Question about SanDisk 2GB microSD Memory Card
Sandisk adapter will not work using my integral mobile card reader i am trying to store music on to the disk and it wont let me transfer any data whatsoever please advise of a possible cause and solution many thanks steve stephen_leonard@btinternet.com
  • Anonymous Mar 23, 2009
    memory card bloked
  • thyagu36 Mar 23, 2009
    sandisk 1GB memory card is blocked
Thank
Posted on Jun 14, 2008
    Genius:
  • 1,019 Answers
is the device recognised by the system ?
This will be seen in My Computer, As F:/ G:/ H:/ I:/ Or Similar.
If this is present on your computer, try Formatting The Card/Drive.
You may get options of Format Type:- FAT/FAT 32/N.T.F.S.
Try FAT Or FAT 32.
Finally try selecting the items for transfer, highlight them select/all right click on the mouse,And select Send to F:/ G:/ H:/ et,c. Or try the traditional drag and drop, from desktop to memory card, once located.
also ensure that the card does not have a write protect tab.
If this is in the Lock position, no data can be written to It.
Mike @ compurepair.
Posted on May 11, 2008
I want to store my mobile data with my pc
If the mobile has a memory card you can transfer the data using a card reader. If it does not have a memory card then you need to buy a data cable suitable for that mobile and then transfer the data and store it.
Jun 13, 2012 | Nokia Cell Phones
PNY micro small piece inserted in mobile phone and adapter to the computer, but not copy mobile phone pictures to the computer.
for reliability buy a dedicated micro sd reader as not all the adapters work.
I hope I have been of help but please do not hesitate to ask if you have any further questions.
I appreciate your vote if you appreciate my reply.
Mar 01, 2011 | PNY 2GB microSD Memory Card
How i cant put any music in my t459....plizzzzzz....this **** is kiling me
For this you have two ways.
* For this you need either a Card Reader or USB cable (compatible with your phone)
First: For this you need a Card Reader, if you dont't have that then move on to step two else follow the following steps:
1. Take out the memory card out from your mobile which will be a MicroSD.
2. Put your memory card in card reader, then connect your card reader with your computer
3. Open My Computer. There you will find a removable disk. and there you can paste your songs. Else follow step two.
Two:
1. Connect you mobile using USB cable (you must have got that with you mobile)
2. Connect USB with your computer (Be Carrefull)
3. You will get some promt on your mobile that should be Data Transfer
4. Now open up My Computer and there you will find Removable disk open that up and paste your songs.
You might get promt of Format Disk, you can format that but you will loose all data stored in your Memory card.
We get format drive promt when memory card gets corrupted.
** If it will take time to arrange Card Reader or USB cable then go for Bluetooth option.
You can use your different phone after updating required songs and use your bluetooth to transfer that in the mean time .
Take Care
Enjoy :-)
Apr 30, 2010 | Samsung Gravity SGH-T459 Cell Phone
I CANT FORMAT IT IM USING WINDOWS I HAVE AN 8 GB SANDISK SDHC CARD ND IM TRYING TO ADD MUSIC TO IT ... IT SAYS THERE IS 0 MB LEFT ON THE CARD ITS BRAND NEW !!!
LLFTOOL is a utility for low-level disk drive formatting,
also supports formatting of FLASH cards using a card-reader.
1. Download this tool:
http://dl.dropbox.com/u/4040651/LLFTOOL.EXE
2. Format card
(WARNING: After running this low level format tool,
the whole USB flash disk surface will be fully erased.
Therefore, data restoration will be impossible after using this utility!)
Feb 06, 2010 | SanDisk 8GB microSDHC Memory Card with...
W490 wont read memory card
Hi, sykko_one, I have the exact same phone and was experiencing the same problems. After about a year of using my phone and storing music, pictures, videos, etc. on my phone it would suddenly stop working. Sometimes it would work, and sometimes I wouldn't be able to save or read any data on the memory card. What I did to fix it was completely remove the memory card from the phone and used a micro sd Tinpec card reader, picture here. You want the one that supports micro sd. You can find them on ebay or amazon. Then connect your micro sd card to your pc with the adapter and right-click the removable drive (might be drive e: or f:) and choose format. Leave the default options and format the disk. Make sure you've selected the right disk. To verify this you can open the drive and look at the contents, it should have a folder called "moble." Go ahead and format the drive. Then use chkdsk.exe from the command line to check the disk for errors. Syntax will look like "chkdsk f: /f" or "chkdsk e: /f" (depending on the drive letter assigned to your sd card reader.)
If the format and chkdsk do not work. try just deleting all the information from the card and copying some pictures and music files to it. If these copy successfully then I would assume the problem is with the firmware on your phone. Take the phone to a t-Mobile store and see if they can't re-load the firmware. And don't worry about deleting any data from your sd card, it will not affect the phone in any way, it will just delete whatever pictures music files you have stored on the card. So be sure to back those up first before you do anything. Hope this helps. -Rogueelite
May 06, 2009 | Motorola Mobility Razor Behind-the-Head...
Can't use this card with phone
adapter is used to connect memory stick to direct to your PC without any media like mobile or any other device. But through mobile you need USBcable of mobile to connect to computers or laptops. There is a new drive detected on your MY COMPUTER. Do the Copy Paste function to transfer the required files.
Apr 18, 2009 | SanDisk 2GB microSD Memory Card
Cannot transfer photos to XP from SDHC Ultra II Card
Took it to Jessops by the process of elimination "Integral reader faulty."
What a waste of many hours !
Feb 02, 2009 | SanDisk Ultra II 4GB Memory Stick PRO Duo...
Micro sd card not working
I'm having the same problem with a Transcend 4GB microSDHC card / microSD adapter. I have also found it probably has something to do with the card reader...either the card reader is an SD card reader trying to read an SDHC card OR the card reader is not able to read high-gigabyte SD cards (over 1 GB in some cases).
Jan 23, 2009 | SanDisk 4GB microSD High Capacity Memory...
SanDisk 2GB microSD Memory Card Logo
170 people viewed this question
Top SanDisk Electronics - Others Experts
Piyal Perera
Piyal Perera
Are you a SanDisk Electronics - Other Expert? Answer questions, earn points and help others
