Question about Whirlpool Dishwashers
Hi there Why is my dishwasher not letting water in? I switch on the machine as normal and all sounds perfect except no water is entering the machine?
  • 1,170 Answers
The most common problem is with the water valve. It may be defective, and hence not letting enough (or any) water in.
Posted on Sep 03, 2010
The water is not entering the system but will drain away. All the normal lights are on except for the water.
Here is a tip that will help you to find out why water will not come into thedishwasher...
Dishwasher Trouble No Water entering Dishwasher
heatman101
Sep 16, 2010 | Neff Dishwashers
When i start my dishwasher it sounds like it is filling normally then error lights 1 &3 (3h&9h) flash rapidly and water begins to drain away
This indicates an error with the pressure switch and indicates that it is jammed on full. First try switching off ther AC power to the washer and letting it stand for 30 minutes. Then switch back on the AC power and see if the error is still present. If it is then the pressure switch will need to be replaced. The pressure switch is how the machine determines how much water there is in the machine and if the switch is indicating the machine is full it will automatically pump and empty as soon as new water enters the machine.
Nov 10, 2009 | Indesit 18 in. D41 Slim-Line Free-standing...
No water seemes to be entering the machine. It
it could be the inlet valve. that is definitely a DIY job. but first i would check out the float inside the machine. if it is stuck in the up position, no water will enter the machine. it will assume that it is already full of water. look for a small hat or cone on the bottom. make sure that it slides freely up and down. if it was stuck up, you will have just freed it and solved your problem. good luck
Nov 01, 2009 | Electrolux 23 in. ESI602 Free-standing...
Water not going into dishwasher
There's no water entering the machine If there's no water entering your dishwasher, check these:
Water Inlet Valve
Float switch
Water-inlet valve The water-inlet valve lets water enter the machine. If this valve is defective, you need to completely replace it. It's usually located behind the lower access panel on the left or right side. It's the device with the main water line (usually copper) from the house, a rubber tube to the dishwasher, and two wires attached to it.
Float switch The float switch is a small electrical switch that's located right below the dishwasher "floor." Above the switch, on the inside of the dishwasher, is a plastic cylinder that floats up as water fills the dishwasher. If this switch is defective, or if the plastic float gets caught or trapped in the raised position, the water can't enter the dishwasher. If the float switch is defective, you need to replace it.
Hope i helped you.
Thanks for using "Fixya".
Jul 01, 2009 | Maytag Dishwashers
Water not coming into the dishwasher.
Water-inlet valve
Float switch
Water-inlet valve
Float switch
good luck......
Mar 28, 2009 | GE Dishwashers
Washer will not start
Water-inlet valve
Float switch
Water-inlet valve
Float switch
Good luck.....
Mar 28, 2009 | Jenn-Air Dishwashers
Dishwasher not filling all the way,
hi,
Water-inlet valve
Float switch
Water-inlet valve
Float switch
good luck.........
Mar 28, 2009 | Kenmore 24 in. 15689 Built-in Dishwasher
Dishwasher not filling with water
hi there,
Water-inlet valve
Float switch
Water-inlet valve Thewater-inlet valve lets water enter the machine. If this valve isdefective, you need to completely replace it. It's usually locatedbehind the lower access panel on the left or right side. It's thedevice with the main water line (usually copper) from the house, arubber tube to the dishwasher, and two wires attached to it.
Float switch Thefloat switch is a small electrical switch that's located right belowthe dishwasher "floor." Above the switch, on the inside of thedishwasher, is a plastic cylinder that floats up as water fills thedishwasher. If this switch is defective, or if the plastic float getscaught or trapped in the raised position, the water can't enter thedishwasher. If the float switch is defective, you need to replace it.
Dec 10, 2008 | Dishwashers
The machine is not taking any water in
First check the water supplies at the back of the machine.
That is either a problem wit the inlet valve , or with the water level switch.
See the following suggestions from Repairclinic:
Water-inlet valve
Float switch
Oct 10, 2008 | Zanussi Dishwashers
Ariston dishwasher
Water-inlet valve
Float switch
Water-inlet valve
Float switch
Mar 01, 2008 | Ariston Technologies LI640S Dishwasher
Dishwashers Logo
32 people viewed this question
Top Whirlpool Dishwashers Experts
Oloyede Monsuru
Mike
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
