Question about Nintendo Wii Fit for Wii
I have owned the wii fit for 3 years, and have a successful wii fit work out program. When I step on the board (when prompted) the little green centering thingy is all the way to the right and it says I am fidgeting. I have never had this problem before. It now for the most part is useless. I can not use it.. What do you think is the issue.. Any help would be very helpful.
    New Friend:
  • 98 Answers
You can recalibrate the board. I forget where the option is but it's usually within the program you are using. This may help.
Posted on Sep 03, 2010
My wii fit board keeps telling me to step off and press (A) even though i am not stood on it
iv got the same problem too, iv resync it and nothing, wiped the wii clean and started again and nothing (mine went down just b 4 xmas and 'santa' got my boy the wii fit plus and he ant been able 2 play it yep) PLEASE PLEASE PLEASE some1 help
Jan 29, 2010 | Nintendo Wii Fit - Balance Board + Game...
My wii fit board will not stay on when I press the button. I have put new batteries in it.
The WII Fit board will only stay on, if there is a game loaded and waiting to access the board. For instance, the WII Fit game will prompt you to turn on the the WII Fit board. If you turn it on before prompted, the WII Fit board will turn itself off.
However, assuming you do not have a hard ware problem and you have already put in fresh batteries. you may have to resync the WII Fit board and the WII. Try pressing the red button on the WII Fit Board (near batteries) and the WII itself (near the SD card slot).
Nov 02, 2009 | Nintendo Wii Console
Wii fit balance board
Make sure that whatever game you are playing (ie: Wii Fit) is fully loaded before pressing the power button.
If the light continues to go off, you may need to re-sync your Wii Fit balance board to the console. To do this, load Wii Fit, and when the program is running, press the red button inside the battery cover. Immediately press the same type of red button inside the panel on the Wii located between the eject and reset buttons (on the face).
If these steps don't work, try fresh new alkaline batteries and repeat.
Note that there have been lots of complaints using rechargable batteries. I've had the same alkalines in my unit for 3 months now. If insistent on using rechargables, I suggest buying several of the same battery and a quick (15 minute or 1 hr) charger as opposed to ANY after-market recharging product. It will be cheaper and more reliable.
Apr 07, 2009 | Nintendo Wii Fit for Wii
Wii fit balance board 3 quadrants are green and 1 is red
This means that one of the 4 sensors is broken. You will need to contact Nintendo via their website to get it repaired.
Good luck, and sorry about that!
Feb 11, 2009 | Nintendo CTA Digital WI-BBP Wii Fit...
Says I'm On When I'm Not
I managed to get my board working by, removing the covers from the feet sensors then placing the board upside down on the floor, then gently pulling on one foot sensor and pressing a, i continued until i found the one with the problem,
the solution i found was if you loosen the screw connecting the plate to the sensor very slightly the board will the calibrate and function correctly,
my board is still working without problems, hope this helps
Jan 29, 2009 | Nintendo Wii Fit for Wii
Doesnt recognise that you have stepped off the board
just ring nintendo this is a common error one of the sensors have gone, i called them and they sent me postage for me to send it back to them with a reference number and they sent me a new one just go to www.nitendo.co.uk/support and ring the number pressing the number which prompt you
hope this work
mine is working fine now got it back after around a week
Jan 22, 2009 | Nintendo Wii Fit for Wii
Wii Fit Board not working
make sure you have the board the right way around! i know it sounds silly but mine did this and all you have to do is make sure the power button is facing away from the tv! i dont know if that solves your problem but it solved mine!
Jan 11, 2009 | Nintendo CTA Digital WI-BBP Wii Fit...
Wii fit board not working
This is really very frustrating when you face such kind of problems. You may check out Wii Fix Guide to fix the problem yourself. This DIY guide will show step by step pictures to fix the problems yourself without any technical knowledge.
Jan 03, 2009 | Nintendo Wii Console
I'm trying to go through the setup to WII fit. My child did the body test with no problems a couple of days ago. I keep getting an error (fidgeting) when I try to take the body test.
Please be a bit more detailed in the problem. The Wii Fit Balance Board is very sensitive to weight shifts. Ensure that you allow the board to calibrate properly. To do this, I would suggest the following steps:
1) Place balance board on a sturdy, flat, smooth surface. If you have average-shag carpet, be sure to use the little adapters that fit over the feet. If the carpet is too thick, then it will NOT work properly. You may want to consider a small piece of plywood or something similar to set between the carpet and Balance Board.
2) Don't step onto the board until it has calibrated (this is when the board establishes its zero point). It will clearly say "Starting Up" followed by "Ok, Step On." After this, you can generally stay on the board unless a particular routine asks you to get off or for some reason it needs to recalibrate.
3) Finally, you must ALWAYS back out all the way to the Wii Fit Plaza (where you pick your Mii) if you change players. Once the board is configured for one player, it will only be suitable for that individual. Its sensitivity is based on an individuals weight. For instance, if the board is calibrated for a 3-year old's Mii, and an adult decides to play any of the routines on that Mii, the board will be over sensitive (calibrated for the lighter weight). Conversely, if an sdult's Mii is selected and a child plays a routine, the board may not detect the movement.
I hope these steps will help. If not, please offer a step by step explanation on what you are doing and I will try to reassess your situation.
Thanks!
Dec 29, 2008 | Nintendo Wii Fit for Wii
Nintendo Wii Fit for Wii Logo
176 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Bee Santiago
Raj Patel
phil
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
