Question about Amcor Aire AMS121HX Split System Air Conditioner
We have a amcoraire unit that has an F1 code and will not run. Any suggestions?
  • 73 Answers
The F-1 error code is fixed by replacing the PFC # 35 & IPM # 35 circuit boards in the condenser.
We stock a complete line of parts for Amcor systems.
Support@Pridiom.com
201-266-8234 option 2
Posted on Jan 04, 2011
    Scholar:
  • 77 Answers
Unfortunately, Amcoraire went out of business and Pridiom Group purchased the remaining stock on a bankruptcy auction. Pridiom has since quit selling parts for Amcoraire and I have been unable to find anyone that sells parts after many days of searching.
I pulled both the circuit boards (PFC 35 and IPM 35) from my Son's unit and found a burned relay OJE-SS-112DM, a scorched Polypropylene Safety Capacitor (333K 275V 0.033uf 33NF Pitch 15) and another capacitor (450V 560uf 30 X 50mm) on the other board.
No one stateside has these in stock that I have been able to find. I did a search on ebay and found them in China for around $40 including shipping. Problem is it takes 8-20 days shipping from China to the US. Everything nowadays is made in China. I ordered them today and will install them myself when they get here. If you have no knowledge of how to install them you can find instructions on www.ifixit.com.
I am hoping this information will help someone in the future. It is the only way you will be able to repair the Amcoraire units. You can also buy the parts and search for a circuit board repair shop in your area and have them do it. Good luck.
Ed
Posted on May 27, 2016
I have a 12,000 Amcorair mini split. Air handler shut down, popped the breaker. Turned the breaker on. The air handler displays F1 fault code.
Hello I think F1 fault is air filter...If it is clogged it can cause iceing (on the coil) and will trip a breaker.Give a good clean/wash or replace.
Jun 04, 2011 | AmcorAire UCHW-H12AF2 Split System Air...
Flashing F1 display on status window. Unit will not start. It will chirp in response to remote control,but takes no action.
What model do you have, the UCHW model is a 13 SEER and only displays error codes starting with the letter ' E '
Email: Support@Pridiom.com
Nov 09, 2010 | AmcorAire UCHW-H12AF2 Split System Air...
I have an F1 error code. The manual states that this means the inside and outside units are not communicating. What should I look for
F-1-No communicationbetween indoor and outdoor. Comms Error, check your wiring, remove external pumps. Split/Multi - check volts from terminal N to 3 = 0 - 65 Vdc, Multi V - 4 Vdc terminals 3 and 4
Sep 09, 2010 | AmcorAire UCHW-H12AF2 Split System Air...
Hello unit has been running then just stop with F1 showing how can i fix this thanks cameron
The F - 1 error code shows a failure of the PFC & IPM circuit boards inside the outdoor unit.
We stock a complete line of Amcor parts.
Support@Pridiom.com
Aug 03, 2010 | AmcorAire UCHW-H12AF2 Split System Air...
Trying to fix an AmcorAire AMD243HX system F1 code, not working.
We stock parts & have tech support for Amcor Mini Split Systems
Support@Pridiom.com
May 06, 2010 | Inverter AMD243HX ThruWallWindow Air...
WE have Amcoraire Mini split unit heat pumps. One is
P 4 code means problem with the outdoor unit, Most likely low on refrigerant. Check all copper pipe connections for leaks first, then add refrigerant after checking pressures.
Jan 17, 2010 | AmcorAire UCHW-H12AF2 Split System Air...
Amcoraire AOS091HX Dead
had the samething. 2 blown capacitors on that middle board. got new capacitors and system was back online. check out digikey electronics and order your new capacitors. hope nothing else is wrong with the board.
Jan 02, 2010 | AmcorAire UCHW-H12AF2 Split System Air...
Amcoraire / aos241hx / code p8 / unit shut down will not restart
for all error codes. http://www.digelair.net/pdfs/TECHLIT/MITSUBISHI/MrSlim_P-SERIES_Troubleshooting_TIPS.pdf
Jun 30, 2009 | AmcorAire UCHW-H24AF2 Split System Air...
Amcor Aire AMS121HX Split System Air Conditioner Logo
367 people viewed this question
Top Amcor Heating & Cooling Experts
Michael Youngman
Michael Youngman
Tim Whalen
Are you an Amcor Heating and Cooling Expert? Answer questions, earn points and help others
