Question about GE WCVH6260FWW
Its not pumping in any water and all i can hear is a loud noise from the outbound pump in the lower right corner of the unit?
  • terry2fish Sep 03, 2010
    No that does not help; it is not pumping in inbound water? It will pump water out simply because i filled a bucket of water up just to see and it pumped it out without a problem. When i turn it on even to rinse it will not pump in water and after a few minutes the outbound pump will kick on?
  • terry2fish Sep 07, 2010
    Do you know whats involved in fixing the float switch? I have checked the screens and the water supply and they are both O.K.
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. To start with check the water inlet valve which is located behind the lower access panel on the left or right side of the Dishwasher. If the water inlet valve is bad you have to replace it, also check the main water line for clogs/obstructions. If still the issue is not resolved then it’s a bad float switch and needs to be replaced. Please do accept the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Posted on Sep 03, 2010
    Brigadier General:
  • 3,917 Answers
Hi
Please check this link bellow and have a detailed idea regarding your query:-
http://www.repairclinic.com/Washing-Machine-Troubleshooting#Itwontdrain
Please accept the solution if it’s helpful. Do get back to us for any further query.
Thanks for contacting fixya.com
Ice maker won't make ice
most times I see the tray and fill tube ice up its due to a leaky fill valve , this valve should close tight after filling tray , but sometimes they leak just slightly then everything freezes up in a block of ice
fill valves on most all units is located in back lower left corner , just follow the water line in the back of unit
Jan 15, 2016 | True Refrigerators
Water not pumping from the tank
If the pump is primed, water will come out of the tank when the pump is running. It make take a little time for the tank to fill, but you should hear the pump making some noise. An un-primed pump just makes a motor noise, not very loud.
Aug 12, 2015 | Plumbing
Hobart LXiH error E4 AND part makes noise when OFF
test this steps and fix it. GOd bless you
Drain Pump
If the dishwasher is loud during operation, the drain pump might be defective or might have some debris in it. This is a common problem.
Enter your model number to see parts for your dishwasher.
Help me find my model number
Circulation Pump
If the dishwasher is loud during operation, and the noise is a continuous drone similar in speed to the circulation pump sound, it's likely that the circulation pump motor bearings have failed. Once this happens the circulation pump will have to be replaced, the bearings are not repairable.
Drain Impeller
If the dishwasher is loud during operation, the drain impeller might be broken, or there might be debris in the pump. Generally, to gain access to the pump the top of the pump housing will have to be removed.
Pump and Motor Assembly
If the dishwasher is loud the motor bearings, drain impeller or wash impeller might have worn out. All three of these components are part of the pump and motor assembly. It may be possible to replace one of the impellers, but the motor bearings cannot be repaired. In that case the pump and motor assembly will need to be replaced.
Wash Impeller
The wash impeller is a small, plastic blade. The motor spins the impeller forcing water through the spray arms to clean the dishes. If one or more blades has broken off of the impeller the dishwasher is loud. The impeller can also scrape against the pump housing if it is damaged, warped or bent.
Circulation and Drain Pump Motor
If the dishwasher is loud during operation, and the noise is a continuous drone similar in speed to the motor sound, it's likely that the circulation and drain pump motor bearings have failed. Once this happens the motor will have to be replaced, the bearings are not repairable.
Water Inlet Valve
The water inlet valve is an electrically controlled water valve. When it is new, the water inlet valve is very quiet. Over time, the diaphragm inside the valve deteriorates and deforms. This deformation interacts with the water rushing in and can cause a loud vibration, buzzing, squealing or other noises. If the dishwasher is loud during the filling cycle, replacing the water inlet valve may solve the problem.
Jul 22, 2013 | Hobart Dishwashers
Hobart LXiH error E4 AND a part makes noise when off
test this steps and fix it. God bless you
Drain Pump
Circulation Pump
Drain Impeller
Wash Impeller
Water Inlet Valve
Jul 22, 2013 | Hobart 24 in. LXIH-3 Built-in Dishwasher
Kitchen Aid Imperial 21 has loud motor noise duing wash cycle
loud motor noises during the wash cycle usually come from a water pump. Either the water pump will stop working soon, or it will keep working for a while longer, and the unit will stop cleaning. Sometimes the pump will stop making the noise for a while before it stops.
Jan 29, 2012 | KitchenAid Dishwashers
Model NHBX-B Date Code 080111CH. We have nothing but trouble since purchasing this unit. Makes a very loud noice when making coffee from we first purchased it. We ignored the noice (sorry we did) Now...
Hi that loud noise you were hearing was the pump not pumping enough water through it. Now it has probably burn't the pump out. All coffee machine manufactures use the same pump, so getting a new one is not a problem. Replace the pump and she'll be right. Dazza REPAIRER
Sep 24, 2011 | Bunn NHB Coffee Maker
I took my 2005 Chev. Malibu in for an oil change and now it is making a loud noise from the engine. they say its the water pump? is that possible?
  • Hi, I can help.
  • When your water pump goes bad it will begin to grind. I had one I let got far to long and it sounded deafening when I opened the hood. You can open your hood and listen and see for yourself. The water pump is on the belt line, left side under the hood, last pulley toward the rear.
  • Now if your asking can an oil change effect the water pump? No, not at all. Water pumps go sporadically.
  • It would be odd that you heard no noises before the oil change and now the water pump is loud enough to take notice after the oil change. The bearings usually go a little slower than that.
  • I would be interested in some more of the details to this. And what your overall concerns are. I'd be happy to further. help. Otherwise get a second opinion on your cars condition.
  • Hope this helps and thank you for using FixYa.
Regards, Tony
Aug 22, 2011 | 2005 Chevrolet Malibu
Why do i still hear a knocking noise in the water pump, when i just changed it. also my coolant pressure cap hoes that connects to the radiator blew off while i was driving, why would that happen after i...
Maybe it's not the water pump that is making the knocking noise.
Water pumps generally don't make knocking noises.
It could have a spun camshaft or main bearing if you hear a loud metal to metal knocking noise.
The coolant pressure cap hose that connnects to the radiator:
Is this an overflow hose that leads to an overflow tank? If so, the hose may have a restriction in it.
Aug 07, 2010 | 2001 Dodge Dakota
When the dishwasher starts or when water starts to enter dishwasher there is a loud noise.
ther could be something stuck n your drain pump.
the way it works is first the unit drains,the it fills,then it start to wash. now if you hear this noise after it drains then it could be your water valve or after it fills when it starts to wash it could be your circulation pump. it depends on what cycle you hear the noise. let me know if this help by posting 4 thumbs up for this answer, thanks
Feb 28, 2010 | Bosch 24 in. SHE44C02UC / SHE44C06UC /...
Whirpool Duet front loader ghw9100lw error code F02
if your hearing clackling try and clean the pump and the hose leading into the pump for a coin ,,small ,,(dime),,,hair clip,,also its a must that you use he detergent,,or you sude up,,if you do use he your using to much,,now bleach the unit out on a normal cycle hot wash cold rinse with about a pint of bleach...and no you can purchase part of a pump..it comes as you see it in unit..onthejob
Jan 12, 2009 | Whirlpool Duet GHW9150P Front Load Washer
GE WCVH6260FWW Logo
42 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
