Question about VIA ASRock K7VM3 Socket A/ KM266PRO/FSB333/DDR333/A&V&L/Modem/MATX MotherBoard (MOTASR09)
K, now it wont boot from disc
One problem after the next...so do i need to install rom on my other pc to update the driver? because i set boot sequence, and it boots, but ignores xp disc and shows, boot error, no boot record and insert media and such....
  • ■P?G?■ May 11, 2008
    o its all new hardware too... =)
  • ■P?G?■ May 12, 2008
    ya, i set boot sequence so cd's boot 1st, and HD 2nd, still no boot from disc happening. so, what we have is a problem with the rom not reading the disc...does the "quick boot" option have anything to do with that?
    Problem Solver:
  • 16 Answers
CHECK IF YOUR CD IS BOOTABLE BECAUSE SOME UPDTE CD'S AND ORIGINAL ARE NOT
AYADI
Posted on Jul 17, 2008
    Genius:
  • 3,422 Answers
Try this out hit f2 repeatedly with the disc inserted when u restart ur pc get into the BIOS screen and select Boot in that select primary boot as cd/dvd drive then save and exit.Now it should restart and boot from the disc..
Goodluck..
Posted on May 11, 2008
My dell latitude c400 will not boot from external cd rom or the brand new hard drive i need to put windows xp on it but it will not boot from anything can you helpnow i have found i have no drivers...
try other known good windows installer. if it boot, then the problem is in xp installer, if it not. try other external cd-rom drive. also be sure the disc rom drive are dvd rom drive because a cd rom drive cannot read dvd disc but a dvd rom drive can read cd rom disc installer
Feb 15, 2011 | Dell Latitude C400 Notebook
CD Rom does not work HELP!
Typically these drives don't need an extra driver, as windows detects them automatically. The first thing I'd recommend trying is to right click it's entry with the exclamation mark and uninstall it. Once uninstalled, reboot the pc. It should install correctly then. If it doesn't, there may be an issue with the IDE controller it's connected to (usually a bios setting determining raid/ide mode).
Feb 23, 2008 | Lite On LVW-5115GHC+ DVD Recorder
How do I install install Windows 7 to my Acer aspire 5630
Purchase Win7 System Disc.
Power up laptop and go into BIOS setting the DVD/CD Rom as first boot device.
Place OS disk in drive and boot from disk
Navigate the menu and questions and there you have it. Windows 7 on your laptop.
Now, download all of the drivers as required from Acer.com.
Download Windows updates and resore any backup data files.
Hope that helps.
Dec 31, 2010 | Acer Aspire 5600 Series 5630-6951 Laptop
Wont boot, not even from CD, won't open setup or boot options
At first you insert your system disc on your cd/dvd rom driver and restart your computer. Now press F2 or DEL until you get your BIOS option. Now go to advance option then boot option in that. Now change your first boot option to CD/DVD ROM DRIVE and save that change by pressing F10. Now restart your computer and continue your installation. Thank you.
Jun 10, 2010 | HP Media Center m7250n (ED842AA) PC...
Boot Disc's Not reading, Dvd rom help? or Xp/vista help?
How did you made it boot to the disc? if you used keystrokes to do so, it would be better if you go into your BIOS and set the boot priority making the dvd drive as priority and see if it is gonna work that way. If it does'nt you need to be concerned about the drive itself, it might be having problems as well.
Jun 02, 2009 | Sony VAIO VGN-S480B PC Notebook
We want to Downgrade the OP from VISTA to Windows
get the windows xp disc, press F2 to get into the bios and set the cd rom drive as the first bootable device.
Boot from the windows xp disc - wipe and re install xp as the operating system and then once installed update to at least SP2 and get the drivers for the network card if not already installed and it should be fine as long as you can get the relevant drivers.
Apr 14, 2009 | Dell Inspiron 1525 (dndppa1_3) Intel Core...
Pc wont boot after vista update
You need to boot in safe mode then do a Windows System Restore to before you installed the updates. You can try redownloading and installing them and if the problem occurs again, just repeat the process.
Feb 21, 2009 | Computers & Internet
I am new to building pc's and I've just bought a asus p5ql motherboard, 4gb ram, intel processor and a hd. I have it all together. Green light on board, fans spin, etc. I get the Asus start up screen and...
Just follow these simple steps:
1. Make sure you have all the discs included in your package.
2. After you power-up, strike del key to go to bios/system.
3. In boot selection, select DVD/CD ROM to boot first, HDD second and other if you wish..
4. Press ctrl+alt+delete to restart.
5. After pressing the tree (3), insert your CD/DVD installer to the drive..
6. Follow the instruction...
Good luck and have a nice day!
Feb 16, 2009 | ASUS P5QL-E Motherboard, LGA775, Intel P43...
Compacq Presario
Prior to re-installing your OS, backup all your documents..
Insert your recovery disk cd on the cd rom drive and reboot your pc.
As it reboots press any key to continue so it will boot from cd and delete the partition, create a partition and active it.
Then install the OS which goes to C:\ drive. After the installation is complete install all the drivers and the applications. You can go to the manufacturer's website and download others drivers as needed.
Activate Windows then go to Microsoft Update
Dec 09, 2008 | Computers & Internet
Rebooting
Hello! am Fabian,
problem.
when i turned the computer on it tells me windows did not start successfully. it wont ...
solution.
to solve this problem you need at list the operating system installation CDs/DVDs and a pair of screw drivers.
using the screw drivers, open the system and carefully unistall any or all newly installed hardware device. try to boot again, if the system boots correctly, you may need to consult the manufacturers of the new hardwares you just unistalled for installation guide. but if this does not solve your problem you will need to boot your system using the operating system installation CD/DVD. all you need do is;
1. access your systems BIOs setup utility program by pressing the "Del", "F1","F2" or "F10" as the case may be. select its advance option and set its boot sequence/priority to boot from CD/DVD first then save the setting and exit.
2. insert the operating system CD/DVD ROM, when the system prompts to boot from the CD/DVD ROM press any key and wait to allow the setup initialisation process to complete. once complete, the system show 3 options from which you press the "R" key and wait next it prompt you to mount onto your WINDOWS installation simply press "1" and press the "Enter" key then enter your password if any and also press the "Enter" key.
3. on the command prompt enter the following command;
chkdsk /p then press the"Enter" key wait for the process to complete then restart your computer.
if the problem persist you will need to reinstall your operating system. visit microsoft website for detailed installation guide.
i hope this information will help.
thanks.
Aug 25, 2008 | HP Pavilion dv8000t Notebook
VIA ASRock K7VM3 Socket A/ KM266PRO/FSB333/DDR333/A&V&L/Modem/MATX MotherBoard (MOTASR09) Logo
87 people viewed this question
Top VIA Computers & Internet Experts
David
David
Abhinandan  Patil
Abhinandan Patil
jason
Are you a VIA Computer and Internet Expert? Answer questions, earn points and help others
