Question about Frigidaire ATF6000ES Front Load Washer
We have a Model QTF1670A50 washer. It had been stacked with a Frigidaire dryer. We now have the washer and dryer side by side. The top of the washer is loose and we have lost the part that would secure it to the top of the washer. Ruby Murphy rjm839@smunet.net
    Brigadier General:
  • 3,917 Answers
Hi
Please check this link bellow to order the parts of the washer:-
http://www.partselect.com/Frigidaire-Washer-Parts.htm
Please accept the solution if it’s helpful. Do get back to us for any further query.
Thanks for contacting fixya.com
Posted on Sep 03, 2010
I have a Frigidaire front loading washer, model FTF530FS3. The dryer that is stacked on top of it just quit. I have discovered that the new model of the dryer for this type, now called Affinity is slightly...
I would bet the manufacturer has an adapter for just this kind of problem. I did an installation on a stacked unit with a similar situation and there was an offset angle piece that attached the base of the dryer to the top of the washer. The front had a molded plastic piece to allow the dryer to rest on the front of the washer. Hope this helps
Oct 18, 2013 | Frigidaire FEQ332E Electric Dryer
I want to try to put my washer (Frigidaire FTF model) on top/bottom of my dryer (also frigidaire). However, we didnt receive any brackets which are standard for stacking, so we are curious to how to stack...
Hello the advice about removing the top of the washer and bolting the dryer to it is exactly what to do.Under the washer top is built in brackets to do that.Every front load Frigidiare washer leave the factory pre-equipped to stack the dryer to it by removing the top and bolting the dryer to it
Aug 21, 2011 | Frigidaire FTF530FS Front Load Washer
I am trying to find the right dryer belt for FEX831FS1
available through sears but the part number is
134503900
16.00 dollars
Oct 09, 2009 | Frigidaire FEX831CS Top Load Stacked...
Need a stacking dryer that vents from the top
rear and side vents only option no machine top vents. although you can gain acces to venting through the middle panel on that unit for slightly easier mounting
Dec 04, 2008 | Frigidaire FEX831CS Top Load Stacked...
How to stack w/d gas Frigidaire Gallery dryer
You are supposed to remove the top of the washer, and the dryer feet lock into brackets...but being lazy I just bolted the dryer to the washer using some metal straps (1/16" x 8 x 4 ") with some machine screws, and it's been fine for years. Not pretty, but I had the same question and no handy internet to help me at the time ;P
Apr 08, 2008 | Frigidaire GLGQ642A Gas Dryer
Stacking Frigidaire dryer on washer using stacking kit 5303937141
You have to take the top off the washer a put it aside. You no longer need the top. Then you put the two angle brackets on the front top of the washer. this is where the front of the dryer will attach. The back of the washer either has or needs the brackets put on the top (been a long time since I did this). Remove the leveling legs from the dryer. Then lift the dryer and slide it on top of the washer with the back touching the top of the washer and the front about 2 inches higher than the washer top. The back of the dryer slides into the back brackets which are on the top back of the washer. Then lower the front of the dryer and the two "L" brackets on the front top of the washer slide through cracks into the dryer. Pop off the two plastic plugs on the dryer bottom front and place a screw in each one to hold the unit in place. Replace the plastic caps and you are done.
Dec 29, 2007 | Frigidaire FEQ332E Electric Dryer
Directions on stacking dryer on washer
get a stacking kit from your local appliance strore that sells frigidaire. they ARE EASY TO STACK WITH THE KIT.
Nov 12, 2007 | Frigidaire GLTF2940ES Front Load Washer
Frigidaire ATF6000ES Front Load Washer Logo
18 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
