the motor on your tile cutter is DC. Reversing the leads will cause the motor to run backward.
Thanks for choosing FixYa.
Kelly
Posted on Sep 05, 2010
  • 10,865 Answers
Hello Nick. Go to this link and download the manual and wiring diagram you need. http://www.mkdiamond.com/tile/tec_manual.html
J.
Posted on Sep 04, 2010
My MK-100 does nothing when I turn on the switch.
Check the brushes for the motor. very common problem in electric motors. It should look like a slotted head of a screw on the side by the motor. Only its plastic and about the size of a dime. After removing the brush, or magnet is what it actually is, replace it. Very cheap to replace and most hardware stores carry them. Hope that helps. Otherwise the switch is bad
Jun 27, 2012 | Mk Diamond MK - 170 Wet Cutting Tile Saw
I need to replace the switch on my 660 but I can't find the wiring diagram
get the new switch 1st,i have gotten them at orchard supply hardware,for mk 101 before,if your switch is broken in the on possition,you can leave it be for now and use a electrical surge outlet you probably have your tv pluged into,they have a on/off reset switch on them and you can use that to get you by for now or a foot pedal sold at tile stores for tile saws,good luck
Jan 22, 2011 | Mk Diamond Saws
I removed the cover on my mk 101 tile saw to replace the switch and the wires came off the run capacitor. Does anyone know which wires go where. Theres a neutral coming in from the cord on one side and 3...
OK MOST Caps aren't polarized, so can go on anyway... Check to see if there is any + or - on the Cap... NO then connect it up anyway .. if yes Phase needs to go to + Neutral needs to go to -.
Black is normally Phase, which probably goes to the motor so the other two, white & blue must be for the Cap.
But unless ya can get a schematic from manufacturer this is only an educated guess.
BE CAREFUL.
Jan 29, 2010 | Diamond Products Mk - 101 10" Tile Saw
I am trying to find an wiring diagram for a tile saw mk-660
Here is the website you need to find the manual and wiring diagram for your saw
Hope you find what you are looking for
http://www.mkdiamond.com/tile/saw_660.html
Nov 30, 2009 | Mk Diamond MK - 660 Electric Tile Saws
Tile saw electrical repair
here is the exploded parts view and parts list.
http://www.mkdiamond.com/pdf/manuals/tile/100/mk100_iso.pdf
You don't really need a wiring diagram. get the switch, swap it out wire for wire... pretty easy.. getting it apart will be the hardest part.
Nov 26, 2009 | Saws
Shorting out
have you checked the brushes ???
Aug 06, 2009 | Wet International Mk Diamond 153330 Mk 660...
No voltage at water pump plug on MK 101 off switchbox.
The Capacitor is only for starting the main motor and not the water pump. Like you said, if you connect the water pump to 110V it will run so there is a problem with how it is wired to the on/off switch. there should be a white wire (neutral) permanently connected to the pump and the on/off switch should supply power on the black wire when turned on.
Apr 05, 2009 | Diamond Products Mk - 101 10" Tile Saw
I need the output shaft of this motor. It has the
You can order the parts you need from this website
http://www.mkdiamonddirect.com/category.sc;jsessionid=B8C66F8A4D5E422E3B401A634FBA7476.qscstrfrnt01?categoryId=99
Hope this is what you need
Mar 31, 2009 | Mk Diamond MK - 1070 Tile Saw
Water flows for cooling but saw does not rotate
check to see if the motor has overload reset button on it (red) usually the water is only pump portion of circuit and can run independent of motor circuit , if not check wiring to motor circuit
Nov 20, 2008 | Mk Diamond MK - 770EXP
Mk Diamond MK - 660 Electric Tile Saws Logo
557 people viewed this question
Top Mk Diamond Saws Experts
Tom Chichester
ray gallant
Are you a Mk Diamond Saw Expert? Answer questions, earn points and help others
