Question about Hayward 1 Hp Max - Flo Swimming Pool Pump
I had a heater element go bad on my artisian spa, 240 volt, replaced the heater and bled the system, no i have a clicking noise constantly coming from the circuit board, trying to pin-point what would cause this a far as i can tell the flow siwtch seems to be working, tub is approx 2 years old
  • Electric by George Sep 04, 2010
    we need to find out what relay is kicking on & off you say the flow switch seems to be working.... any error codes on the topside control??
  • 310 Answers
Sounds like maybe the heating element installed is the incorrect voltage.
If not, the relay is bad as it sounds like a "chattering" relay.
Posted on Oct 28, 2010
Why is the water not getting hot?
This one is 240 volts
http://www.hayward-pool.com/pdf/literature/CZ-SpaHeater12.pdf
This one comes in both.
http://www.absolutepoolspa.info/electric_heaters.htm
you will need to find the element or the control and check. Or Google the spa "make and model" plus "heater voltage"
Dec 31, 2015 | Pool & Spa
Checking ohms on whirlpool dishwasher heating element
http://waterheatertimer.org/images/ohm-reading-for-emements.jpg
Rated voltage squared divided by rated wattage = ohms
Element rated for 240 volts and 3500 watts
240 x 240 = 57600
57600 divided by 3500 = about 16 ohms
Gene
Sep 09, 2014 | Water Heaters
Lay z spa heater pump
need more info does whole thing trip off sounds like shorted heater element if you are able to disconnect heater leads and thing stays on bad heater be careful its either 110 volts or 220 volts if your not familiar with this call a professional
Jan 25, 2014 | Pool & Spa
Not getting 240 volts to lower element- have replaced lower element and both thermostats. get 120 on each leg to ground but no 240
If your top element is bad the the lower element will never turn on be cause the top element completes the 240 circuit. It is like a resister in a circuit. Make sure top element measures out at 13 ohms.
Dec 24, 2012 | Rheem MR50245 Marathon Electric Water...
The dryer is spinning but no heat is coming out
You either have a bad element, a bad limit, or a bad timer.
Most times if it is the smaller limit mounted on the heater element you have a blocked vent. It still runs so the fuse is not blown and the door switch is fine. Make sure you have 240 going into the machine. The motor is 120 volts but the heater is a 240 volt component. So if one side of the braker is bad you won't have any heat.
Repair photos and more
Mar 06, 2012 | Kenmore Dryers
POWER PROB: I have an 85 Gal. Marathon water heater and I'm having some power issues. I have 240 Volts coming into the water heater and on the "upper" element but I only have 120 Volts on the...
It sounds like upper or lower thermostat.
Thermostats turn off one leg (or one wire) in the 240Volt circuit, so each elements will test for 120V even when thermostat is off.
When thermostat turns ON, it closes circuit by adding the second leg to 240V circuit, and element turns ON.
http://waterheatertimer.org/How-to-wire-EH40-hot-water-heater-timer.html#120-240
http://waterheatertimer.org/How-water-heater-thermostat-works.html
Take 30 minutes and troubleshoot before replacing parts:
http://waterheatertimer.org/How-to-troubleshoot-electric-problems-with-water-heater.html
Jan 11, 2011 | Rheem Water Heaters
We had no hot water so we check the elements with a voltage meter and found the bottom element to be bad. We replaced it. Now there is still no hot water. When we test the voltage again there is continuity...
The elements never run at the same time, it would take to much energy for a standard residential heater. Instead, they rotate powering up back and forth depending on the hot water demand. If you getting 208 to 240 volts on the top element and nothing is happening, the top element is bad and needs to be replaced. If you can swing 30 bucks, replace both elements and both thermostats at the same time. This way you know that everything is new. Check out this generic water-heater wiring schematic.
Sep 06, 2010 | Reliance & 50gal Electric Water Heater
Not heating
un hook the incoming power lines, turn the breaker back on, and carefully measure power between the 2 hot wires, not the ground. You must have 220 to 240 volts between these 2 wires, if you dont either the breaker is bad, or the wire is broken somewhere. If you have 240 volts to the heater, with the power OFF unhook the wires from both elements and use an ohm meter to test the resistance on the elements, both should be around 30 ohms and about the same, if not one is bad. Test across the elements after re connecting them and turning the power on you must have 240 volts across the elements when they are on, if you have only 120 or 0 then the trouble is the breaker or the wire.
Mar 06, 2010 | Rheem 40 GAL ELEC TALL Water Heater 6YR SC...
No hot water
If the water does not heat, then you have to troubleshoot to find the problem. With a voltmeter determine if 240VAC is actually getting to the water heater. Take care here - a defective circuit breaker can give a false 240 volt reading - check for the 240 volts across the upper element (i.e. when the 240 volts has a live load on it, not just an open circuit test).
Also, remember, the upper element has priority over the lower element, and if the water is cold, the upper element will try to turn on and this locks out the lower element (only one element is allowed to heat at any given time). The lower element comes on ONLY after the upper thermostat is satisfied. Therefore if the upper heating element is burned out you will never get any hot water. If you suspect this, TURN OFF THE POWER TO THE HEATER and take a resistance check of the upper element.
Nov 15, 2008 | Water Heaters
Hayward 1 Hp  Max - Flo Swimming Pool Pump Logo
180 people viewed this question
Top Hayward Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
john h
Are you a Hayward Pool and Spa Expert? Answer questions, earn points and help others
