Question about Adobe Photoshop 7.0 for PC
RAM memory and Adobe Photoshop 7
I was normally working on my Adobe Photoshop 7 and suddenly at next session the computer rejects to initialize this programme giving reason of not enough RAM memory despite my computer having 256 MB of RAM, and though I have not kept anything unsaved on my computer. Why this problem, can you help me.
  • aaron irving May 11, 2010
    Have you installed any other software since the last time you ran photoshop 7 successfully?
    You will get much better performance with a faster system aswell.
Please check if it is written "low virtual memory".
then use any cleaner software which help to increase the virtual memory of your computer.
And if the problem accured in your ram then tell to your hardware person.
Posted on May 15, 2008
  • 202 Answers
The solution is to increase your virtual memory size...
Considering Win XP SP2 system.. the following procedure may be used to increase ur virtual memory / page file size...
Right click 'My Computer' --> Properties --> 'Advanced' Tab --> 'Performance' Settings --> 'Advanced' Tab --> 'Virtual Memory' Change --> Type in a custom size of 1024MB or something like that (not too much) --> Press 'Set' --> Close the windows --> restart -->DONE!!!
I hope that this solves your problem
Have a nice day
Posted on May 13, 2008
Photoshop 5.5 r6025 error web
If the operating system is windows 7 or above the XP software will not run, it has to be compatible with windows 7 up.
Apr 20, 2017 | Adobe Computers & Internet
How to Increase your error undo ability on Adobe Photoshop CS2
By default this is set to 20 which in my experience is not enough you can increase this to a maximum of 99 however 50 should give you what you need under normal use.
Press <CTRL> + <K> to get to the General Preferences.
It is a good idea to save the adobe file every couple of hours or so with a different incremental number of the same file name, this will ensure that you don't loose your precious work.
Also press <CTRL> + <8> to get into the Memory and Cache screen whilst in the previous menu to set the Maximum Memory for use with Photoshop to about 70% of you available RAM
With 1GB of RAM this works out to be 635MB as about 100MB is already used for system processes running in the background.
on Jan 06, 2010 | Adobe Photoshop CS2 for PC
Adobe Photoshop Elements 3.0 Error problem out of memory
Without your computer specs, it is hard to judge if this is a bug in Photoshop Elements 3.0 or your system causing the issue.
If you are using Windows 7/Vista, please press Shift+Control+Esc to enter your task manager while running Photoshop Elements 3.0. Click Performance. Under Physical Memory, view the "Available." If this number is low, saw under 1,000, your system most likely needs more RAM. In Windows XP, press Control+Alt+Del ONCE to access your Task Manager.
Feb 26, 2011 | Adobe Photoshop Elements 3.0 for PC
Photoshop Elements 7 won't open on my PC laptop
Try this, in windows services, set flexnet licensing to manual and start it. Try opening PSE again.
Aug 23, 2009 | Adobe PHOTOSHOP ELEMENTS 7 for PC
Serial number for photoshop elements 7
Try calling the company and tell them you bought the program and the serial no. doesn't work. If that doesn't work do a your favorite search engine serial for photoshop elements 7. Warning, do this can cause harm to your computer, with adware, mailware.
Aug 09, 2009 | Adobe Photoshop 7.0 for PC
Adobe Photoshop Elements 7 Editor "stops working"
Even though this says Elements 6, it still works for 7. The only difference is the TWAIN file is at: C:\Program Files (x86)\Adobe\Photoshop Elements 7.0\Locales\en_US\Plug-Ins\Import-Export
Jul 15, 2009 | Adobe Photoshop 6.0 for PC
After years Adobe Photo Deluxe 2.0 will not open. I added more ram and now when I try and open Adobe it tells me I don't have enough RAM to open. Frustrated!!!!! It is the only photo program I have
I had the same problem and an angel sent me this instruction and I solved it. Hope it works for you as well:
-Control Panel
----"Advanced" tab
-----Performance: -->Settings
------"Advanced" tab
-------Virtual Memory: -->Change
--------"Custom Size: (change it to) Initial: 4000MB Maximun Size: 4095MB
-------------OK everything out
***Restart your PC
Apr 22, 2009 | Computers & Internet
HP4650 suddenly printing very slow from Adobe Photoshop
Turn the printer off then back on or download a new driver from hp web site.
Jan 16, 2009 | HP LaserJet 4650n Printer
Unable to Open
I'm sorry but the only way you're going to be able to use CS2 is if you either use less programs on the computer so that you can open it without the error message coming up, or downgrade back to Photoshop 4.0 or buy more RAM for your computer. Adobe Photoshop requires quite a bit of RAM so really, it would be wise to upgrade if you want to continue using their products.
Oct 09, 2008 | Adobe Photoshop CS2 for PC
Photoshop 7 won't open
Hi there heepslaven,
Quite a dilemma. You need to be in Photoshop to adjust the memory preference settings. The memory preference settings prevent you from getting into Photoshop. Catch-22.
The solution: Change the settings through the .ini file.
Important: If you have questions or need clarification at any point, stop and ask. You are my eyes, I want you to understand the process. OK?
Just to clarify a few things (to rule out other possibilities), please respond with the answers to the following:
  • This just started happening? (No recent changes or upgrades to 7.0?)
  • What is the size of your hard drive? (Right click the drive icon in My Computer and select Properties. It will show a pie chart. I'm looking for Capacity)
  • Same place, What is the available space?
  • Any other recent events that might have something to do with memory usage or disk utilization? (even remotely possible)
  • Ram - How many megabytes (Giga?)
  • Are you comfortable navigating with Windows Explorer?
OK, The objective:
  • Find the initialize file (.ini) that Photoshop uses to save its settings (general preferences, memory, file locations, etc.).
  • Once found, change the default settings, specifically those involving memory usage, errors and so on.
  • This should allow the application to complete its initialization.
  • The changes: Either you can do it with notepad or you can copy and paste it into a comment back to me. Then I make the changes which you put back into the file. Which ever, I prefer to see the whole file, in case something else catches my eye. Don't worry, it's pretty short.
Sound good?
Get back to me with the answers and we can begin.
Aug 16, 2008 | Adobe Photoshop 7.0 for PC
Adobe Photoshop 7.0 for PC Logo
217 people viewed this question
Top Adobe Computers & Internet Experts
Are you an Adobe Computer and Internet Expert? Answer questions, earn points and help others
