Question about Hisense LHD3206US Television
I have a hisense HSL8129hdi. Have had no problems since i had it but now cannot get any digital signal at all, analogue signal is fine. Hve retuned stations but cannot locate any digital stations at all.
  • 11 Answers
SOURCE: Digital tuning
You'll need to go into service mode and do a factory reset.
To enter service mode you'll need to press these buttons on your remote in the following order:-
Standby-info-menu-mute-standby.You'll need to do it fairly quickly and be patient it doesn't always go into it first time,don't press and hold the buttons.
The service menu should appear on the screen.Use the up /down cursor to scan down to option number 12 (factory reset)and then press the right cursor wait will appear on the screen and the set will go to standby(don't worry this is normal)
Reboot the set and retune and all should be well
Posted on Nov 04, 2007
  • 8 Answers
SOURCE: LG LCD HDTV 'NO SIGNAL'
if it still under warranty get intouch with LG-if not looks like (if its definitely not your input signal) theres a problem on the mainboard- if theres a firmware fix for the issue youll have to look into as there are many forums with ppl who have problems like this
Posted on Dec 18, 2007
  • 1779 Answers
SOURCE: Digital Television sound synchronisation
The pixel problem your having is signal strength related, the sound is always affected first. If your on cable, have them come out and check the signal strength first.
Posted on May 17, 2009
localwonder
  • 6784 Answers
SOURCE: dose my tv (Hisense TL3000) is hd-tv ready
Not all units were fitted with the DTV tuner before the switch over occurred. you set should have an insignia that sates that it is DTV ready. if this insignia is not on the box or actual set, you will need a converter box to receive this DTV signal.
Posted on Jun 21, 2009
  • 6 Answers
SOURCE: no digital yet tried to retune but greyed out.
Just got through to Samsung support. Turns out the freeview card had frozen and needed a reset. To do this put tv on standby. then press in serries these buttons on the remote: 'info' 'menu' 'mute' 'power' TV will then turn on with a default screen. Press 'arrow down' button untill you reach option 12 'reset' . then push the 'right arrow' and tv will reset and start in plug and play mode and commence a scan when you've set the time. Just retuned mine and its back to normal. Hoorah!!! :-)
Posted on Oct 05, 2009
Why do I get no signal on my auria tv set
Was it working recently and then gone wrong. Is there a good aerial with it. Is it analogue, most places broadcast only digital signals now, (at least here in Europe.) If everything is fine in these areas it might be that the receiver has gone. Check as much as you can, try a retune, if it works all well and good. If not then a technician might be needed.
Good Luck
May 27, 2015 | Televison & Video
Auto retune has wiped everything. Help
There is the digital tuner (DTV) and the analogue tuner (TV). Make sure you are tuning the digital side as there are no longer any analogue TV broadcasts in the UK.
Sep 04, 2014 | LG 26LH2000 26 in. HDTV LED TV
Hisense tv HSL8129HDI off standby without remote
Your problem post has not enough details to post a solution. Provide more details about the problem you faces with this TV, please.
Aug 29, 2012 | Televison & Video
I cant retune my proline tv/dvd combo as there is no retuning option in the limited menu.no option to reset on the controller either so have no signal now since swithover.how can i get it to reset anyone?
Some TVs brands - I believe Proline is one of them - cannot be retuned when you are in Digital mode. If you switch back to analogue mode, then press the menu button, the option to auto-scan should be available. Once you retune, switch back to digital mode.
Try this and post back if you need further assistance.
Please rate this solution if you find it helpful. Thanks.
Oct 20, 2010 | Televison & Video
Cannot tune all digital cahnnels on Sharp aquos
Start by doing a factory settings/ defaults on the Sharp rather than a normal automatic retune.This should then be ok. You need to empty the existing presets first so it will find the new type of signal BBC is now using.
If still not working for BBC1 +2 then look at whether you have too much aerial signal strength. (ie a booster/splitter that you could bypass)
Nov 07, 2009 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
On retune, Digital has disappeared, can only see Analogue
Check on the r/c to see if there is a button to switch from analog to digital
Oct 05, 2009 | Panasonic Televison & Video
Since digital switchover yesturday loss of digital channels
It may well be your aerial despite the success with your DVD recorder.
Digital signals are very much weaker than analogue ones, and when multiple devices share a single aerial you can get this kind of problem. You also lose about 60% of the signal at each point in your aerial cable where there are signal splitters.
There are a number of possible solutions:-
First, look at every bit of coaxial cable you have between the aerial and each appliance. Check especially at the aerial end for corrosion or poor shielding/installation and especially for evidence of rain water penetration. If the aerial is on the roof then it will cost almost as much to get the aerial inspected as it will to have it replaced, so skip to the next option. But otherwise, check along every bit of the cable for any cuts or splits in the insulation and properly remake every junction or joint if there are any doubts about them. If the cable is in poor condition then consider option three instead.
The second is to try to see if you get a better digital signal from another transmitter, this will involve trying different aerial positions so is impractical if your aerial is roof mounted but is worth trying if it's in the loft instead. It doesn't always follow that your best digital signal will be from the transmitter which you used for analogue transmissions.
Thirdly, if you're still using the same aerial as you have done for years then it's worth upgrading to one optimised for digital reception. When doing this it's foolish not to replace the cabling as well as you need it to be as good as possible. With analogue, many installers got away with using cheaper cable intended only for very short cable runs from the wall socket to the tv.
The fourth option is the budget option but can work as well as the third option: fit an additional analogue style aerials and run a separate cable down to each appliance. If these are fitted in the loft and you have the space, then there's no aesthetic or planning concerns. Normally the extra cables can run partway down through the house alongside existing cables, but for best signal quality keep them separate and ensure that the cable runs as as short as possible.
One further thing which you may want to try before all else: connect your digital box directly to the aerial cable which currently feeds your dvd recorder. Leave all other tv devices disconnected from the aerial. If the box retunes correctly then it's definitely a supply of signal issue as outlined above and if not then you should add the exact make and model of your digibox as a comment to this answer as there are a large number of earlier digibox models which cannot retune correctly due to evolving standards.
Jul 02, 2009 | Sanyo Televison & Video
May 17, 2009 | Hisense LHD3206US Television
Open Questions:
hisence lcd3206ru By suggsy2007 Rank: Apprentice Rating: 0%, 0 votes Session Date: Sep 16, 2008 jonniewalker: hi jonniewalker: pls describe your problem in details suggsy2007: hi Read more suggsy2007: i have a hisense lcd3206EU and have perfect sound but no picture, i was after locating a service manual or even better a solution suggsy2007: hello? jonniewalker: ok jonniewalker: you just need the service manual suggsy2007: well, if you had a known solution to my problem that would be ideal. suggsy2007: but the service manual would be a good start for now jonniewalker: ok jonniewalker: you can get the manual from here http://www.devicemanuals.com/company/Hisense.html jonniewalker: are you with me? suggsy2007: hi, just lost connection on the live chat...how can we get back to the service manual for the LCD3206EU suggsy2007: i have just re-tried the link you gave me and it is as i say there are only manuals on there in french spanish and german and i think ultimately it returns to the hisense web page, which does not work. Please advise with alternative solution as i was led to beilive that you would have the service manual available, that is why i joined the 'live chat' service as i wanted a swift solution, now i have been kicked out and resorting to an email version. suggsy2007: is there any way to get the live chat session going again. suggsy2007: hello?? suggsy2007: hello?? suggsy2007: hello? suggsy2007: hello? jonniewalker: it seems i lost you but any was the link not useful or helpful? suggsy2007: did you not read the message i posted in the section above.. suggsy2007: i have just re-tried the link you gave me and it is as i say there are only manuals on there in french spanish and german and i think ultimately it returns to the hisense web page, which does not work. i have just re-tried the link you gave me and it is as i say there are only manuals on there in french spanish and german and i think ultimately it returns to the hisense web page, which does not work. suggsy2007: are you still around, any chance of a reply....do you have the service manual to send. if not i would like to claim my 'money back refund' as i am not satisfied with the service..
Feb 26, 2017 | Hisense LHD3206US Television
Hisense LHD3206US Television Logo
301 people viewed this question
Top Hisense Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Electro Med Services...
Are you a Hisense Televison and Video Expert? Answer questions, earn points and help others
