Question about Weiser Lock Powerbolt 1000 Lock
I was changing the batteries. Now the bolt retracts when you push "lock" and Locks when you put the the code. How do I fix this reversal function problem?
  • 963 Answers
Here is a link to the Frequently asked question page for your lock:
http://www.weiserlock.com/Support/Faq/50160000000HhmZAAS.aspx
I have installed your Powerbolt, but when I push the Lock Button, it unlocks? What should I do?
First remove the cover on the inside of the Powerbolt unit. On the right hand side under the batteries, you will notice that is says "Door Direction Jumper". If the cap is mounted on Prongs 1 & 2, carefully remove it and move it over so that it mounts Prongs 2 & 3. A is right handed, B is left handed.
Here's a link which tells you how to remove the cover, and reprogram the lock codes:
http://www.weiserlock.com/Support/Faq/50160000000HhhZAAS.aspx
Posted on Mar 05, 2011
Schlage BE365 CAM 505 opens with top pushbutton, without entering pass code
The BE 365 is out of sequence. When it was installed the bolt was in the throne position. Take the battery out and allow it to reset and reinstall the BE365 with the bolt retracted. We sell these and other Schlage keyless entry locks at Factorylocks.com. This is a frequently asked question. We hope we fixya!
Sep 21, 2013 | Locks & Locksmithing
How do I lock the door with the key pad? I can unlock it fine but I can't get the door to lock. Don't have the manual. what buttons to I press?
Push the Lock button on outside touch pad to extend latch bolt 1" which locks the door when you leave.
Enter your desired personal code to retract the latch bolt completely which unlocks the door when you return home.
The T-turn on the inside of the door is used to extend (lock) or retract (unlock) the latch bolt when you are inside.
Using the key from the outside will also extend (lock) or retract (unlock) the latch bolt.
This Touchpad Electronic Deadbolt should be accompanied by a Kwikset Knobset, Leverset, or Handleset.
I cut & pasted the above from the installation instruction sheet.
Here is the link to the entire installation instructions sheet (manual):
http://s7d5.scene7.com/is/content/BDHHI/40486-02
It is a .PDF file, so if you aren't able to view it, download and install Adobe Reader from this site first:
http://get.adobe.com/reader/
If you are not able to lock the door using the outside touch pad's lock button, you may need to reprogram the door's "handedness", which gives the lockset the ability to be used on doors that have their hinges on either the right or left side of the door (right-hand or left-hand door).
The instructions for that are found on Step 4.9. This is also an excellent time to change the batteries, which is recommended yearly.
Aug 01, 2011 | Kwikset 907 907-15 Satin Nickel Powerbolt...
I have to punch in the code twice to retract the bolt, new batteries installed, no change!
Be sure the bolt is able to move freely. After the first try, does the lock try to move the bolt?
If it behaves like the wrong code was entered, the keypad might be part of the problem.
Jun 29, 2011 | Weiser Lock POWERBOLT ELEC DEADBOLT
My Kwikset Electronic Deadbolt is working in reverse. When I push the lock button it retracts the deadbolt. When I put in the access code it extends the deadbolt. What is wrong?
My lock did not have jumpers, but adjusts itself automatically... You have to hold the lock button in (on the exterior side) while you insert the battery pack - the deadbolt will cycle in and out, then beep a couple times. You'll be holding button for maybe 10 seconds.
I have to say while this step is included in the instructions in a big red box, it says nothing about why or what its doing, so I imagine many people miss this...
Mar 05, 2011 | Kwikset 907 907-15 Satin Nickel Powerbolt...
To unlock the bolt no code is needed... just by pushing the lock button it unlocks what do i have to do to make it function proporly
You need to reset the lock, so it will be set to the correct handing (left or right hand door).
Open the door and extend the lock bolt. Remove the battery. Press the reset button three times and wait 20 seconds. Push and hold the lock button, while inserting the batteries. Hold the lock button until the bolt starts to move. Allow the lock to complete it's learning cycle.
Program a new code and test.
Jan 09, 2011 | Kwikset 909 909-15 Satin Nickel Smart...
Brought new keyless dead bolt. Put it in a door that opens in with hinges on right side. The problem is that the motor wants to turn the dead bolt the opposite direction, unlock extends deadbolt,...
My lock adjusted itself automatically... You have to hold the lock button in (on the exterior side) while you insert the battery pack - the deadbolt will cycle in and out, then beep a couple times. You'll be holding button for maybe 10 seconds.
Aug 25, 2010 | Kwikset 909 909-15 Satin Nickel Smart...
When I enter my code the bolt only retracts 75%, leaving the door still secured.
Try pulling or pushing the door in while you lock and unlock, sounds like the bolt is binding in the door frame, comon problem with these locks in changing temperatures and humidity.
Feb 21, 2010 | Weiser Lock Powerbolt 1000 Lock
Aside from the possibility of the unit "losing its marbles" the only thing I could think would be to reverse the handing by moving the jumper from Pins 1&2 to Pins 2&3 or vice versa... see what effect that has. And if still not working, see what effect it would have to move the jumper back to its original position.
I might also try letting it sit overnight without the batteries in it.
Jan 28, 2010 | Weiser Lock Powerbolt 1000 Lock
Center button unlocks insted of locks code locks insted of unlock
Take off the inside cover and move the door direction jumper over one pin.
Jan 22, 2009 | Weiser Lock Powerbolt 1000 Lock
Weiser Lock Powerbolt 1000 Lock Logo
118 people viewed this question
Top Weiser Lock Locks & Locksmithing Experts
Jim Goldsmith
Jim Goldsmith
john h
Are you a Weiser Lock Lock and Locksmithing Expert? Answer questions, earn points and help others
