Question about Scanport 17" LCD Monitor
After a short while the monitor just goes off. If I unplug it and then plug back un it comes on for 15 top 20 minutes and then does it again. What do I do?
  • 11,361 Answers
It may have cold solder joints, failing componenets such as capacitors due to heat. You need to open it up and do some visual inspection and post back what you see.
If you are going to DIY and have proper tools and know safety precaution then please read on:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply (they should be replaced in a set), blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Posted on Sep 03, 2010
Monitor goes black immediately after waking from sleep, at the same time the power light changes from green to yellow. Image is just visible on black screen when viewed with a torch, After a wait of about...
Common problem in this model is bad DC filter caps, that will be the first place to look.
Sep 01, 2010 | HP Pavilion F1523 15" LCD Monitor
Backlight repeatedly turns off
Replace the backlight.
Google your make and model, lots of places selling replacements
Jul 31, 2010 | Belinea 10 15 55 15" LCD Monitor
Monitor turns on for about a minute then screen fades to a half lit and then goes dark. if you turn it off even for a split second it comes back on and then repeats. This monitor has had less than 20 hours...
If it is left plugged into the wall, the power supply is always running 24/7 even the power switch is OFF.
Most common failure in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed SAMSUNG monitors to get some ideas what goes wrong: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further.
http://www.badcaps.net
Apr 03, 2010 | Samsung SyncMaster 216BW Monitor
My LCD monitor is blinking green but no display is coming, some days back after blinking 15-20 minute display comes. But now display not come
Most common failure in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, falied inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what goes wrong: http://s807.photobucket.com/home/budm/allalbums
Mar 09, 2010 | Dell UltraSharp 1701FP 17" LCD Monitor
HP w2007 monitor will not turn on. When unplugged and re-plugged (power cord) the little blue light in the on-off button flashes once, then nothing. The blue light in the pwer button remains unlit, and...
The only troubleshooting step I can offer here, is unplug it, and press the power button down for about 15-20 seconds, to flush any trickle power remaining in the unit. Then plug it back in, hook it up and try turning it on again. If this solves it, great! If it doesn't though, then I would check either with HP directly or with your place of purchase to see if your issue can be covered under limited/extended warranty. If you are out of warranty though, LCD repairs tend to jump pretty high, and usually end up being more than what the monitor is worth, so it may be more economical to replace it at that stage.
May 10, 2009 | HP W2007 LCD Monitor
Tv powers off after 15-20min
chk fans 4 dust & clean if no help replace the largest visable fan approx 6"
Apr 27, 2009 | Televison & Video
ViewSonic VX2235wm LCD Monitor
hello do you still have the monitor maybe i can trade you something for it i could use the parts to fix a unit i have lmk thanks
Sep 08, 2007 | ViewSonic VX2235wm LCD Monitor
Scanport 17" LCD Monitor Logo
32 people viewed this question
Top Scanport Computers & Internet Experts
William Miller
William Miller
Jerry Umali
richie46
Are you a Scanport Computer and Internet Expert? Answer questions, earn points and help others
