Question about Brother IntelliFAX 775 Plain Paper Thermal transfer Fax
Can not get a dial tone. Phone appears to be off the hook. How do I trouble shoot it?
  • 1,110 Answers
Unplug the phone line from the fax machine. Wait at least 1 minute then call the phone number that goes to the fax machine from another line such as a cell phone. Make sure you get a ring and not a busy signal. If you get a ring then hang up the phone. Plug in the fax machine again and call the fax number again. If you get a busy signal then either your phone if off the hook, the switch that is actuated when the phone is placed in the cradle is bad or your modem in the fax machine itself has gone bad. Another thing to try is unplug the fax machines power cord for 30 seconds then plug it back in. I have seen the modems get "locked up" and keep the phone line open. Unplugging will sometimes reset this and get it working again.
Good Luck and Thank You for using Fixya.
Posted on Sep 03, 2010
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 91 Answers
Just check your Tellephone lines.The one that comes from the wall must go in to LINE on the back of the fax and the exturnal phone plug in at the Ext.Plug hole.....If that is not the problem you can put a normal phone in the wall socked and listen if you can hear a dailing tone.If not get your tellecom provider to check out your lines .if you do hear a dailing tone then the board in the fax is been damage.
The tel 1 and 2 buttons are flashing green along with stand by. The phone line has no dial tone and its busy when we call the line..
When the tel light blinks this indicates that the line is in use. To trouble shoot this issue you will need to connect a phone directly to the tel 1 port of your modem. If you have dial tone when directly connect that means that there is an issue with the internal wiring of the home. If you still do not have any dial tone with the phone directly connect than there is an issue with the modem and it needs to be replaced.
I hope that information above has helped is some way.
If possible please rate this solution.
Aug 25, 2010 | Arris SURFboard SB5120 Modem
Need to change phone back to tone dialing
Here's what the manual says: Changing the Dial Mode (Tone or Pulse Dialing) (HS1 only) Your phone can communicate with the telephone network in two different ways: tone dialing or pulse dialing. These days, most phone networks use a method called tone dialing, so your phone comes programmed for tone dialing. If your phone company uses pulse dialing, you need to change your phone's dial mode. If you don't get a dial tone or can't connect to the telephone network, follow the steps below to modify your phone?s settings: With the phone in standby, press and hold [cid/menu]. Press [vol/ / ] to move the pointer to select DIAL. Press [select/channel] to set the phone to pulse dialing. Press [end]. Return the handset to the base. The handset communicates the new setting to the base, and the base activates the setting on any other handsets. Hope this helps out. K
Jun 05, 2009 | Uniden 2.4 GHz Cordless Phone System
A new phone system I have bought requires the jacks in my home to be in parallel. If I remove the cover from a phone jack, is there a way to tell if it's hooked up in a parallel circuit? If it's not in...
A parallel phone system means all phone jacks are connected in a series. From phone jack A to phone jack B to phone jack C. That means if jack A is not functioning properly or has a short ,all other phone jacks in that series will cease to function. The other type of system is a home run system.Meaning all phone jacks are ran independently outside to service provider NID Network Interface Device. This is the best to trouble shoot because if one jack fails the others will continue to operate independently. The best way to check is to remove the lead from one side of the phone jack, after carefully removing from wall. Check for a dial tone at other phone jacks if no, replace lead at the initial jack. If dial tone returns you have a series system.
Oct 13, 2008 | Lands Phones
Dial tone
my phone has no dial tone and when you call the phone it has a busy signal. There is no static just sounds like it is not hung up.
Sep 23, 2008 | Panasonic KX-TG1033S Cordless Phone
GE Model 29265 Trimline Memory Phone
I just purchased the Trimline Model 29265 phone and in the instructions it says that it can be wall mounted if you reverse the handset hook in the base? Where is the handset hook and how do you reverse it. Nothing in the instructions tells you where it is nor how to fix it.
Mar 19, 2008 | Thomson 26943GE1 Cordless Expansion...
Bell phone
is your computer hooked up dsl or dial up? unplug all the phones and computer from the phone jacks.plug a corded phone into the jack and check for dial. if you don't have dial tone, call your phone company. if you do have dial tone, plug everything in one at a time and see if the phone line goes dead.if it does, the last thing you plugged in is the problem.
wg
Feb 10, 2008 | Lands Phones
No dial tone
Have you tried a known good phone in the jack, if that doesn't work take the phone to the demarc box provided by your phone company and open the door on the box. Under this door locate the mini jack and disconnect it, then plug your known good phone into that jack. If you get no dial tone at this point, then it isn't being provided by the local phone company so it's their trouble. Thank you. Jerry
Dec 18, 2007 | GE 26998GE1 Cordless Phone
No Dial Tone
If you are sure that both cords are good (use another phone to test), make sure the Speaker button light is off. If both lines stay lit up when the phone is on the hook, your phones has problems. Can't help you there.
Hope this helps, and please rate my advice.
Nov 24, 2007 | RCA 25202RE3 Corded Phone
Fax problem
I want to make sure I understand this completely. You get no dial tone from the fax machine when hooked up to VOIP. In the past, was there an audible dial tone from the fax, or did it just dial silently and give you an error if there was no tone? When you said you got a dial tone by connecting a phone to the ext phone port of "the machine" did you mean the fax machine? If you get a dial tone by running a phone through the fax machine, then the line is good. I have used a fax machine over Sunrocket before they went defunct, which used the same technology base as Vonage - so it should work. If you used to get an audible dial tone when using the fax, and no longer do, and you are geting a dial tone on a regular phone that is connected to the ext. port of the fax machine, then the problem has to be in the fax machine itself, not the VOIP. If you can verify that, we can go from there.
Oct 08, 2007 | Brother MultiFunction Center MFC-440CN...
Brother IntelliFAX 775 Plain Paper Thermal transfer Fax Logo
189 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
