A very stale odor is coming from this unit when it is not in a fully engaged cooling mode.
  • 24 Answers
What type of unit is it? Window, wall unit, or split system?
Do you smoke? It could be a number of things.
Posted on Sep 04, 2010
Why does heat quit blowing hot air when I slow down?
2013-2014 Ford Escape Poor A/C Performance Quick Fix ...
? 3:18
www.youtube.com/watch?v=k0EToZjmTO8
Sep 3, 2014 - Uploaded by FordTechMakuloco
I have a 2011 ford escape usually only blows warm air, from time to time I ... cold air , and then a decide to blow out a warm or hot air , That have an humid , stale odor ) . ... Fast forward 3 months and the ac will quit working all together . ... noise again but would die down in a few seconds after engagement.
Oct 19, 2015 | 2014 Ford Escape SE
Inside cab blows out hot air controls are off but air still comes out
OUTSIDE AIR: Press this button to direct the system to use outside air.
Pressing the OUTSIDE AIR button will cancel the RECIRCULATION button.
RECIRCULATION: Press this button to limit the amount of outside air entering your vehicle.
This is helpful when you are trying to limit odors entering your vehicle or attempting to quickly cool down the interior. Pressing RECIRCULATION will recirculate air continuously.
RECIRCULATION is used when the fan control is OFF to limit odors, outside air and dust from entering your vehicle. All button lights will go off. The last setting selected will activate when the blower is turned back on.
Pressing the RECIRCULATION button will cancel the OUTSIDE AIR button. To return to normal operation and to prevent stale air, be sure to return the OUTSIDE AIR.
Between HEATER and BLEND mode, outside air is forced to reduce window fogging. If the RECIRCULATION button is pressed, the LED indicator will flash three times indicating that forced outside air is activated and RECIRCULATION is not available.
I think what your experiencing is normal. If you want to keep cold air form coming into the cabin, press the recirc button.
Aug 23, 2014 | 2001 Chevrolet Blazer
Environizer doesn't work
Is it dead? does the motor run? Fan blow? No freshened smell from unit, only stale odor? You haven't given any usable info here but I'll address a dead unit condition for you: power cord stretched/damaged, on/off switch bad, fuse/cicuit breaker(if any are used).
Jun 15, 2014 | Air Purifiers
A stale water coming from inside. What could i "run"through to get rid of the smell Regards Sally
Your local home depot sells a product called AFFRESH. This product is supposed to be used on all front load washing machines and can also be used on top load washers as well. They make two types of this product one is for washing machines and the other is for dishwashers. You basicly add one of the tablets to your machine on the hotest setting and run the machine without any clothes inside the unit. It takes away the smells such as stagnant water smells and can also remove mold smells as well inside of a washing machine. Sometimes I find for stronger odors it is best to use two tablets instead of one and run both cycles one after the other. Also how high is your drain line in the unit set at. The drain should be about 6 inches above the highest point of the machine for best results on the machine emptying the water out of the unit. If you have any further questions message me back and please also remember when our chat has fully concluded to rank how this opinion has helped in your appliance situation it allows me to continue helping others in similar situations in the future. Thanks
Rick
Aug 23, 2011 | Washing Machines
You know, it smells stale. What can I do about the odor? I didn't want to come out and say it "smells like ****."
Pull the panels on the unit look at the drain pan you will probably see a lot of stagnet water turned moldy you can remove this by flushing the drain pan. Also using simple cleaner to freshen up the unit. You can buy some evaporator coil cleaner that requires no rinsing to clean the coil that will freshen it up a bit.
Jun 27, 2011 | Convair Portable Air Conditioner
My refrigerator has a stale odor evertime the door
poss drain hole/vents blocked clean vents with bicarb,drains with clorine bleach(rinse afterward)
smell is your f/f making its own penicillin
Mar 04, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
Odor problem in refrigerator section. Have thoroughly cleaned but odor is still there. Refrigerator is a Kenmore elite cold spot purchased 3-4 years ago. It is a 2 door with exterior ice and water.
clean out drain holes with clorine bleach(do not use to clean inside unit)poss smell stale wet carpet ???
black gunge is streptococus.....grow your own penn...
Feb 11, 2010 | Refrigerators
When motor comes on there is a stale,odor
check around the compressor area and the drain pan there might be a mouse or something dead under there make sure to unplug the fridge before you go messing around back there
Jul 11, 2009 | Kenmore 50522 / 50524 Side by Side...
Foul odor from back area of fridge/Kenmore bottom freezer
I had the same problem, but just fixed it. I have a maytag bottom freezer and when the fan blower comes on, there was a foul/stale smell that permeated the kitchen. There is no drip pan that I could remove to clean.
I just removed four screws from the back cover of the fan blower area, reached in with a small cup of organic odor remover and poured it into the drip pan just under the fan blower.
Any odor remover would work. probably vinegar or enzyme odor remover would work, too.
I now have fresh smell when the fan blower comes on.
Jul 03, 2009 | Kenmore 50522 / 50524 Side by Side...
Changed the 2 cabin air filters but bad odor still comes out vent
If you run your Air cond on recirculate always try using an air sanitizer in your return vent. Or switch your A/C to outside air flow for for half an hour and raise the rear of your sunroof panel to vent the stale air do this till the smell dissipates and then close he sunroof and reset the A/C to recirculate if desired.
Jun 30, 2009 | 2008 BMW 528i Sedan
Heating & Cooling Logo
44 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
