Question about Kogi l7eh-ta ko 17" Flat Panel LCD Monitor
I am trying to connect my KOGi 17 in. monitor to my 15 in laptop and I get my Screen saver but NO Programs. what do I need to do??
  • 4 more comments
  • hgan Sep 03, 2010
    my "use as main monitor" greyed out and will not accept my check mark
  • hgan Sep 03, 2010
    Hey 114, followed all of your steps many many times. #2 screen shows up .The extend at this monitor IS checked!, the use as main monotor is GREYED OUT AND UNCHECKED! when I go back to #1 monitor both are greyed AND CHECKED. How can I get the #2 Monitor to accept the main Monitor check??
  • hgan Sep 04, 2010
    114, NOW WHAT, yOU HAVE NOT SOLVED MY PROBLEM.
  • hgan Sep 04, 2010
    i HAVE ALREDY ASKED FOR MORE ASSISTANCE.wHEN CAN i EXPECT A REPLY
  • hgan Sep 04, 2010
    I have always had both screens,THE PROBLEM IS THAT MY PROGRAMS, FILES AND TASK BAR DO NOT COME ON THE #2 MONITOR AND I AM UNABLE TOUSE IT TO WORK WITH. IT ONLY SHOWS MY SCREEN AND NO ICONS. THE MOUSE IS ACTIVE ON BOTH. HOW DO I GET ALL THAT INFORMATION SO I CAN WORK ON THAT MONITOR????
  • hgan Sep 05, 2010
    Clear questions? My #2 KOGi monitor IS enabled with my THEME picture not screen saver, the same as my laptop EXCEPT I repeat EXCEPT it does NOT show my icons, task bar! my curser IS active on both screens. I want to use the KOGi as an active working monitor. My "settings" will not open to allow me to check use as primary Monitor. What am I missing???
Check the default power settings. Start -> Control Panel -> System & Maintenance -> Power Options. The default will turn off the monitor from five to fifteen minutes. Moving the mouse should turn it back on. Make sure your video out is activated. On most laptops the key looks like lOl. And its usually in the F4-F8 range
Posted on Sep 05, 2010
  • 4,924 Answers
Im not sure what you mean by getting the screen saver...maybe the secondary monitor is not enabled..and in this case..you have to enable it from the video driver settings ..or try the short cut..it is Fn+ F4 or the monitor function ....it is the function with a monitor on it ..and the secondary monitor will be enabled..
see that the F4 is not a must be one...it can be the f5 or f6 ..just try them if there not seam to be working ..or take a look to see which one is labeled with a monitor sign..and use i t..press Fn + that key ..
  • 857 Answers
Follow these steps:
Check whether your monitor has a DVI (digital) or VGA (analog) port, both of which are generally built in. Contact your vendor if your laptop does not have either. In this case, you can use a special adapter to connect the external monitor. These adapters are model specific and should be bought directly from the vendor.
Connect one end of the DVI or VGA cord to the DVI or VGA port of your laptop and the other end to the monitor. Your laptop should automatically identify the external monitor as a new hardware device.
Press Fn + F2 to toggle the screen do it twice to get the display on both the screens.
Posted on Sep 04, 2010
  • Jayant Jha Sep 05, 2010
    If you are using any utility to do it like any software, i would recoment to download it from the website and then when you do the setup at that time you can select the dual dispaly.
    Check your video card type and downlaod the utility from its website.
    President:
  • 1,851 Answers
All you have to do is, at the settings (right click on a free space on the screen - properties - settings), to click on the screen numbered as 2, check the box "extend at this monitor" and the above box "use as main monitor". Hit apply and your main screen will be the external 17''.
In case of a problem or clarification, don't hesitate to post me a reply before rejecting my answer.
If you are satisfied, accept my solution.
Thanks and regards
Stelios
direct FixYa link: http://www.fixya.com/users/technical114
Posted on Sep 03, 2010
  • 1 more comment
  • Stelios
    Stelios Sep 03, 2010
    Let me put it back in order:
    A. Choose monitor number 2. Your screen has to be like this:
    B. Choose extend at this monitor. Your screen has to be like this:
    C. Now you can check the "use as main window" box. Your screen has to be like this:
    After the previous step the boxes will be grayed but the selections will be done. Hit apply and ok.
    Thanks and regards
    Stelios
    direct FixYa link:http://www.fixya.com/users/technical114
  • Stelios
    Sorry for my adhesion but at all the cases I set up 2 screen as main monitor this is way. Just take care that (at the 2nd monitor) you must first choose expand at this screen and then you will get the ability to choose use as main. If at your case this can not be done I'm suspect about the laptop's VGA. What is the brand / model?
    Thanks and regards
    Stelios
    direct fixya link:http://www.fixya.com/users/technical114
  • Stelios
    Stelios Sep 04, 2010
    In case I didn't ansewered your question wait for a better solution from FiXya community experts.
    Thanks and regards
    Stelios
The issue is that I had an XP machine and I bought a brand new HP deskktop Windows 7 and as soon as I turned it on I got a message on my Kogi that I should change the settings to 1280 X1024. Since I did...
To change the screen resolution, click on Start - Control Panel - Display - Settings tab and the adjust the screen resolution slider to 1280X1024 click Apply.
Feb 03, 2011 | Kogi l7eh-ta ko 17" Flat Panel LCD Monitor
I just hoolked up a Kogi l7 eh 17
It may be that your video card is too old, that probably is the problem since you are running Windows 2k. If not open up your monitor's menu and see if you can manually change the monitor's resolution. Newer monitors do that.
Apr 12, 2010 | Kogi l7eh-ta ko 17" Flat Panel LCD Monitor
When pc left on after 15 minutes the screen keeps changing colours from reds /greens /greys/blues constantly is this normal
Maybe this is a Screen Saver, set to start after 15 minutes. Open up Control Panel then Appearance and Personalization, then Screen Saver to check on this and perhaps choose a more pleasant screen saver.
Dec 03, 2009 | HP Pavilion F1703 17" LCD Monitor
Kogi L9CH monitor - black screen
return for a replacement, the screen is broken
Sep 13, 2009 | Kogi L9CH 19" Flat Panel LCD Monitor
Looking for the three cables needed for a 17" KOGI L7CH LCD monitor. Where can I find these, please.
You need a signal cable, an audio cable and the power adapter. The first two are standard cables available at any retailer of computers and monitors or online. The signal cable is the type that has 15-pin "D-sub" connectors on each end. The audio cable will have a mini-stereo plug on each end. The power adapter is available from several online sources. There's an eBay auction currently running for the adapter you need.
Jun 15, 2009 | Kogi l7eh-ta ko 17" Flat Panel LCD Monitor
Kogi 17'' flat screen monitor
there are four(4) buttons on your monitor to the left of the on/off switch.
Press the first one to the left of the off switch, which will bring up a menu, so you can select
bright or volume, screen size, etc; Next, there are two (2) buttons to the left of the first left button
that you can push to adjust brightness, size, vertical, etc;
Apr 03, 2009 | Kogi l7eh-ta ko 17" Flat Panel LCD Monitor
Cables for the KOGI 17"
Any Computer Electric Plug Will Work But The Cable For The Screen To Hook To The Computer Can Be Bought On Ebay, Circuit City, Radio Shack, Best Buy Wal-Mart Even.
Jan 05, 2009 | Kogi l7eh-ta ko 17" Flat Panel LCD Monitor
Oversize Message
dear,
run the system on safte mode and then try to manage your screen resolution to minimum and then restart it normally..
regards,
dont forget to rate
Jun 20, 2008 | Kogi l7eh-ta ko 17" Flat Panel LCD Monitor
Kogi Monitor
Hello there.
You need to enable the external display in your Operating System.
Please see http://www.mrhope.com/issues/ch000801.htm for information on the FN keys on your laptop.
Hope this helps.
May 04, 2008 | Kogi l7eh-ta ko 17" Flat Panel LCD Monitor
On screen display on monitor locked and need to restore factory settings
Hold the menu button down long enough and it should unlock, if it unlocks and then locks back up immediately, you have a problem on the main board
Mar 07, 2007 | Kogi l7eh-ta ko 17" Flat Panel LCD Monitor
Kogi l7eh-ta ko 17" Flat Panel LCD Monitor Logo
102 people viewed this question
Top Kogi Computers & Internet Experts
Laxman Bisht
Laxman Bisht
Computer Links
jay kaye
jay kaye
Are you a Kogi Computer and Internet Expert? Answer questions, earn points and help others
