Question about Frigidaire GLWS1233A Top Load Washer
My Washer does not spin or agitate when washing, but it spins when drying on cycle...
Hi Sir,
I had this problem last week...My washer does not load water...when i manually load water using a hose from a faucet,it start to wash...When it's time for it to spin...it doesn't spin...so my clothes come out wet...
Then the next day...it started filling up water on itself...just like the way it used to be...but then it doesn't agitate to wash the clothes...when it reaches it's cycle,it removes the water from the tub,then spins....
I talked to a technician to fix it but nothing happened...He can't fix it...
Im from a province,i guess the tech's here havn't encountered a washing machine like this...i cant afford to bring it back to it's service center because it's so far away and cost a lot for trucking...
I hope someone would help me with some troubleshooting tips.....thnx
  • lotsalove Oct 25, 2008
    where do we get a new gear box??
Hi Mate,
Check the controller, is it digital or analogue ( pushbutton or control knob that turns ) Sounds like part of the switching cycle has burnt out replacement of controler may be the answer
Stoker
Posted on May 11, 2008
My washing machine will'nt wash and little water come out to fill it
Washing Machine Will Not Agitate or Spin - Home Repair ...
? 15:00
www.youtube.com/watch?v=wUSmUSWWIS4
Oct 20, 2013 - Uploaded by Robert DIY This washing machine would not agitate or spin. There is a ...My washer also is not agitating or spinning but water will drain after a long while.
Troubleshooting Why the Washer Won't Agitate ' PartSelect ...
? 3:10
www.youtube.com/watch?v=LfWRyt1vj2w
Nov 5, 2012 - Uploaded by PartSelect
The only wash cycle that works is delicate none of the other washcycles work .... The washer still fills, drains and spins to dry butwill not agitate. ... Hi My machine wont spin or agitate on heavy loads like a few towels etc (fine
Nov 02, 2015 | Washing Machines
My washer''s agitator spins but not the drum during spin cycle.
If you see the agitator moving, but not the tub..I guess, you have a defective transmission..this is tough without knowing a little more info.
May 20, 2010 | Maytag Legacy Series Top Load Washer
Doesn't agitate and spin cycle work when reset
you have a worn motor coupler
you can order a new one at sears
and its a ver y easy repair
Oct 06, 2009 | Kenmore 3.2 cu. ft. Plus Top Load Washer
The Washer did not spin
MOR PROBELY THE CUPLER WENT OUT IS A 3 PEASE 2 WHITE AND 1 BLACK PART IN BUTTEM OF WASHR BETTEN THE MOTOR AND TRANMISION OR CK LID SWITCH. GOOD LUCK
Jul 16, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
No spin - agitate
You just do this
  • Test the lid switch
  • Inspect the motor coupler
  • Inspect the drover belt (belt drive only)
  • Inspect under the washer for soot (clutch)
  • Test the motor
  • Inspect the pulley
  • Test the transmission
  • Inspect the Agitator
  • Inspect the pump coupling
  • Test the Water switch level
Good luck !!!
Regards
PCmania
Jul 08, 2009 | GE Washing Machines
Cloths Soaked after Spin Cycle
If the motor has a transmission, it could be stuck in 1st gear. I think the agitator running is normal.
Jan 17, 2009 | LG WM1814CW Front Load Washer
Drum spinning during wash cycle
if when in the wash cycle the tub spins then the brake in the cluch assembly is worn and to be replaced. this holds the tub from moving when in the wash cycle. thanks tallpaul
Apr 14, 2008 | GE WBSR3140DW Top Load Washer
Kenmore stacked W/D will not agitate during wash cycle
hi thanks for the question i dont know the model of your washer but i think yours is a direct drive no belt you have a motor drive coupling which is located between the motor and transmission replace that part thanks the appliance doctor
Mar 31, 2008 | Kenmore 98702 Stacked Washer/Dryer
Frigidaire GLWS1233A Top Load Washer Logo
107 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
