No colour when tv played through aerial - Televison & Video
  • calado1 May 11, 2008
    Sorry, should add more details. Its a panasonic TX-32LX75A, the colour is fine when played through video or dvd, but no colour on aerial
    Sergeant:
    Champion:
  • 346 Answers
Do you mean when it is played through the cable?
Posted on May 13, 2008
Colour loss
Try a reset to this set and check. If it do not help you, contact any service technician. There are two types of reset to TVs. The first is simple to do; a Hard Reset; and the other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight; will be better. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Service mode entry, adjust and exit procedure to many popular brand TVs are given. Never forget to exit the service mode, after all adjustments have been done.
Apr 04, 2015 | Toshiba 32BV700B 32 in. LCD HDTV
Bush TV set up colours look like looking through night vision lenses.
Try to reset the unit to factory default settings.
If the TV is under any kind of warranty, return it while you can.
Also, without knowing what kind of TV, Plasma, ect. it is had to pin point your problems.
Hope this helps
Mar 22, 2014 | Televison & Video
How do you hook up an antenna to a tv?
Optimum reception of colour requires a good signal and will generally mean that an outdoor aerial must be used. The exact type and positioning of the aerial will depend upon your particular area. Your dealer or service personnel can best advise you on which aerial to use in your area. before connecting the aerial cable be sure to turn off all main power switches. in the media recorder you will see an aerial connector one is the input and the other one is the output. your input is the antena and the output goes directly to your tv aerial input.
Oct 24, 2010 | RCA Televison & Video
How to hook antenna to tv?
optimum reception of colour requires a good signal and will generally mean that an outdoor aerial must be used. the exact type and positioning of the aerial will depend upon your particular area your dealer or service personnel can best advise you on which aerial to use in your area. before connecting the aerial cable,turn off all main power switches. vhf or uhf it must first go to the media box and you will see the input aerial cable connect it there and the output go to the back of your tv that indicates aerial input terminal.
Oct 15, 2010 | Maxent MX-42HPM20 42 in. Plasma HDTV
My Transonic LCD tv was connected to the aerial via my video recorder which is now out of order. I connected the aerial directly to the TV but now only get black & white! The DVD channel etc are...
Ok, if all you did was remove the vcr out of the circuit and put the aerial directly to the tv and now the color will not come in. That means your signal is not strong enough to provide a good picture. Some new model tvs have weaker tuners compared to older model tv and vcr tuners causing them to have weak snowy or black and white picture. The idea being most newer tvs are designed for cable or satellite hd use not for aerial use. What you wear doing before was amplifying the signal by running it thru the vrc first then viewing the output on the tv. Get another vcr or amplify the signal with an signal amplifier.
Aug 19, 2010 | Televison & Video
We have a black and white picture on the TV, no colour
check for DVD/TV cable. Use a SCART 21 conductor cable (if possible with gold contacts), or HDMI Cable if Tv has HDMI Input
Nov 29, 2009 | Panasonic DVD-S35 DVD Player
Cannot get colour picture
check tv colour system is correct for your region, this is shown in the tuning menu, adjust if required
May 16, 2009 | Bang and Olufsen Beosound 4000 Shelf...
No colour when digital set top box attached
Ensure the set top box is set to the correct video out. Probably RGB if scart lead or CVBS if coax lead.
Jun 10, 2017 | Sony FD Trinitron WEGA KV-32FS120 32" TV
No colour on television
Hi, It is possible that the reason for the black & white as well as lines across the screen is weak, defective or wrong oriented antenna. If you are hooked up to cable, then it should not be a problem as you can call for service; if on the other hand you are using aerial antenna, you can try to: reorient or adjust the direction to where the antenna is pointed until the reception improves, check the lead in wire (cable or flat) for any breaks or shorts or loose connection, check/clean the connection of the antenna elements to the cable/flat wire, replace your aerial/cable as may be deemed fit and needed. A couple of questions pls if the above does not solve your problem: when receiving from aerial, is the picture full vertically? are you also having problem with sound? If yes, where was the TV bought and where is it being used now? If no, is the image snowy and some channels/stations are better than the others? Good luck and pls post back how things turn up or further information. kind regards.
Aug 12, 2007 | Zenith B25A11Z 25" TV
Televison & Video Logo
29 people viewed this question
Top Televison & Video Experts
