Question about LG 22" FLATRON LCD Monitor
Monitor keeps shutting off, would this be expensive to fix?
  • 11,361 Answers
Shop rate will be $100 range ($25~35 just to tell you what is wrong with it, free here), it can be as simple as $10~15 worth of caps.
If you are going to DIY and have proper tools and know safety precaution then please read on:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply (they should be replaced in a set), blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Posted on Sep 03, 2010
MICROTEK C997SD MONITOR SHUTS OFF AFTER 5-10 MINUTES
If you turn your monitor on and when its on you go into your computers settings. Where you can fix your monitor and fix the resolution and all that. There should be a thing there where you can put never shut off. You have it on 5 to 10 minutes to shut off. That will keep the monitor from turning off again. I did this with mine it kept shutting off to. Thanks for posting I hope this helps you. I am sorry I couldn't be more detailed. i have been up all night lol.
Dec 12, 2017 | Microtek C997SD (Silver) 19 in. Flat Panel...
The check engine light on my 98 saturn sl1 came on a few weeks ago. i went to go get it checked and i got "p0446 evap emission control, system vent control circuit malfunction" as a result back....
no , not really expensive. yes it can be fixed by replacing the vent solenoid. the solenoid (usually open) gets stuck and the computer can shut it to run the EVAP monitor so it sets the code.
Jul 30, 2011 | Saturn SL1 Cars & Trucks
My Hewitt Packard flat screen monitor keeps shutting off, it will come back on then shut off again.The green light stays on.
my HP w1907 flat screen keeps shutting off after playing a game, but does it frequently when changing browsers also.The blue lite stays on, if I click and return it back on blue the monitor opens for one second.
Also I can't return the screen resolution back to its original setting, which is 1440x900 because any browser home page has a 4"white space on both sides of the monitor. I can't hit my auto selectbutton because that causes the problem. I spent $60.00 for tech support but no help on fixing the problem. One tech directed to buy hardware helper,that was about$30.00! I just keeps directing me to my original chipset setting which I told the tech that's where my problem started! My daily important update keeps popping up with it,so where's the HP support when you paid for it? Problem still not resolved. Joe...aka jljoekool@charter.net,,I bought the HP monitor and tower together,so it's a HP PROBLEM
Dec 12, 2010 | HP Vs17 17" LCD Flat Panel Monitor
E228WFP display disappears Posted by
disconnect all the cable from the monitor except the power cable .
see if you see any test screen and keep it on ,if the test screen blacks out you monitor is bad ,better buy a new one as usually repairs cud be expensive
Apr 17, 2010 | Dell E228WFP LCD Monitor
My monitor keeps shuttinhg off how do I fix it
Common problem for E172/173 are shorted out inverter transformers driver transistors (4) C5706/5707 in the inverter circuits.
Jan 28, 2010 | Dell E173FP 17" LCD Monitor
No power, is it worth fixing?
The proper answer to your question is "it depends".
- LCD's have a long operating life compared to Plasma but they will burn out eventually. If this monitor has been used extensively then even having it fixed will not be worth it because the panel may die off in just a few months
- However, if the LCD was seldom used, then it may be worth it to fix it
- LCD panels are also known to be very expensive. If your problem is just electrical then it will probably worth fixing it.
- However, if your problem is with the panel itself, then replacing it is a better alternative because the replacement panel is very expensive and will be almost as much as a new unit.
NOTE: Please rate our help to keep this free service online.
Jan 11, 2010 | LG L1932TQ LCD Monitor
Monitor shuts off
The labor rate in the midwest where I live is $50 just to look at it. Unless you have electronic experience and test equiptment, I do not believe you wil be ableo to service it yourself.Usually cheeper just to buy another replacement one.
Feb 17, 2009 | Dell M992 19" CRT Monitor
Hp FX 70 monitor keeps shutting off
Sounds like the problem is with the switch itself. No real fix for this.
Both these monitors will work with your desktop without any additional software.
Feb 14, 2009 | HP Pavilion FX70 Monitor
Monitor shutting off with blinking standby light.
Very expensive to fix.You hve a bad ysus board.Nec will re-build theboards as a set 1000.00 plus
Dec 14, 2006 | NEC PlasmaSync 50MP1 50 in. Television
LG 22" FLATRON LCD Monitor Logo
57 people viewed this question
Top LG Computers & Internet Experts
Alun Cox
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
