Question about Dell Inspiron 1525 Notebook
Mydell inspiron 152 wont turn on without being connected to charger and battery wont charge anymore... what can i do?
  • Dell Master
  • 629 Answers
Sounds like you need a new battery. Check if the battery is detected in the BIOS. If yes, attempt to update the BIOS which may include fixes or improvements that can affect battery performance. If this does not work, test your battery on another system if possible to confirm if it is really faulty, once verified, you may purchase a new battery or get a warranty replacement if still valid. For Dell batteries, they have a standard 1 year warranty from the date you got your system.
Posted on Sep 03, 2010
  • 3,940 Answers
Tablet wont charge
The charger has a function that restores the battery operation parameters by discharging then charging the battery a number of times. Refer to charging instructions in the pack but I think the cycle is a 3 hourly one, time to charge from a full discharge. If the charger thinks the battery is dead then it will try to recover the battery using this process. You may have left the charger on long enough to charge then also discharge the battery.
Start again and charge for the time in the instructions ONLY, if you are not sure of the time try it for an hour, then without disconnecting the charger turn the unit on and take particular note of any screen messages, if any.
You should be able to continue as normal now, but still be aware of the time you are leaving the charger connected for, as it may take some time before it returns to normal operation and stops trying to recover what it thinks is a dead battery.
Apr 01, 2014 | Samsung Tablets & eReaders
Our year old Dell Inspiron 1545 currently won't turn on anymore, for the past week it would not charge so we were just keeping it plugged in. It claimed the ac adapter was unknown, even though we had been...
You have a bad or loose DC connector on the system board:
Symptoms of a broken power jack
1. If you wiggle the power cord or the AC Adapter connector on the back of the laptop, the power LED and battery charge LED start to flicker.
2. Battery will not charge in the laptop.
3. Laptop runs fine off a charged battery.
4. With the AC Adapter connected the laptop appears to be dead.
No power LED or battery charge LED activity.
5. Laptop randomly powers off without any warning.
If your laptop is out of warranty, then you can fix the problem by resoldering DC-IN jack on the system board. If it
Dec 16, 2010 | Dell Inspiron 1545 Notebook
Mydell 5160 has a yellow blinking light on the front 1st from right. any suggestion on cause or solutions.
It is the battery Status indicator and flasing orange light indicates that battery is low. After connecting the charger it should turn solid green, which indicates that the battery is charging and it turns off when battery is charged completely.
If it continously blinks, check out the charger and battery.
Dell 5610 owner's manual can be downloaded from:
http://support.dell.com/support/edocs/systems/ins5160/en/OM/G74822LRs.pdf
Check out Page-15
Let me know if any clarification is required
CreativeTECH
Nov 12, 2010 | Dell Inspiron 5160 Notebook
My 1501 Dell Inspiron wont turn on. The charger
The ac power jack needs to be either resoldered or replaced.
Dec 09, 2009 | Dell Inspiron 1501 Notebook
For some reason my Dell Inspiron 1525 wont charge!!. I plug it into the main and the green light comes on the charger lead and it is putting power into the computer but just not actully getting any charge...
This only mean that you have a failing battery and does not hold charge anymore.. battery life can last upto 2years, depending on how frquent you use..
HOpe this helps
Oct 30, 2009 | Dell Inspiron 1525 Laptop
My Dell 1501 laptop turns off as soon as the charger is connected
Sounds like you have a multiple problem going on here honestly. If you have a constant light on your charger even when its completely disconnected from the wall outlet then your charger is bad for sure, cause the light shouldn't come on unless the charger is hooked up to power.
Your battery maybe shorting out the laptop which is why it needs to be taken out for a bit before the laptop will turn on.
My suggestion would be to try a known good working charger on your laptop to make sure it turns on properly and stays on without the battery hooked up.
Then if your laptop stays on for a while then with the laptop on and the charger hooked up, connect the battery again and see if the laptop will charge up the battery to 100%. If it does then disconnect the charger and see if the laptop stays on with just the battery hooked up. It could be that the battery is drained beyond 0% and just needs a good charging. If you can't charge up the battery or the laptop still turns off to where you have to take out the battery to get the laptop to turn on then the battery is bad and would have to be replaced.
Jun 02, 2009 | Dell Inspiron 1501 Notebook
Wont charge or turn on
There two possible hardware problems those are, battery and the system board. Try to isolate the problem by using other charger, if that charger is known good one, and there is a light on the device, then the battery is not holding charge and needs replacement, but if there is no light at all then it is the system board for replacement..better buy new one if you have no warranty anymore. if have problem on other charger. try to plug in to usb cable to your PC.
Apr 21, 2009 | GPS
Dell inspiron 1300 wont work from the AC adapter
Is the laptop working without the battery, directly on AC. Have you tried using another charger or battery to see if its charging.
Jan 28, 2009 | Dell Inspiron 1300 Notebook
NOKIA 6600 wont charge and turn on
hey,
how about check your charger .. maybe there is a problem with your charger... try another nokia charger
Cheers
Aug 28, 2008 | Nokia 6600
Dell Inspiron 1525 Notebook Logo
51 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
