Question about Casio Triple Sensor Pathfinder PRG60-1AV Wrist Watch
In the compass mode the diplay reads "RECO" What does that mean?
2 Suggested Answers
SOURCE: compass comes up with RECO, what does this mean?
If you use the backlight of the alarm a number of times during a short period, RECOV appears on the display. After some time, battery power will recover and RECOV will disappear, indicating that the above functions are enable again.
Posted on Mar 27, 2010
What does RECO mean when I hit my compos function on my pathfinder? Everything else works. Cannot find my manual that came with the watch. Thanks much and sorry to bother you. John
I believe the RECO refers to the NIST time signal that the watch receives at about 2-3am to reset the time. If you're not in North America then you can somehow set the NIST signal to another signal in JAPAN or GERMANY although those signal may be WRONG as those signals are based on sand-filled hour-glass bottles in those countries.
Aug 09, 2017 | The Watches
I just bought the Casio SGW500H-2B Mens Twin Sensor 100M Digital Sports Watch Compass Thermometer. My problem is the digital readout in compass mode reads fine but the needle/ second hand points to east...
To fix this, hold down the A button for 4 seconds. this allows you to recalibrate the home position of the second hand. My secondo hand was posting exactly 90 degrees west in compass mode, and this home position recalibration fixed it 100 percent.
Sep 11, 2013 | Casio Watches
I have a tcm 217362 watch with a digital compass how can i set it up to show me north it currently shows cal. and when i press the top right and left button it shows err.(probably error) it is a black and...
Hi john30x,
You have to calibrate the compass.
1. Press the upper right button (switching to compass mode)
2. Press and hold upper left button. The "CALL" will appear on the display. You are in compass calibrating mode.
3. Rotate the watch horizontally (around his vertical axis) slowly, so to be sure that he point the North at least 2 times.
4. Now press the upper left button again to input the
declination (this is the angle between the magnetic and real pole). It is different for the area around the world, that you want to explore.
5. Switch between the positions of the cipher by pressing bottom left.
6. Change the cipher by pressing bottom right.
7.
Switch between the active position by pressing bottom left. Now you have to enter East or West declination
8. If you are ready press the upper left. "END" of calibration will appear on the screen
Once you calibrate and set the declination you can use the the compass by pressing upper right button. As the compass is very sensitive It is good idea to calibrate it on a field, far away of metal objects and electromagnetic fields (cables, ect.). You need to calibrate the compass each time you want to use it by different surrounding.
Remember the compass function of your watch need much more energy than the watch itself. Don`t worry to change the battery when dead. The water resistance remains good even after. Very robust and accurate device. I hope that should help.
May 15, 2011 | Watches
Compass comes up with RECO, what does this mean?
Mar 20, 2010 | Casio Triple Sensor Pathfinder PRG60-1AV...
I have a PAG40 model and sensored functions are not reading. all it shows is "RECO" on top
It may help if you check my tips and tricks. Find CASIO manuals/instructions there and see if it works.
Jan 23, 2010 | Casio Pathfinder PAG40B-2V wristwatch
My Casio Pathfinder PAG-50 when I go into compass mode shows ---* is there a way to set the compass?
http://world.casio.com/wat/download/en/manual/
Use the four numbers on the back of your watch and you will have a PDF version of your instruction manual.
Hope this tip helps.
R/
David
Jan 01, 2010 | Casio Pathfinder Triple Sensor PAG501V...
Compass wont work correctly
if your hands aren't straight when you use the compass try this to sync the hands.
1. Press and hold the middle button to enter T-Touch mode.
2. Press the centre area on the face twice to display 24hr/12hr
3. Press and hold the middle button to enter T-Touch mode untill screen says sync.The hands will face 1200.
4. Press either the upper (East) or lower (West) button to adjust the compass hands. They should both face 1200.
5. Press the middle button to get back to 'regular' compass mode. Note that your offset setting will still show in the digital area.
Oct 10, 2007 | Tissot T-Touch T33759851
Casio Triple Sensor Pathfinder PRG60-1AV Wrist Watch Logo
90 people viewed this question
Top Casio Watches Experts
Kazim ERGUNEY
Kazim ERGUNEY
Ansel Alberto
Ansel Alberto
Are you a Casio Watch Expert? Answer questions, earn points and help others
