Poor line condition memory Problems with MFC 9440CN
Semi-Driver
  • 434 Answers
SOURCE: our Brother MFC 9440CN laser printer memory, keeps
When Fax Storage is set to On, copies of all received faxes are stored in the memory, thus using up a portion of the memory available for other functions.
The Fax Storage feature is utilized for Fax Forwarding, Fax Paging and Remote Retrieval. If you do not need these features, verify that Fax Storage is set to Off by doing the following:
  1. Press the Menu key on the control panel.
  2. Press the Up or Down Arrow key until Fax appears on the LCD. Then, press OK.
  3. Press the Up or Down Arrow key until Remote Fax Opt or Advanced Fax Operation appears and press OK.
  4. Press the Up or Down Arrow key until Fwd/Page/Store or Forward/Store appears and press OK.
  5. Press the Up or Down Arrow key until Off appears and press OK.
  6. If you have faxes stored in the memory, you will receive a message that reads Erase All Fax? 1. Yes 2. No.
    If you want to erase all the faxes in the memory without printing them out, press 1 (Yes) and then press Stop/Exit.
Posted on Dec 24, 2009
  • 8064 Answers
SOURCE: How to check ink level on brother MFC-9440CN?
Run the Brother Control Center. Click Device settings. Click where it says Inklevel.
A simpler way is Start-->All Programs-->Brother--> ...-->Status Monitor.
An icon will lodge itself on the tray (a printer). When icon is clicked on, the inklevels will show.
Hope it helps.
Posted on Sep 03, 2009
SOURCE: using MagicJack for faxing; however, Brother MFC
I had the same problem trying to send out faxes out using my Brother MFC 7340. I use a magic jack phone line. Page 106 of the user manual says if sending via VOIP phone line, you should press menu, then 2, 0, 1 to select "Basic (for VOIP) mode. Then press ok. Then press stop/exit. This cuts the modem speed down to 9600 bps and turns ECM off. Then retry to send the fax. I did that and can now send and receive faxes.
Posted on Apr 13, 2010
  • 4044 Answers
SOURCE: Poor line condition / out of memory when
That is a problem with your phone line. Get a line filter from Radio shack and install it between your wall socket and the fax. This should solve teh issue.
Posted on Jul 12, 2010
nonontech
  • 4737 Answers
SOURCE: NG: Poor Line Condition / Out Of Memory
This problem could be Phone line problem, or hardware failure or receiver's (the machine of the person whom you are sending the fax) machine problem and so on. First, let's check the line, if you have another Phone line, please dial from the number to your number, also, connect the currently connected line to a receiver and call a Land-line number, if the outgoing or incoming is ok, the proceed forward, otherwise, you telephone operator should check the line.
Sometimes, sending fax to a particular number doesn't work, to make sure, try sending a fax to another number.
If the line which is connected to the machine is extended from another machine such as Receiver, Switch, etc... unplug them and connect the fax machine directly to the Line.
It's also important to adjust the compatibility mode, to do this, follow the steps below:
  • Press Menu.
  • Press the up or down arrow key to select Fax.
  • Press OK.
  • Press the up or down arrow key to select Miscellaneous.
  • Press OK.
  • Press the up or down arrow key to select Compatibility.
  • Press the left or right arrow key to select Basic (for VoIP).
  • Press OK.
  • Press Stop/Exit.
If you place the scanning document/file on the auto-sheet feeder, you can help it pulling inside the passage or you can use the glass (flatbed) instead. Sometimes, this small mistakes with the sheet-feeder creates this problem. You can also clean the rollers inside the ADF (auto document feeder) passage.
If all of the above measure don't help, I would suggest you to call brother and seek their help. The rest is with mechanical or we can say hardware or firmware related issue. (use this form to contact Brother)
I wish you good luck.
Thanks for using FixYa.
Posted on Aug 15, 2010
OUT OF MEMORY
Hello laray7813,
Please visit this link to know exactky what NG means and how to solve it.
http://welcome.solutions.brother.com/BSC/public/us/us/en/faq/faq/000000/000200/000009/faq000209_000.html?reg=us&c=us&lang=en&prod=mfc420cn_us&Cat=12
If this dosent work, let us know and we will find other solutions,
Dahaka
Jul 22, 2008 | Brother MultiFunction Center MFC-440CN...
Mfc-9840cdw scan poor line condition out of memory - how can this be solved. i feel so dense because it appears your site has already offered solutions but i can't even find them there!
Poor line condition / out of memory is almost always caused by poor line condition.
This is to say that there is a problem trying to send because the signal is not going through clearly enough.
This error can be due to either your fax machine or the receiving ends fax machine.
Try sending to other numbers as a test to see if it works for other numbers (you can use 1-866-685-8587 for the brother test line)
If you get the same error no matter who you send to, you may want to try another jack or telephone cable.
If you are using a splitter, try without the splitter.
Thanks,
Pat
Apr 01, 2010 | Brother MFC-9840CDW Laser Printer
Trying to send a fax error: Poor line condition/ Out of memory
Make sure by making a copy that your scanner is OK, streaks or black bands won't send properly and you need a new scan assembly, Poor line condition is just that, you need a better line or cable, If you go to fax settings and turn off error correction mode it sometimes helps as well.
Feb 01, 2010 | Brother MFC-8460N All-In-One Printer
Our MFC 7840 printer when faxing keeps saying
Depending on your location the line coulod well be poor quality for a sensitive fax. Any spurious sounds on a fax line will cause it to fault.
May I suggest you try the fax on the mainline first before assuming the unit is at fault.
Length of line from point a to b can also reduce the efficiency of signal. It may sound ok to the ear, but resistance may be the factor in reducing the level of the tone that the fax requires to hear and then activate send or receive.It reports poor line condition and even poor memory because it keeps loading to send.
If it does it on the mainline as well then I would be considering a technical call for help. There may be a fault in the unit.
please rwte my help++++Thanks for using FIXYA
Nov 24, 2009 | Brother MFC 7840W Printer
MFC-440CN PRINTER fax error
Plug a phone into the line and listen for static. Too many phones on the line, bad lines,etc, can cause a poor line condition. Try the unit directly into the phone line, no answer machine or anything else on the line. Maybe the memory thing is it has a lot of faxes that it hasn't been able to send.
Apr 29, 2009 | Brother MultiFunction Center MFC-440CN...
Will not fax
how do i find my fax number on my mfc-440cn?
Sep 09, 2008 | Brother MultiFunction Center MFC-440CN...
Printer MFC 420CN
Click HERE to read previous suggestions to this problem.
Jun 01, 2008 | Brother MFC 420CN All-In-One InkJet...
94 people viewed this question
k24674
jasbo
jasbo
