Question about Bosch Dryers
Wtl 6101eu does not heat but runs. Where is the reset button?
  • Bosch Master
  • 43,501 Answers
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Posted on Sep 03, 2010
The heat stopped working on my Bosch WTL 5100 dryer (the dryer turns around just fine). I cleaned out the condenser filter, then opened up the back and pressed the red reset button. It worked -- once.
are u getting the full 240 voltage in some machines it uses 2 settings to run and to heat? u might get 120 for running it but the other 120 to run heat> thus u get it running but no heat? other wise u may have a bad heating element or hi-lo thermostat or the thermal cut off fuse, u can check with multimeter and u can buy cheap multimeter at places like harbor freight for 5 bucks
Dec 05, 2014 | Bosch Dryers
Hi. My Bosch WTL 5500 wont start. It has power and filters are clean. When you push start the dry light comes on and nothing happens. Any ideas?
there is a thermal reset button at the back of the unit on the heating element. to get to it you have to remove the back panel that covers the heating element. (its the panel that sticks out). Once that panel is removed you will see the red thermal reset button. press it so it clicks, then start unit. Let me know what happens.
Mar 18, 2011 | Dryers
Where is reset button?
Remove the panel in the back of the dryer that covers the heating element. ( the inner panel) (part that sticks out). Once that panel is off you will now be able to see the heating element and the thermal sensor. the reset button is located on the thermal sensor.
Dec 11, 2010 | Bosch Axxis WTL 5410 Electric Dryer
My Bosch Axxis WTL 5410 will turn on and spin but no heat comes out of it. I cleaned the heat exchanger and wiped down the moisture sensors inside the drum, but still can't get heat out of it. I've read...
How long have you had the dryer (is it still under Warranty) and do you have the owner's manual and have you looked in it for a solution?
If not then you can contact the manufacturer on line to pose the problem to them.
There may not be a reset button on it at all. If there isn't then it is more than likely the heating element and you will have to replace it.
Oct 17, 2009 | Bosch Axxis WTL 5410 Electric Dryer
Bosch TD WTA3000 can't find reset button
YOU NEED take out hood cover 210162 in the back dryer.
Oct 06, 2009 | Bosch Axxis WTL 5410 Electric Dryer
Re-set button location?
you need to remove the back panel the smaller one that covers heater matrix you will find a thermostat with a red reset button on it when you push it it will click and reset however you should find out why this happened before you use it again as it only does this if it overheats.
hope this helps
Jun 29, 2009 | Bosch Axxis WTL 5410 Electric Dryer
Dryer drum will not turn
check to see if there is a little red button on the back if so push it in thats your re-set button
Mar 24, 2009 | Dryers
Bosch Maxx WTL 6100 tumble dryer - door switch
i have wtl 6100 bosch and the mashine is not running. There is power on the machine, it can run but it can not run and heat. I can get light in al the panel, but it is like it needs to be rebouted. I can get it to show 111,222,333 etc in the window but i cant get it to work
Oct 25, 2008 | Dryers
Bosch WTL 5400 running, but not heating
I've just fixed mine. The heating element at the rear under the covers was broken - crappy design BTW!
Mar 18, 2008 | Bosch Axxis WTL 5400 Dryer
Dryers Logo
170 people viewed this question
Top Bosch Dryers Experts
Lawrence Oravetz
MightyMikeJr
Are you a Bosch Dryer Expert? Answer questions, earn points and help others
