Question about HP Color LaserJet 2600n Printer
I am printing address labels.Avery L7162. The labels have a logo on them. The Logo is grey toned. It prints correct color on the left side but on the right side of the page the logo has gone a purple color. Can you advise how to fix this please?
  • 1 more comment
  • harrishouse2 Sep 03, 2010
    Didn't make any difference
    I tried the advice I received. I uninstalled the programme and reinstalled the programme but it made no difference.
  • harrishouse2 Sep 04, 2010
    There is no purple toner.
    Toner has all been checked and is all OK
  • HP Master
  • 1,606 Answers
This sounds almost like a fusor unit issue. It can be a few other things so what you need to do is sort through a few things and see if we can nail it down.
First on the purple color side when you feel the printed bit is it rough or powdery in any way? Do you see any faded print along that side? If the purple is rough or soft or powdery then the fuser may be weak. This literally melts the plastic toner powder onto the paper and if it is not hot enough the color and texture can change.
If the print is faded down the entire side then you may have a low or unevenly distributed toner problem. You can get these just before they say they are empty. You can take the cartridge out and gently shake side to side to even out the toner powder inside to fix or replace the cart.
Next try printing a sheet with the output set to gray scale. That should force it to only use the black toner. This should confirm that the problem is in the black toner and not a problem with the other colors. I don't know what you are printing so I'm trying to rule out what may be obvious to you but not so obvious in a text description.
Next try printing on ordinary paper. Try normal and gray scale output. If it prints normally then the problem may be the labels. The labels may be affecting the heat but you may see the purple error change as it heats or cools as it prints multiple pages, IE it may print fine the first page then change or print normally after a few pages. I know we switched from avery on ours as the adhesive seemed to melt on long print jobs. You may need to try a different brand of label if it prints fine on normal paper.
If it is a serious hardware issue on these you will get an error code in the display. It is possible but not likely these are the early symptoms of a impending failure (don't worry nothing serious or expensive) but I don't think this is one. I think you have a paper or label in this case compatibility issue. There is nothing wrong with avery, thats what we have always used. However the printer or a batch of labels can be different and cause an issue. We've switched and switched back later with new stock and were fine again.
Posted on Sep 04, 2010
    President:
  • 1,851 Answers
It seems that the purple cartridge is going to end of life and the purple toner comes out. Replace with an original (or qualified refiler).
In case of a problem or clarification, don't hesitate to post me a reply before rejecting my answer.
If you are satisfied, accept my solution.
Thanks and regards
Stelios
direct FixYa link: http://www.fixya.com/users/technical114
Posted on Sep 03, 2010
    Genius:
  • 1,478 Answers
The problem could be from the printer driver, it might be malfunctioning, i will advice you uninstall the printer driver and reinstall back after uninstalling, that should fix the problem.
Take care.
Print avery label from hp photosmart
could very well be try an ordinary print see if you have the same problem
Nov 19, 2017 | Computers & Internet
Hi. We are trying to use an avery label 22807 and also 22806 for a label factory logo we created. We need measurements/diameters so that we can print on these labels. They keep printing wrong. ...
If you are using Microsoft work to print the label, then follow the link below to Avery's website. The link is to their find a template, type in the label number in the Product # or Keyword search box and it will take you to a down load for that label. Click on the download, you will be asked for some information before the download begins. Follow the instructions on the next page (save the file and remember were you saved it). When you open the saved file it will be in Word and you can go from there.
http://www.avery.com/avery/en_us/Templates-%26-Software/Templates
I hope this helps you out.
Jul 22, 2011 | Computers & Internet
Set up a mail merge for labels avery L7162, but the printer prints them a different size - Printer is HP M3035. It is something not set up on the printer
You will need to feed these through the manual tray and you should set the paper size and type to match this label. The avery site shows this as an A4 label sheet. If you are in North America the default on this printer is letter size not A4.You should also ensure that you have configured the print driver correctly when you go to print.
May 23, 2011 | HP LaserJet M3035xs MFP All-In-One Printer
Hi My printer 2600n prints a shadow of the
if logo preprinted may not take heat if everything repeats check fuser
Jul 28, 2010 | HP Color LaserJet 2600n Printer
Want to know if this printer can print address labels (Avery peel and stick). Thanks.
Yes you can print Address but to print that you have to use MS word, to create it first
May 19, 2009 | Brother MFC 490cw Color Inkjet...
How do I Print Address Mailing Labels from Avery 300-Easy Peel White Mailing Labels, on Windows XP,CP?
You'll need the actual Avery code for this, or at least the correct measurements.
Open up Microsoft Word. Go to 'Tools' and find 'Letters and Mailings' in the list. Then off of that is 'Envelopes and Labels'. Click on that one and a box will pop up. If you click on 'Options'. From here you can find the correct label settings by the code which will be on the Avery pack. If you haven't got the code, you can scroll through the lists and highlight options to see the measurements but this will take you a while.
Once you chosen your labels, click on ok. Now you can enter your address in the box and print a whole page of the same address or click on 'New Document' and that will give you a page set out correctly for that label sheet.
Nov 19, 2008 | Computers & Internet
Printing avery labels
You need to change the paper settings from plain to something thicker. The toner is not being heated properly for it to fuse to your paper. It needs to run at the correct speed and temperature in order to adhere properly.
Set it to a heavier stock.
Apr 29, 2008 | Konica Minolta magicolor 2430 DL Laser...
Does not print pictures
hi suvi please tell us more about your computer and printer setting.. However, i have some question.. 1) Does your printer print another logo or any other picture correctly like before? & 2) Which software did you used to print your logo? Thanks, waiting for your response
Aug 29, 2007 | Epson Stylus C46 InkJet Printer
HP Color LaserJet 2600n Printer Logo
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
